Two different colors to the same shape  Topic is solved
Postby davesexcel » Wed Apr 03, 2019 3:08 pm
With this code I am drawing a box and a box top, I am coloring the box gray and the top blue. I just require the top to be blue, the sides of the top need to be grey.
Code: Select all
l=96
w=60
h=60
heel=8
slope=4
clr='Gray'
rfClr='blue'
ent = Sketchup.active_model.entities
      #---------Clear All
Sketchup.active_model.entities.clear!
   model = Sketchup.active_model
    model.start_operation "Create Box"
    entities = model.active_entities
    group = entities.add_group
    entities = group.entities
       group.name="Box"
    @pt0 = [0, 0, 0]
    @pt1 = [0, l*12, 0]
    @pt2 = [w*12.0, l*12, 0]
    @pt3 = [w*12, 0, 0]
newface = entities.add_face(@pt0, @pt1, @pt2, @pt3)
    newface.material=Sketchup::Color.new clr
newface.reverse!
    newface.pushpull h*12
       group.name="Top"
#-----------Top----------------
    @pt0 = [0, 0, h*12]
    @pt1 = [0, 0, h*12+heel]
    @pt2 = [w*12/2, 0, 12*h+heel+(w/2)*slope]
    @pt3 = [w*12, 0, 12*h+heel]
       @pt4 = [w*12, 0, 12*h]
newface = entities.add_face(@pt0, @pt1, @pt2, @pt3, @pt4)
    newface.material=Sketchup::Color.new rfClr
    newface.pushpull l*12
davesexcel
Re: Two different colors to the same shape  Topic is solved
Postby TIG » Wed Apr 03, 2019 4:53 pm
Please use 'code' blocks to format long Ruby extracts.
I've fixed your post for you this time...
You need to find all 'vertical' faces in the group named 'Top'.
After the last part of the code add this...
Code: Select all
vfaces = entities.grep(Sketchup::Face).find_all{|f| f.normal.z == 0 }
vfaces.each{|f| f.material = clr }
Global Moderator
Return to Developers' Forum
Users browsing this forum: fz6242001 and 10 guests
