Efficient Code?
Efficient Code?
Postby medeek » Tue May 08, 2018 9:47 pm
As I'm working on the finishing touches to the Wall Plugin the six panel door geometry is something that keeps coming back to me.
This type of door geometry is fairly typical so eventually I would like to implement it however it does have a very high polygon count comparatively speaking. I've devised a fairly straightforward piece of code that generates a single panel, see below (cut and paste into the ruby console to view solid geometry):
Code: Select all
  group1 = Sketchup.active_model.entities.add_group
    entities = group1.entities
    new_face1 = entities.add_face [0,0,0], [500,0,0], [500,500,0], [0,500,0]
    new_face1.pushpull 50
    pt1 = [100,100,0]
    pt2 = [200,100,0]
    pt3 = [200,200,0]
    pt4 = [100,200,0]
    new_face2 = entities.add_face pt1, pt2, pt3, pt4
    pt1 = [130,130,0]
    pt2 = [170,130,0]
    pt3 = [170,170,0]
    pt4 = [130,170,0]
    pt1 = [110,110,0]
    pt2 = [190,110,0]
    pt3 = [190,190,0]
    pt4 = [110,190,0]
    line1 = entities.add_line pt1, pt2
    line2 = entities.add_line pt2, pt3
    line3 = entities.add_line pt3, pt4
    line4 = entities.add_line pt4, pt1
    entities_to_transform = [line1, line2, line3, line4]
    transform = Geom::Transformation.new([0,0,-5])
    entities.transform_entities(transform, entities_to_transform)
However, my concern is that this block of code will need to be iterated twelve times in order to create the six panels on each side of the door, a lot of computation in order to create this door style. In that light, I would like for this code to be efficient and tight as possible, since the plugin is already quite heavy just in generating simple block geometry (ie. studs, casing, trim etc...).
Is there a more efficient way to write this block of code?
Nathaniel P. Wilkerson PE
Medeek Engineering Inc
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Return to Developers' Forum
Users browsing this forum: No registered users and 13 guests
