by TNTDAVID » Sun Oct 22, 2017 3:51 pm
Hello,
The code below redraws the instance 0 named with the definition "BOX".
- Code: Select all
model = Sketchup.active_model model_definition = model.definitions model_def = model_definition['BOX'] $dc_observers.get_latest_class.redraw_with_undo(model_def.instances[0])
How to redraw all the instances being selected without taking their definitions into account?
Thank you
David
* Nouveau !!! Découvrez notre nouveau Plugin Click-Cuisine 2, pour créer vos cuisines 3D !
TNTDAVID
- PluginStore Author
- Name: TNTDAVID
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: woodworking
- Level of SketchUp: Advanced
by TIG » Sun Oct 22, 2017 3:57 pm
Something like - Code: Select all
Sketchup.active_model.selection.grep(Sketchup::ComponentInstance){|i| next unless i.definition.attribute_dictionaries["dynamic_attributes"] $dc_observers.get_latest_class.redraw_with_undo(i) }
- Global Moderator
- Name: TIG
- SketchUp version: 2021
- License type: Pro
- SketchUp use: architecture
by TNTDAVID » Sun Oct 22, 2017 4:01 pm
I get the following error message with your TIG example:Error: #<ArgumentError: wrong number of arguments (1 for 0)> <main>:2:in `attribute_dictionaries' <main>:2:in `block in <main>' <main>:1:in `each' <main>:1:in `grep' <main>:1:in `<main>' -e:1:in `eval' nil
TNTDAVID
- Name: TNTDAVID
- License type: Pro
by TIG » Sun Oct 22, 2017 4:05 pm
Sorry, I adjusted the () to []. I can't actual test this code as I type it !
- Global Moderator
- Name: TIG
- License type: Pro
by TNTDAVID » Sun Oct 22, 2017 6:09 pm
Thank you TIG! This solution will give me even more possibilities in the future with the dynamic components.
TNTDAVID
- Name: TNTDAVID
- License type: Pro
by TNTDAVID » Tue Oct 24, 2017 1:53 pm
I found with some tests that it is not possible to add dynamic attributes to neutral components.
The component must have at least an existing attribute for it to be possible to add attributes in ruby.
If not, we have this error message:
Error: #<NoMethodError: undefined method `[]' for nil:NilClass> <main>:1:in `block in <main>' <main>:in `each' <main>:in `grep' <main>:in `<main>' -e:1:in `eval' nil
The goal is certainly to protect the creation of dynamic components, which is only available in Pro version of SketchUp?
TNTDAVID
- Name: TNTDAVID
- License type: Pro
by TIG » Tue Oct 24, 2017 1:55 pm
Without us seeing your code it's impossible to say what raises your error message. Perhaps adding an extra test before testing for the DC attribute dictionary [] entry next unless i.definition.attribute_dictionaries as the first test will stop it failing, since the DC dictionary can't be tested for without the existence of the attribute dictionaries entry.
- Global Moderator
- Name: TIG
- License type: Pro
by TIG » Tue Oct 24, 2017 2:06 pm
You can create a new dictionary thus - Code: Select all
some_definition.set_attribute("dynamic_attributes", "test", "1") p some_definition.attribute_dictionaries["dynamic_attributes"]
- Global Moderator
- Name: TIG
- License type: Pro
by TNTDAVID » Tue Oct 24, 2017 8:58 pm
Sorry TIG for not having specified the method used.
I tried these 2 methods:
- Code: Select all
Sketchup.active_model.selection.grep(Sketchup::ComponentInstance){|i| next unless i.definition.attribute_dictionaries["dynamic_attributes"] i.set_attribute 'dynamic_attributes','teste', '1' $dc_observers.get_latest_class.redraw_with_undo(i) }
- Code: Select all
Sketchup.active_model.selection.grep(Sketchup::ComponentInstance){|i| next unless i.definition.attribute_dictionaries["dynamic_attributes"] i.set_attribute("dynamic_attributes", "test", "1") i.attribute_dictionaries["dynamic_attributes"] $dc_observers.get_latest_class.redraw_with_undo(i) }
None of the 2 solutions work on a component without dynamic attributes.
But these 2 solutions work on components already have dynamic attributes.
TNTDAVID
- Name: TNTDAVID
- License type: Pro
by TIG » Tue Oct 24, 2017 9:26 pm
The attributes belong to the instance's defintion NOT the instance. You mess up trying to set things to the instance, NOT the definition ! Try substituting something like... - Code: Select all
i.definition.set_attribute('dynamic_attributes', 'teste', '1') $dc_observers.get_latest_class.redraw_with_undo(i)
Please learn the difference between a definition and its instance !!!!!
- Global Moderator
- Name: TIG
- License type: Pro
by TNTDAVID » Tue Oct 24, 2017 9:56 pm
This still does not work for components without attributes:- Code: Select all
Sketchup.active_model.selection.grep(Sketchup::ComponentInstance){|i| next unless i.definition.attribute_dictionaries["dynamic_attributes"] i.definition.set_attribute('dynamic_attributes', 'teste', '1') $dc_observers.get_latest_class.redraw_with_undo(i) }
TNTDAVID
- Name: TNTDAVID
- License type: Pro
by TIG » Tue Oct 24, 2017 10:34 pm
WTF ! You really must learn basic principles... consider this: - Code: Select all
Sketchup.active_model.selection.grep(Sketchup::ComponentInstance){|i| ###next unless i.definition.attribute_dictionaries["dynamic_attributes"] i.definition.set_attribute('dynamic_attributes', 'teste', '1') $dc_observers.get_latest_class.redraw_with_undo(i) }
The added ### skips the check for the dictionary [ which you do NOT need ! ]... so IF a definition does NOT have that dictionary set then it makes it anyway !!!!!!
- Global Moderator
- Name: TIG
- License type: Pro
by TNTDAVID » Wed Oct 25, 2017 5:53 pm
OK TIG, I understand!
The Ruby is very wide and has many instructions such as:
!,&&,||,and,box,else,elsif,eql?,equal,if,then,not,gold,require,unless,wheen,true, false...
I had not yet read "unless".
I realize that it takes many years of Ruby to totally understand him master it.
As I learn according to my needs, this undoubtedly slows down my general understanding of ruby.
Promised, next time I would make more effort with your examples before publishing it does not work.
Ps: Your solution works wonderfully TIG
Thanks a lot for your help.
David
TNTDAVID
- Name: TNTDAVID
- License type: Pro
by TNTDAVID » Thu Oct 26, 2017 4:53 pm
Hello,
I now want to refresh the visible dynamic components.
If not, the answer must be "nil".
The methde below works for components that are not nested:
- Code: Select all
m=Sketchup.active_model; s=m.selection; m.definitions.each{|d|s.add d.instances if d.name=~/#{"BOUTON"}/} s.grep(Sketchup::ComponentInstance){|i| next if i.hidden? $dc_observers.get_latest_class.redraw_with_undo(i) }
Oddly if the components with the "BOUTON" definitions, are nested in another component, they will be considered as visible even if they are hidden.
Do you know what is the problem?
Thank you
TNTDAVID
- Name: TNTDAVID
- License type: Pro
by TNTDAVID » Sat Oct 28, 2017 2:54 pm
I solved the problem of my previous post!
Now, I'm facing another problem that is much more difficult to solve.
The code below adds an attribute to all the "Handles" definitions that are visible in the components being selected.
- Code: Select all
def handlesCI(ents) sel = Sketchup.active_model.selection ents.each do |e| if e.is_a? Sketchup::ComponentInstance sel.add e if e.definition.name=~/#{"HANDLES"}/ handlesCI(e.definition.entities) sel.grep(Sketchup::ComponentInstance){|i| next unless i.visible? i.set_attribute 'dynamic_attributes','attribut', '1' } end end end
This method does not work to refresh only visible components.
- Code: Select all
def handlesCI(ents) sel = Sketchup.active_model.selection ents.each do |e| if e.is_a? Sketchup::ComponentInstance sel.add e if e.definition.name=~/#{"HANDLES"}/ handlesCI(e.definition.entities) sel.grep(Sketchup::ComponentInstance){|i| next unless i.visible? $dc_observers.get_latest_class.redraw_with_undo(i) } end end end
I need your help to understand the problem.
Thank you
David
TNTDAVID
- Name: TNTDAVID
- License type: Pro
by TIG » Sat Oct 28, 2017 8:41 pm
Please stop adding entities into the selection. What happens if it already contains some selected entities ? You haven't cleared it ?? Also these additions might not be in the current context and cause various issue down the line... Simply create an empty array and add entities to that if they meet a certain test. e.g. - Code: Select all
def handlesCI(ents) array = [] ents.grep(Sketchup::ComponentInstance).each{|e| ### collect only visible instances next unless e.visible? array << e if e.definition.name =~ /#{"HANDLES"}/ handlesCI(e.definition.entities) ### repeat for nested entities in visibles } array.each{|i| ### process this array of instances $dc_observers.get_latest_class.redraw_with_undo(i) } end
- Global Moderator
- Name: TIG
- License type: Pro
by TNTDAVID » Sun Oct 29, 2017 3:17 am
Your method works TIG, but it does not keep the "Handles" definitions selected.
The goal is to update all Invisible Handles, then select any definition "Handles" without visibility restrictions.
TNTDAVID
- Name: TNTDAVID
- License type: Pro
by TNTDAVID » Sun Oct 29, 2017 1:33 pm
Here I am in a paradox!
If I apply your TIG method, the handles selected in Method 2 will also be redrawn.
- Code: Select all
def methodeTIG(ents) sel = Sketchup.active_model.selection array = [] ents.grep(Sketchup::ComponentInstance).each{|e| ### collect only visible instances next unless e.visible? array << e if e.definition.name =~ /#{"HANDLES"}/ methodeTIG(e.definition.entities) ### repeat for nested entities in visibles } array.each{|i| ### process this array of instances $dc_observers.get_latest_class.redraw_with_undo(i) } end
def methode2(ents) sel = Sketchup.active_model.selection ents.each do |e| if e.is_a? Sketchup::ComponentInstance sel.add e if e.definition.name=~/#{"HANDLES"}/ methode2(e.definition.entities) end end end
def methode_end methodeTIG(instances) methode2(instances) ### The handles of this method are drawn by the methodTIG! end
How can I avoid this?
Thank you
TNTDAVID
- Name: TNTDAVID
- License type: Pro
by TNTDAVID » Mon Oct 30, 2017 4:51 pm
I ended up bypassing the problem by selecting a different definition than "handles" in method 2.
I asked to select the IKEA definition, which corresponds to the furniture that contains the facades and the handle inside.
- Code: Select all
def ikeaCI(ents) sel = Sketchup.active_model.selection ents.each do |e| if e.is_a? Sketchup::ComponentInstance sel.add e if e.definition.name=~/#{"IKEA"}/ ikeaCI(e.definition.entities) end end end
This is possible because I specified the definition of the highest components of the hierachie.
Is it possible to select the highest components of the hierarchy without specifying the name of that definition?
Thank you TIG for your method that allows me to redraw the visible handles.
TNTDAVID
- Name: TNTDAVID
- License type: Pro
- Robot
Return to Developers' Forum
