[Plugin] Slender - Baking textures in Sketchup with Blender
Hmm, i see now better.
So, can we say it's not that suitable for interior stuff? Or is it possible to add other light types in addition to sun into baking process? -
So, can we say it's not that suitable for interior stuff? Or is it possible to add other light types in addition to sun into baking process?It's all a matter of translating objects from SU to Blender, then everything is possible.
qpik, you're using cycles or is this blender internal?
@qp
fantastic idea. Can't get it going yet so subscribing so I can flag updates
Out of curiosity. I've seen great things coming from cycles and heard it's improving very fast.
Who knows where this plugin will lead so, maybe cycles would be a good bet.
@filibis said:
I will see tomorrow what causes problem in the office computer
I tried again in the office today, i noticed this code was missing in slender.bat
%~dp0\slender.blend
(see attachment) I don't remember deleting it, maybe downloaded the .zip yesterday before you update or something idk
So i downloaded .zip again today, it worked fine.
A couple of question.
How does the geometry look when imported back into SketchUp?
Is it grouped the same?
Are the components intact?
Is the geometry triangulated or as it was originally in SU? -
Is the geometry triangulated or as it was originally in SU?Seems it imports one component that contains the whole geometry and everything inside exploded. Also triple clicking only select ones that shares the same material. See below for gif demonstrations.
Triangulation and other export features are optional (see attachment). (But making "preserve_instancing => true" doesn't seem to be working)
Unless I'm missing something there's no combination of COLLADA import/export settings in SU and Blender that would keep components. It's just how those exporters/importers work.
Triangulation solves issue with holes in faces, which are not supported, as far as I learned, in Blender.
The real question is whether keeping component structure is really necessary, I doubt it.
I am getting the same result as qpik, I put the pause i nthe bat file and this is the error it is giving me:
TypeError: Converting py args to operator properties: : keyword "include_material_textures" unrecognized -
I should have also included I am using win 10, blender 2.79c, sketchup 17
