Replace Several Textures?
Postby TNTDAVID » Mon Apr 24, 2017 4:13 pm
Hello, :enlight:
I'm currently developing Click-Cuisine 2 and I want to bring a very important new feature.
This feature should allow multiple materials to be replaced with a single click on an icon.
The goal is to display all IKEA colors in any kitchen project by a simple click.
It remains for me to discover how to write the method and I need your help to succeed. ;)
Explanation Stage by Stage of my final goal:
1st click on the icon:
The materials with the pictures, "1-100x40.jpg", "1-80x40.jpg", "1-60x40.jpg" ....
Which are applied on furniture are replaced by:
The images, "2-100x40.jpg", "2-80x40.jpg", "2-60x40.jpg" ....
These images are in the folder "Plugins\TNT_ClickCuisine2\Materials"
2 nd Click on the icon:
These are the images, "3-100x40.jpg","3-80x40.jpg", "3-60x40.jpg", which are loaded.
This will allow the different colors to be displayed quickly and easily on all furniture.
Here is the organization of the Materials file:
I need your experience to find the simplest method possible!
1.How would you proceed?
Here's the little I know about the materials:
Code: Select all
Model = Sketchup.active_model
Materials = model.materials
Material = materials.add ('100x40')
Material.texture = "C: /Materials/1-100x40.jpg"
Texture = material.texture
This creates a material with an image from a raw path.
2.How to do the same with a path of type, " Plugins\TNT_ClickCuisine2\Materials " ?
3.Then how to replace the image of the materials?
4.Is this the right approach or do you have a simpler solution?
Thank you in advance for your help.
David
* Nouveau !!!
Découvrez notre nouveau Plugin Click-Cuisine 2, pour créer vos cuisines 3D !
TNTDAVID
PluginStore Author
PluginStore Author
Re: Replace Several Textures?
Postby sdmitch » Mon Apr 24, 2017 10:35 pm
This seems to work for the 3 'sets' of materials I created.
Code: Select all
def cycle_materials
  mat_names = ['60x40','80x40','100x40']
  materials = Sketchup.active_model.materials
  mat_names.each{|mn| materials.add(mn) unless materials[mn]}
  mat_folder = File.join(File.dirname(__FILE__).gsub('\\','/'),"TNT_ClickCuisine2/Materials/")
  @last ||= '0'
  @last=='3' ? @last='1' :  @last=@last.next
  for mn in mat_names
    material = materials[mn]
    material.texture = mat_folder + "#{@last}-#{mn}.jpg"
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Postby TNTDAVID » Tue Apr 25, 2017 3:10 am
Hello sdmitch,
Thank you for your help !
I tested the code with the Ruby console which returns "nil".
Can you tell me for what?
Can you explain how your code works?
Thank you
David
* Nouveau !!!
TNTDAVID
PluginStore Author
PluginStore Author
Postby TNTDAVID » Tue Apr 25, 2017 2:20 pm
I wrote the code in a .rb file and then I called it with an icon.
When I click on the icon, 3 black materials are created but no "jpg" image is imported.
You can download the file.rbz, below:
TNT_ClickCuisine2.rbz
Here is the code:
Code: Select all
module ClickCuisine2
  class << self
  @@path_to_resources = File.join(File.dirname(__FILE__), 'Resources')
  def materials
      @last ||= '0'
      for mn in mat_names
if !file_loaded?(__FILE__)
        su_menu = UI.menu("Plugins")
        cc_menu = su_menu.add_submenu(%Q(Click_Cuisine2))
        tb = UI::Toolbar.new(%Q(Click-Cuisine2))
        command1 = UI::Command.new("Nex Material"){ ClickCuisine2.materials }
        command1.small_icon = File.join(@@path_to_resources,"add_00.png")
        command1.large_icon = File.join(@@path_to_resources,"add_00.png")
        command1.tooltip = %Q(Nex Material)
        command1.status_bar_text = %Q(Nex Material)
        command1.menu_text = %Q(Nex Material)
        cc_menu.add_item(command1)
        tb.add_item(command1)
        tb.restore
        file_loaded(__FILE__)
* Nouveau !!!
TNTDAVID
PluginStore Author
PluginStore Author
Postby sdmitch » Tue Apr 25, 2017 2:38 pm
There is no need to import the materials. The code simply re-defines the texture to be used. If the newly created materials are still 'black', then the textures are not where they should be.
sdmitch
PluginStore Author
PluginStore Author
Postby TNTDAVID » Tue Apr 25, 2017 2:57 pm
The textures should not be in the folder, "C:\Users\Dada\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins\TNT_ClickCuisine2\Materials" ? :shock:
If not, in what folder should the images be?
Thank you
* Nouveau !!!
TNTDAVID
PluginStore Author
PluginStore Author
Postby sdmitch » Tue Apr 25, 2017 3:59 pm
That would be correct if the plugin is in "C:\Users\Dada\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins"
sdmitch
PluginStore Author
PluginStore Author
Postby TNTDAVID » Tue Apr 25, 2017 5:53 pm
The plugin is in the right place!
I think the problem has to be tied to something else.
Can you share your "rbz" file?
Your soluition is great and very interesting.
Thank you
David
* Nouveau !!!
TNTDAVID
PluginStore Author
PluginStore Author
Postby sdmitch » Tue Apr 25, 2017 6:22 pm
TNTDAVID wrote:The plugin is in the right place!
Thank you
David
Hope this helps.
sdmitch
PluginStore Author
PluginStore Author
Postby TNTDAVID » Tue Apr 25, 2017 10:18 pm
Thank you very much! :)
Moving from one material to another with Click-Kitchen 2, will be much faster and easier with your code. ;)
I would make a small demo as soon as the code is applied to the plugin.
Ps: My error was indeed the path to the materials file.
Code: Select all
File.join (File.dirname (__ FILE __). Gsub ('\\', '/'), "TNT_ClickCuisine2 / Materials /"
Corrected like this:
Code: Select all
File.join (File.dirname (__ FILE __). Gsub ('\\', '/'), "Materials /"
* Nouveau !!!
TNTDAVID
PluginStore Author
PluginStore Author
Postby TIG » Tue Apr 25, 2017 10:46 pm
NEVER include a <space> between a method and its parenthesized arguments !
AND you show some weird Capitalization and added spaces !
So it IS NOT:
BUT:
File.join( File.dirname(__FILE__).gsub('\\', '/'), "Materials/" )
In fact it'd be better as:
File.join( File.dirname(__FILE__).tr("\\", "/"), "Materials" )
Then the path can be joined to the files without the trailing '/' ??
Suitable for all OSs.
BUT the exactly correct way would be:
File.expand_path( File.join(File.dirname(__FILE__), "Materials") )
Which always uses / rather than \ ...
Global Moderator
Postby TNTDAVID » Thu Apr 27, 2017 4:26 pm
OK TIG ;)
How to do the same for components?
Example:
I have 3 boxes, "1-Box", "2-Box", "3-Box", they are in the folder "Plugins/ Click-Cuisine2/Components".
I want to create an icon that calls a method of this type:
1st Click
Selects all components with the definition "1-Box ##", and replaces with "2-Box", which is in the "Components" folder.
If no component with the definition " 1-Box" was found, send the message, "Import a Clik-Cuisine 2 furniture, to replace these components ".
2nd Click
Selects all components with the definition "2-Box ##", and replaces it with "3-Box".
3rd Click
Selects all components with the definition "3-Box ##", and replaces with "1-Box".
Final objective:
Click-Cuisine 2, will offer more than 20 IKEA handles that I want to interchange with one click.
This can be done in Dynamic Components, but it is not suitable for such a large number of 3D models.
If you can help me write this method, I would be very glad. :enlight:
thank you
David
* Nouveau !!!
TNTDAVID
PluginStore Author
PluginStore Author
Postby TIG » Thu Apr 27, 2017 5:10 pm
Clicks 1/2/3:
Find all component instances matching a certain name.
If none then messagebox, but if some are collected, then check if the particular replacement component definition exists and use that, otherwise load it from your SKP subfolder... swap the collected instances' definitions for the desired one...
Here is an outline - assuming your clicks are suitably trapped in a Tool, or are buttons on a webdialog etc...
Currently this is for filtered selected objects only:
Code: Select all
path_to_SKP_folder = "????????"
# you must set this from knowing your File.dirname(__FILE__)
# which can be joined with the SKP subfolder's name etc
model = Sketchup.active_model
defns = model.definitions
ss = model.selection
name = "Box-1" # we'll match the start of the names only /^.../
instances = ss.grep(Sketchup::ComponentInstance).find_all{|e| e.definition.name =~ /^#{name}/ }
unless instances[0]
  UI.messagebox("#{name} NOT matched !")
  return
else
  rname = name.next # e.g. Box-2
  unless defn = defns[rname]
    defn = defns.load(File.join(path_to_SKP_folder, rname+".skp")) # you set up SKP path earlier !
  instances.each{|e| e.definition = defn }
If you want to do it globally, then you need to grep model.entities and then all defns' entities in turn - filtering out .image? - to process only groups and component contexts...
Global Moderator
Postby sdmitch » Fri Apr 28, 2017 1:40 am
TNTDAVID wrote:OK TIG ;)
Example:
1st Click
2nd Click
3rd Click
Final objective:
thank you
David
This seems to work for me.
Code: Select all
      @mod = Sketchup.active_model
      @ent = @mod.active_entities
      @last ||= '1'; @next = @last.next; @next='1' if @next=='4'
      last_name = @last + '-Box'; next_name = @next + '-Box'
      cmp_folder = File.join(File.dirname(__FILE__).gsub('\\','/'),"TNT_ClickCuisine2/Components/")
      cis = @ent.grep(Sketchup::ComponentInstance).find_all{|ci|ci.definition.name[0..4]==last_name}
      unless cis.empty?
        for ci in cis
          cd = @mod.definitions[next_name]
          unless cd
            cmp = cmp_folder+"#{next_name}.skp"
            cd = @mod.definitions.load cmp
          ci.definition = cd
        @last = @next
      else
        UI.messagebox "#{last_name} not found."
sdmitch
PluginStore Author
PluginStore Author
Postby TNTDAVID » Fri Apr 28, 2017 11:32 am
Great! Your two examples work perfectly. :enlight:
TIG with the method, I must manually select "Box-1", so that "Box-2", replaces it.
How to automatically select all the "Box-1" components, even those that are nested in a piece of furniture?
And How to switch from "Box-2" to "Box-3"?
Sdmitch your code is very surprising! :thumb:
All "1-Box", "2-Box" and "3-Box" components are selected and replaced automatically.
This works for all components at the first level of the structures list.
For "Boxes" that are inside a group or components, this does not work anymore.
How to solve the problem ?
Sorry, I forgot to specify this detail. :mrgreen:
The objectives are more and more precise:
1 - The user clicks on the icon "Change the Handles", to replace all the handles present in all the furniture. ( We are almost there. )
2 - If the user no longer wishes to modify some handles, he must select the furniture that he no longer wishes to modify then click on the icon "Freezing the Handles".
( This action must rename the definition of all the handles present inside the selected furniture. )
Rename Definitions = Prevent the first code from acting on the handles.
How do you write this method?
Great thanks to both of you for your help.
See you.
David
* Nouveau !!!
TNTDAVID
PluginStore Author
PluginStore Author
Postby TIG » Fri Apr 28, 2017 1:09 pm
Code: Select all
instances = model.entities.grep(Sketchup::ComponentInstance).find_all{|e|
model.definitions.each{|d|
  next if d.image?
  next unless d.name =~ /^#{name}/
  d.instances.each{|e| instances << e }
Now you have an array 'instances' that match that name pattern.
To process different names have your method take an argument - e.g.
Code: Select all
def swapper(name=nil)
  return unless name
  ### 'name' is set when calling the method
  ### main code here
You then run the method as swapper("Box-1") or swapper("Box-2") etc...
Provided that you always swap by incrementing the name it works as the name.next turns "Box-1" into "Box-2" for the replacement etc...
To process just a selected instance's definition you use a context-menu that tests for ss.length==1 && ss[0].is_a?(Sketchup::ComponentInstance) ...
Then it runs some 'freezer' method code...
Code: Select all
name = "some_name_???" ### how is this to be set ?
defn = ss[0].definition ### selected instance
instances = defn.entities.grep(Sketchup::ComponentInstance).find_all{|e|
ds = []
instances.each{|e| ds << e.definition }
ds.uniq! ### all matching definitions
ds.each{|d| d.name = 'x' + d.name }
### or however you will rename each definition...
Global Moderator
Postby sdmitch » Sat Apr 29, 2017 2:57 pm
David
Following up on TIG's idea of collecting instances, I think this solves the problem of the embedded components.
Code: Select all
      @last ||= '1'; @next = @last.next; @next = '1' if @next == '4'
      last_name = "#{@last}-Box"; next_name = "#{@next}-Box"
      if @mod.definitions[last_name] && @mod.definitions[last_name].instances[0]
        unless cd
         cmp = File.join(Sketchup.find_support_file('plugins'),"TNT_ClickCuisine2/Components/#{next_name}.skp")
        @mod.definitions.find{|d|d.name==last_name}.instances.each{|ci|ci.definition=cd}
        @last = @next
      else
sdmitch
PluginStore Author
PluginStore Author
Postby TNTDAVID » Tue May 02, 2017 4:02 pm
I'm sorry to take so much time to answer you but I'm overworked.
First tests on the cubes, all seems to work wonderfully.
I will test your codes directly on Click-Cuisine 2 and post here an example of the revolutions that it will bring to my tool.
I do not know how to thank you because your help allows me to move forward as never before.
See you soon.
David
* Nouveau !!!
TNTDAVID
PluginStore Author
PluginStore Author
Postby TNTDAVID » Sat May 13, 2017 3:13 am
Hello, :enlight:
After some tests of your codes on Click-Cuisine 2, I noticed a small problem that I hope to solve with your help.
The change of component changes perfectly from 1 to 2 then to 3, except if one goes backwards.
Here is an example in image:
Same problem, if I close and I open the file because the script restarts to "1-Component".
How to work around the problem?
I think it is best to delete the error message, even though "1-Component" is not found.
You can download skp example below:
TESTE.skp
And below the rbz plugin:
TNT_Teste.rbz
David
* Nouveau !!!
TNTDAVID
PluginStore Author
PluginStore Author
Postby TIG » Sat May 13, 2017 2:19 pm
Without even looking at the code consider this...
The 'file's suffix is to change thus:
1 >>> 2
2 >>> 3
3 >>> 1
So you don't use 'next' to increment the suffix just a 'case'...
In 'pseudo' code...
case suffix
when '1'; suffix = '2'
when '2'; suffix = '3'
when '3'; suffix = '1'
end#case
Attach the suffix the the files' base names as you look through...
If you want to remember the last used 'suffix' then use @suffix in a module or @@suffix in a class.
Then the next time the tool is used the last used enduring variable is recalled...
OR if you are getting the current value from a DC each tim then you can skip the enduring variable route ?
Global Moderator
Postby TNTDAVID » Fri May 26, 2017 5:53 pm
Sorry TIG to come back so late, but this time I finally have time to devote myself fully to ruby. :enlight:
I would have to put "@@" into all the variables, but that is certainly not the solution you advise me. :mrgreen:
Here is the basic code written by Sdmitch, which is almost perfect:
Code: Select all
def handles
      @last3 ||= '1'
      @next = @last3.next
      @next = '1' if @next == '19'
      last3_name = "#{@last3}-HANDLE"
     next_name = "#{@next}-HANDLE"
      if @mod.definitions[last3_name] && @mod.definitions[last3_name].instances[0]
      unless cd
      @mod.definitions.find{|d|d.name==last3_name}.instances.each{|ci|ci.definition=cd}
      @last3 = @next
      else
      UI.messagebox "#{last3_name} not found."
Before exploring your idea TIG:
Can your solution manage multiple SKP files or the status of the handles are different for each file?
For example :
My Project 1 has been saved with the definition in "9-HANDLE".
If I open this file the code must look for the definition "9-HANDLE", to replace it with "10-HANDLE".
My Project 2 is saved in "4-HANDLE".
If I open this file the code should look for the definition "4-HANDLE", to replace it with "5-HANDLE".
Another example:
If I go back with Sketchup, the code that is "4-HANDLE" will return to the "3-HANDLE" state.
If your idea fulfills all these conditions can you write an example?
Another idea would be to replace all the definitions that are called "Handle" in their definitions.
For example:
"1-Handle", "2-Handle" or "3-Handle" etc ...
Are replaced because they contain the name "Handle" in their definitions.
Is this easier to apply?
If so, how will you change the code?
David
* Nouveau !!!
TNTDAVID
PluginStore Author
PluginStore Author
Postby TNTDAVID » Mon May 29, 2017 3:30 pm
Hello,
To replace several definitions with the "next name" definition, I tried this:
Code: Select all
def handles
      @last3 ||= '1'
      @next = @last3.next
      last3_name = ['1-HANDLE','2-HANDLE','3-HANDLE']
      unless cd
      {next_name}.skp")
      @last3 = @next
      else
But the code does not work for a list of definitions between these brackets "[]".
How to replace a list of definitions with the definition "next name" ?
Any help would be of great help to me.
Cordially
David
* Nouveau !!!
TNTDAVID
PluginStore Author
PluginStore Author
Postby TNTDAVID » Mon May 29, 2017 5:33 pm
There is news :enlight:
As my code is in a class, I tried to apply the advises of TIG, put in "@@".
Now "@@ next" continues to evolve from 1 to 19, even if the definition that needs to be replaced is not found.
Even if the situation is better than before, it is not perfect because the code restarts to
"1-Handle" every time SketchUp runs.
If the handles on the stage are defined "5-Handle", you have to click 4 times on the icon to change the handle.
Code: Select all
def Handle
    @@mod = Sketchup.active_model
    @@ent = @@mod.active_entities
    @@avant ||= '1'
    @@next = @@avant.next
    @@next = '1' if @@next == '19'
    @@last1 = "#{@@avant}-HANDLE"
    @@next_name = "#{@@next}-HANDLE"
 if @@mod.definitions[@@last1]
    @@cd = @@mod.definitions[@@next_name]
    unless @@cd
    {@@next_name}.skp")
    @@cd = @@mod.definitions.load cmp
    @@mod.definitions.find{|d|d.name==@@last1}.instances.each{|ci|ci.definition=@@cd}
    @@avant = @@next
 else
    UI.messagebox "#{@@last1} not found."
* Nouveau !!!
TNTDAVID
PluginStore Author
PluginStore Author
Postby sdmitch » Mon May 29, 2017 9:46 pm
I would suggest using attributes to keep tract of "next".
@@avant = Sketchup.active_model.get_attribute("Handles","Last","1")
Sketchup.active_model.set_attribute("Handles","Last",@@next)
sdmitch
PluginStore Author
PluginStore Author
Postby TNTDAVID » Tue May 30, 2017 1:34 pm
Great Thanks sdmitch.
The general change of all the Handles furniture is finally perfect. ;-)
I will do the same for all the components of a kitchen, sink, taps, oven etc ...
Thanks to your help, "Click-Cuisine 2" will be even easier than ever.
A small remark without great consequence:
The current code does not replace the unique handles, such as "1-HANDLE # 1".
Is it possible to circumvent the problem, if so how?
The 2nd Great Steps is to replace the Handles of a single piece of furniture selected, without affecting other furniture.
How would you do that?
Any help from you is very good news to me. :-)
Thank you
David
* Nouveau !!!
TNTDAVID
PluginStore Author
PluginStore Author
Postby sdmitch » Tue May 30, 2017 3:22 pm
TNTDAVID wrote:The current code does not replace the unique handles, such as "1-HANDLE # 1".
Code: Select all
@@mod.definitions.find{|cd|cd.name=~/#{@@last1}?/i}.instances.each{|ci|ci.definition=@@cd}
This would be difficult indeed. The easiest way would be to move the single piece to a new model, make the changes then import it back.
David
sdmitch
PluginStore Author
PluginStore Author
Postby TNTDAVID » Tue May 30, 2017 4:26 pm
Thanks for your Sdmitch solution, but the definitions rendered unique "1-HANDLE # 1" still do not change.
Maybe I made a mistake somewhere?
Code: Select all
def poignee
    @@last1 = "#{@@avant}-POIGNEE"
    @@next_name = "#{@@next}-POIGNEE"
    unless @@cd
    {@@next_name}.skp")
    @@avant = @@next
    else
Perhaps it is more interesting not to reload the rendered unique models to find a solution to my 2nd Objective?
Here is a simpler idea for the 2nd Objective:
1 - I select a piece of furniture.
2 - I Click on the icon "Freeze the model". (The method that is executed makes all unique components and subcomponents of my selection.)
3 - I can execute the first code without changing the handles of the furniture made unique.
How to write this method?
Thanks in advance for your help.
* Nouveau !!!
TNTDAVID
PluginStore Author
PluginStore Author
Postby sdmitch » Tue May 30, 2017 6:22 pm
TNTDAVID wrote:[size=110]Thanks for your Sdmitch solution, but the definitions rendered unique "1-HANDLE # 1" still do not change.
Code: Select all
def poignee
    unless @@cd
    {@@next_name}.skp")
    @@avant = @@next
    else
I think you need to use the same @@mod.definitions.find when checking for existence also.
Code: Select all
if @@mod.definitions.find{|d|d.name=~/#{@@last1}?/}
   @@cd = @@mod.definitions.find{|d|d.name=~/#{@@next_name}?/}
   unless @@cd
      cmp = File.join(Sketchup.find_support_file('plugins'),"TNT_ClickCuisine2/Components/#{@@next_name}.skp")
   @@avant = @@next
else
sdmitch
PluginStore Author
PluginStore Author
Postby sdmitch » Wed May 31, 2017 1:04 am
TNTDAVID wrote:Here is a simpler idea for the 2nd Objective:
Thanks in advance for your help.[/size]
Could you post or PM me a sample model,version<=2016, that I could test.
sdmitch
PluginStore Author
PluginStore Author
Postby TNTDAVID » Wed May 31, 2017 4:01 am
sdmitch wrote:I think you need to use the same @@mod.definitions.find when checking for existence also.
It does not work yet. :shock:
For the code that makes it unique all of it is found. ;)
Here is the example of the updated cube:
TESTE 2.skp
TNT_Teste.rbz
1.Open the SKP file Teste 2.
2. Install the extension.
3.Click on the color icon. (All cubes will change texture.)
4.Click the cube icon. (This will reload the subcomponents.)
5. Select the middle cube and click on the padlock.
6. Click the cube icon again, you will see that the sub-components of the middle cube will no longer change.
7. Click on the color icon, the texture of the middle cube no longer changes. (Unfortunately this is not yet the case and I need your help to write this method.)
Thank you
David
* Nouveau !!!
TNTDAVID
PluginStore Author
PluginStore Author
Next
Return to Developers' Forum
cron
Users browsing this forum: No registered users and 5 guests
