- Code: Select all
# Foundation POSITIONING LOGIC (Polygon)
module FoundationPositionToolPolygon
# -------- FOUNDATION POSITIONING TOOL -----------------------------
# Positions the foundation assembly. This tool allows the user
# to place the foundation assembly using the mouse to select a polygon
class PositionToolPolygon
# Show the Ruby Console at startup so we can
# see any programming errors we may make.
# SKETCHUP_CONSOLE.show
# these are the states that a tool can be in
STATE_EDIT = 0 if not defined? STATE_EDIT
STATE_PICK = 1 if not defined? STATE_PICK
STATE_PICK_2 = 2 if not defined? STATE_PICK_2
STATE_PICK_3 = 3 if not defined? STATE_PICK_3
STATE_PICK_FINAL = 4 if not defined? STATE_PICK_FINAL
STATE_MOVING = 6 if not defined? STATE_MOVING
STATE_SELECT = 7 if not defined? STATE_SELECT
def initialize()
@tool_name = "FOUNDATION LOCATOR"
@type = "foundation"
@pointcount = 0
def reset
@pts = []
@state = STATE_PICK
@pointcount = 0
# This sets the label for the VCB
Sketchup::set_status_text "MEDEEK FOUNDATION", SB_VCB_LABEL
Sketchup::set_status_text "[#{@tool_name}] Click first corner of Polygon"
@status_text = "[#{@tool_name}] Click first corner of Polygon"
@drawn = false
def activate
@ip1 = Sketchup::InputPoint.new
@ip = Sketchup::InputPoint.new
self.reset
def deactivate(view)
view.invalidate if @drawn
@ip1 = nil
def onMouseMove(flags, x, y, view)
self.set_current_point(x, y, view)
Sketchup::set_status_text @status_text,SB_PROMPT
def onLButtonDown(flags, x, y, view)
self.update_state
def set_current_point(x, y, view)
if (!@ip.pick(view, x, y, @ip1))
return false
need_draw = true
# Set the tooltip that will be displayed
view.tooltip = @ip.tooltip
# Compute points
case @state
when STATE_PICK
@pts[0] = @ip.position
# need_draw = @ip.display? || @drawn
when STATE_PICK_2
@pts[1] = @ip.position
@sectionlength = @pts[0].distance @pts[1]
Sketchup::set_status_text @sectionlength.to_s, SB_VCB_VALUE
when STATE_PICK_3
@pts[2] = @ip.position
@sectionlength = @pts[1].distance @pts[2]
when STATE_PICK_FINAL
@pts[@pointcount] = @ip.position
@sectionlength = @pts[@lastpointcount].distance @pts[@pointcount]
view.invalidate if need_draw
def update_state
case @state
when STATE_PICK
@ip1.copy! @ip
@lastpointcount = @pointcount
@pointcount = @pointcount + 1
Sketchup::set_status_text "[#{@tool_name}] Click second corner of Polygon"
Sketchup::set_status_text "Section Length", SB_VCB_LABEL
Sketchup::set_status_text "", SB_VCB_VALUE
@state = STATE_PICK_2
puts "#{@state} #{@pointcount}"
@status_text = "[#{@tool_name}] Click second corner of Polygon"
when STATE_PICK_2
# @ip1.clear
@ip1.copy! @ip
Sketchup::set_status_text "[#{@tool_name}] Click third corner of Polygon"
@state = STATE_PICK_3
@status_text = "[#{@tool_name}] Click third corner of Polygon"
when STATE_PICK_3
# @ip1.clear
@ip1.copy! @ip
Sketchup::set_status_text "[#{@tool_name}] Click fourth corner of Polygon"
@state = STATE_PICK_FINAL
@status_text = "[#{@tool_name}] Click fourth corner of Polygon"
# @ip1.clear
@ip1.copy! @ip
ptcurrent = @ip.position
@distorigin = @pts[0].distance ptcurrent
if (@distorigin > 0.0001)
@nextpointcount = @pointcount + 1
Sketchup::set_status_text "[#{@tool_name}] Click corner #{@nextpointcount} of Polygon"
@status_text = "[#{@tool_name}] Click corner #{@nextpointcount} of Polygon"
else
# Final point picked, jump to calculation and exit tool to main program
self.calculate_obj
Sketchup.active_model.select_tool(nil)
def calculate_obj
# Check units of template again
lengthconstant = Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
if (lengthconstant == 0) || (lengthconstant == 1)
@Unitstemplate2 = "imperial"
else
@Unitstemplate2 = "metric"
if @Unitstemplate2 == "metric"
# Sketchup::set_status_text "Foundation Width: #{@BuildingSpan_m.round(4)} m - Foundation Length: #{@BuildingLength_m.round(4)} m"
else
# Sketchup::set_status_text "Foundation Width: #{@BuildingSpan_ft.round(4)} ft. - Foundation Length: #{@BuildingLength_ft.round(4)} ft."
# Back to main program
MedeekMethods.main_menu_polygon @pts, @pointcount
def onCancel(flag, view)
reset
def onUserText(text, view)
# The user may type in something that we can't parse as a length
# so we set up some exception handling to trap that
begin
value = text.to_l
rescue
# Error parsing the text
UI.beep
value = nil
return if !value
case @state
when STATE_PICK_2
# update the section length
vec = @pts[1] - @pts[0]
if( vec.length > 0.0 )
vec.length = value
@pts[1] = @pts[0].offset(vec)
# view.invalidate
self.update_state
when STATE_PICK_3
vec = @pts[2] - @pts[1]
vec.length = value
@pts[2] = @pts[1].offset(vec)
# view.invalidate
self.update_state
vec = @pts[@pointcount] - @pts[@lastpointcount]
vec.length = value
@pts[@pointcount] = @pts[@lastpointcount].offset(vec)
# view.invalidate
self.update_state
def getExtents
bb = Geom::BoundingBox.new
case @state
when STATE_PICK
# We are getting the first point
if( @ip.valid? && @ip.display? )
bb.add @ip.position
when STATE_PICK_2
bb.add @pts[0]
bb.add @pts[1]
when STATE_PICK_3
bb.add @pts[2]
bb.add @pts
return bb
def onKeyDown(key, rpt, flags, view)
if( key == CONSTRAIN_MODIFIER_KEY && rpt == 1 )
@shift_down_time = Time.now
# if we already have an inference lock, then unlock it
if( view.inference_locked? )
view.lock_inference
elsif( @state == 0 )
view.lock_inference @ip
elsif( @state == 1 )
view.lock_inference @ip, @ip1
elsif( @state == 2 )
elsif( @state == 3 )
elsif( @state == 4 )
def onKeyUp(key, rpt, flags, view)
view.inference_locked? &&
(Time.now - @shift_down_time) > 0.5 )
view.lock_inference
# draw a polygon for the outline of the foundation
def draw(view)
@drawn = false
# Show the current input point
@ip.draw(view)
@drawn = true
case @state
when STATE_PICK
# do nothing
when STATE_PICK_2
# just draw a line from the start to the end point
view.set_color_from_line(@ip1, @ip)
# view.drawing_color = [0, 0, 200]
inference_locked = view.inference_locked?
view.line_width = 2 if inference_locked
view.line_width = 2
view.draw(GL_LINE_STRIP, @pts[0], @pts[1])
@drawn = true
when STATE_PICK_3
view.line_width = 2
# view.draw(GL_LINE_STRIP, @ip1, @ip)
view.draw(GL_LINE_STRIP, @pts)
@drawn = true
else
view.line_width = 2
@drawn = true
end # class PositionToolPolygon
end # module FoundationPositionToolPolygon
Polygon Positioning Tool
• Page 1 of 1
Polygon Positioning ToolI've got the polygon positioning tool mostly worked out for my foundation plugin. However, when the user enters in a value for the length of the segment (VCB_VALUE) then the subsequent line selection does not properly infer the X and Y axis. I've spent already way too much time on this and I can't figure it out. My code is shown below for the polygon positioning tool:
Re: Polygon Positioning ToolJust an FYI, the posted code's improper indentation is so annoying I will not bother to read nor try it out.
Re: Polygon Positioning ToolI agree, the indentation is killing me. Trust me it doesn't actually look like this, when I cut and past it into the text box it completely mucks it up.
There are two problems as I see it. 1. You are using @ip1 and @ip to set the line color but, when you enter a length, @ip1 is no longer valid since the point it represents has changed. I think you should use the last to values of the @pts array to set the color. 2. Expecting the user to get within 0.0001 of the first point to close is way to restrictive.
Re: Polygon Positioning ToolI replace the set color line with:
view.set_color_from_line(@pts[@lastpointcount], @pts[@pointcount]) however the behavior is identical. I agree the .0001 is probably too restrictive. What I should probably do is insert a temporary guide point (add_cpoint) and then delete it once I jump back to my main program out of the tool or as the tool terminates. This way the user has something to snap to in order to close out the polygon.
I too find it odd that entering a length suddenly causes the axis inference to change its' behavior. The tooltip seems to think that @ip1 is still valid while, if you zoom in and move the mouse very slowly, the correct inference will occur. After that everything is back to normal until the next length entry. Very strange indeed and an obvious bug in Sketchup.
Re: Polygon Positioning ToolYes it is strange. If you enter a value then the next line won't infer the axis, but if you then click the mouse and begin another line the inference returns to normal. The whole tool thing is still somewhat of a black box to me so I don't really understand it fully but this certainly has me confounded.
Re: Polygon Positioning ToolNat, use 2 space characters for indents. Tabs will not come out well in the forum code blocks.
Re: Polygon Positioning ToolI've been using tabs for indents since 1999, getting me to change now is not easy. You can probably tell that I like a lot of whitespace in my code, easier to read.
Re: Polygon Positioning ToolThat is okay (whitespace). I use Notepad++ which automatically replaces TAB with spaces. Each language can have a different indent spacing. (I'd think most editors can [or should] do this.)
Re: Polygon Positioning ToolI totally agree. I use Notepad++ as well and I do not use tabs.
The main reason is everyone can set their tabs differently - but spaces are spaces so the reader gets to see what you want them to see.
Re: Polygon Positioning ToolI tried Notepad++ a couple years ago but something about it perturbed me so I went back to my basic Windows Notepad, I may revisit it.
How do you know what encoding it saves the file it ? How do you know what type of line ending characters it uses ? These are things easily set with a real code editor. In addition code editors use color lexing to help you spell keywords correctly, match up the begins and ends of code blocks, etc. They also can use autocomplete features to help fillout method calls.
• Page 1 of 1
Who is online
Users browsing this forum: lucytaetae and 10 guests
