Component that can not be made unique
Postby sdmitch » Tue Apr 04, 2017 2:27 am
Is there any reason that a component created by a plugin can not be made unique?
I've tried using a group and .to_component as well as creating the definition.entites. In both cases, when the component is added to the model, the 'Make Unique' option is grayed out. If I copy the instance, the copy can be made unique while the original still can not be.
I guess the answer is to hide an instance in the model so additional copies can be placed made unique and modified
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Re: Component that can not be made unique
Postby Box » Tue Apr 04, 2017 3:03 am
Check when you have made a copy, can you make the original unique if you haven't made the copy unique.
I think you may be simply running into the logic problem of there needs to be something to make your component unique from, if there is only one it already is unique.
Postby sdmitch » Tue Apr 04, 2017 3:09 pm
It makes perfect sense I guess that, if you only have one instance of a component in the model it is already 'unique'. What I was trying to do is create a basic component in the model then place and modify copies of that component without effecting the original. Placing and hiding a copy solves the 'logic problem'.
sdmitch
PluginStore Author
PluginStore Author
Postby slbaumgartner » Tue Apr 04, 2017 3:39 pm
If you want each copy to be unique, why not use Groups? The Group#copy method automatically clones the associated ComponentDefinition and hooks the new copy to the new clone. That is, each copy is "unique" right from the start.
slbaumgartner
PluginStore Author
PluginStore Author
Return to Developers' Forum
Users browsing this forum: No registered users and 12 guests
