I am working on the foundation plugin, in particular slabs and slab on grade foundations. I am creating a tool that allows the user to generate a polygon shaped slab, see below:
Currently the rebar or mesh is created so that it extends to the full extent of the bounding box of the slab. I would like to use the boolean subtraction that is built into SketchUp to trim the reinforcement so that it is properly contained within the slab however this feature is only available in the Pro version.
The intersect_with method is probably the next best thing but it seems like it will be quite a bit more complicated to subtract out the rebar that is external to the slab, especially where the rebar is cut in multiple locations.
I am exploring any and all options.
Boolean Subtraction or ???
• Page 1 of 1
Re: Boolean Subtraction or ???You might want to check out 2DBoolean by Joel G. Just the thing for this operation.
I am both an early bird and a night owl, I am some form of permanently energized dragon.
Re: Boolean Subtraction or ???Edge tool 2 split faces tool can also give you some clues.
I thought so to at a first glance. But then I looked closer at the Picture and it does look like the metal-net is inside the volume meaning a 3D boolean is needed. 2D-boolean plugin only have algorithms for working with planar (face) intersections. I don't think you have any other alternatives then winding up your own intersection formula using Groups and sorting out geometry if you are not going to use PRO version boolean.
Re: Boolean Subtraction or ???One option is to detect whether the user has Pro or Make. If Make - then skip the rebar. If Pro then use the available boolean functions.
What should the distance be from the end of the rebar to edge of the slab?
50mm or 2 inch Re: Boolean Subtraction or ???I have sent you a PM with a code snippet.
select the face of the slab and run the code and you will have construction points offset by 50 mm. Adjust the code to fit your needs.
Re: Boolean Subtraction or ???Not that difficult.
Re: Boolean Subtraction or ???@Sdmitch: I'm testing your Subtract tool you sent me a while back and it almost works! However when the subtraction breaks the solid group into more than one physical solid then the process seems to break down slightly.
In a nutshell I need to be able to do this sort of thing: Where I am subtracting the odd shaped polygonic solid from the cylinder. This last week has been challenging working on the polygon tool for the foundation plugin, I've made some real progress, thanks in a large degree to the continual help and encouragement from Sdmitch, Garry K, TIG and Facer. I'll readily admit my actual SketchUp programming skills are very weak whereas my ideas are very big, it sometimes amazes me I've gotten as far as I have with these two plugins. The fact that I am able to lean on others for some help on occasion has made all the difference.
Yes, I see where it would since it the opposite of what you are trying to accomplish with the slab and rebars. I will PM you the interactive tool version of the plugin I demonstrated in my previous post.
Re: Boolean Subtraction or ???I'm still digging through the code you sent me. It may take a week but I will attempt to figure out how this actually works. Its amazing how much you are able to compress into such a small body of code.
• Page 1 of 1
Users browsing this forum: SAMISAMO123 and 22 guests
