Dynamic Component DCFunctionsV1 within in Module
Postby michaelwhksg » Sun Mar 19, 2017 4:47 am
Hi I am a newbie to ruby. Can we place the DCFunctionsV1 within Module?
I am unable to get the customized formula in the dynamic component.
Please kindly advise.
Thanks.
Code: Select all
# add_funcs.rb
require 'sketchup'
module M123
module M123abc
# Open SketchUp's Dynamic Component Functions (V1) class.
class M123::M123abc::DCFunctionsV1
  protected
  # provide access to Ruby's arctangent method
  # Usage:  atan2(y,x)
  def atan2(a)
    return Math::atan2(a[0].to_f, a[1].to_f).radians
User avatar
michaelwhksg
Re: Dynamic Component DCFunctionsV1 within in Module
Postby slbaumgartner » Sun Mar 19, 2017 9:11 pm
Two thoughts:
First, the code you show isn't modifying SU's DCFunctionsV1, it is creating a new class of that name within the M123::M123abc module namespace.
Second, what makes you think that just defining atan2 within the DCFunctionsV1 class will make that formula available for use in DC's? That assumes a lot about how the DC class is programmed (which isn't documented).
slbaumgartner
PluginStore Author
PluginStore Author
Postby TIG » Sun Mar 19, 2017 10:04 pm
This code will work outside of your own module.
Code: Select all
# add_funcs.rb
# extends DCs functions
require('sketchup')
if Sketchup.version.to_i <= 8
  require('dynamiccomponents.rb')
else
  require('su_dynamiccomponents.rb')
if defined?($dc_observers)
  # only if DC extension is active
  class DCFunctionsV1
    protected
    unless DCFunctionsV1.method_defined?(:atan2)
      # access to Ruby's arctangent method
      # Usage: =atan2(y,x)
      def atan2(a)
        return Math::atan2(a[0],a[1]).radians
    end#unless
    protected:atan2
  end#class
end#if
User avatar
Global Moderator
Postby michaelwhksg » Mon Mar 20, 2017 7:06 am
Thanks a lot for the advice, slbaumgartner and TIG. :) Will try the codes later.
Another question, if you don't mind. Assuming we do not confine the entire code within it's own namespace (module), will there be a chance that name of the customised formula clashes with someone's else?
If we have created another unique formula for the dynamic component, for example, def qwer(a) and qwer(a)=a[0]+a[1]+a[2]. Is there any way from preventing others from using the same name as qwer(a)?
Thanks.
User avatar
michaelwhksg
Postby TIG » Mon Mar 20, 2017 12:05 pm
Yes you should keep your own code within your own modules.
The example I gave is adding methods into SketchUp's DCFunctionsV1 class directly.
I did that to show how to construct the new method etc...
You could do it within your module with suitable extends etc:
search.php?keywords=extend+class&fid%5B0%5D=180
with refine:
viewtopic.php?p=573770#p573770
etc
BUT I'm unsure that DCFunctionsV1 will respect those added methods outside of your code - i.e. with DC code...
Test it and see...
DCFunctionsV1.instance_methods.sort
User avatar
Global Moderator
Postby michaelwhksg » Sat Mar 25, 2017 11:52 pm
Hi TIG, I have been trying for a few days with DCFunctionsV1.instance_methods.sort.
However, it does not really work.
Are you able to help enlighten me further?
User avatar
michaelwhksg
Postby TIG » Mon Mar 27, 2017 3:01 pm
Using
in the Ruby Console simply returns a list of all of the methods available.
If you have added your own method it will also be listed there.
The example I gave for adding 'atan2' will work if you then used it as directed in your DC code...
User avatar
Global Moderator
Postby michaelwhksg » Tue Mar 28, 2017 3:22 am
If i am using the code which you have shared, and keying DCFunctionsV1.instance_methods.sort in the Ruby Console, I do see atan2 appearing in the console.
However, if I tried inserting the DCFunctionsV1.instance_methods.sort into the code, an error message appeared.
Below is the code which I have tried...
Code: Select all
# add_funcs.rb
require('sketchup')
module ABC
module ABC123
else
  class DCFunctionsV1.instance_methods.sort #(did I do this correctly?)
    protected
      def atan2(a)
    end#unless
    protected:atan2
  end#class
end#if
end #module ABC123
end #module ABC
This generated an error message.
"Error Loading File arctan-test2.rb
Error: #<SyntaxError: C:/Users/wongh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/arctan-test2.rb:16: syntax error, unexpected '\n', expecting :: or '[' or '.'
C:/Users/wongh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/arctan-test2.rb:30: syntax error, unexpected keyword_end, expecting end-of-input
end #module ABC
Is there anything I have done wrongly?
User avatar
michaelwhksg
Postby TIG » Tue Mar 28, 2017 11:08 am
You have misunderstood the purpose of the ...methods.sort snippet.
It is for use in the Ruby Console - pasted manually - so that you can see what's available.
The main code that defines the new function should NOT have that added into it !
As you have found it breaks it !
You have a script creating the atan2 function.
Do not do anything more to that.
Do not place it within your own name spaces [for now at least].
Use it as my example...
Use it to add the extra function directly into the DC code.
In the DC you then use: =atan2(y,x)
as the function...
User avatar
Global Moderator
Postby michaelwhksg » Wed Mar 29, 2017 6:56 am
Understood your message, TIG.
Does this mean that at this point in time, we are unable to introduce a new function in our name spaces?
User avatar
michaelwhksg
Postby TIG » Wed Mar 29, 2017 1:17 pm
There are ways to use an existing class and add to it or 'refine' it etc within your own module[s].
But that will provide the new class/method when called within your module - but not outside of it.
Since the DC code is calling its class/method directly, then your own method-wrapped additions will not be seen by it.
Since you are only using this code for yourself [?] I see little wrong in adding directly to the DC class and then making your own separate code within your own module[s] to do other things.
The method I provided only adds the new method it it doesn't exist [for example some other code is adding it or in the future it's added to the main shipped class.
It is bad form to mess with shipped classes etc, but sometimes you must do it - e.g. this DC class methods are used directly in the DC functions...
User avatar
Global Moderator
Postby michaelwhksg » Wed Mar 29, 2017 11:56 pm
Thanks for the advice, TIG. Appreciate your input.
At this moment, I am using the code for myself. However, I am also looking at opportunity to release the dynamic components I have created into the Extension Store.
I have seen the recommendation that you have shared with others in the forum. One way of getting the DC component to be dependent on the plugin is to give the DC component a function defined in the code. The DC component will not work without the plugin.
How can we use the class DCFunctionV1 within the name space (our own module) so that it fulfills the requirement of a good practice of a plugin? This is the question I am trying to get around. Any recommendation on this?
User avatar
michaelwhksg
Postby TIG » Thu Mar 30, 2017 11:44 am
I don't think you can do it wrapped inside your module.
It needs to add the function-method to the DC class directly, so that it's then seen by the DC function calling that class.
If you define it within your module it's your module's class and will not be seen.
Even if you 'refine' it or use it in other ways it's new methods are only seen in your class.
You need to change the DC class directly !
Changing a shipped class might get you into a mess on the EWH.
You could of course sell it separately...
User avatar
Global Moderator
Postby michaelwhksg » Sat Apr 01, 2017 10:01 am
Since we are unable to wrap the class DCFunctionsV1 in the name space, if we just submit the script with 2 parts, one of which is the DCFunctionsV1 and letting the formula be defined as my own unique name, and the second part which is wrapped within my name space, will this work? Will EWH team accept this?
For example,...
Code: Select all
# add_funcs.rb
require('sketchup')
else
  class DCFunctionsV1
    protected
    unless DCFunctionsV1.method_defined?(:XXXXXX)
      # Usage: =ABC123
      def (we give this definition a unique name)
        return XXXXXX (my own unique formula)
    end#unless
    protected:ABC123
  end#class
end#if
module ABC
module ABC123
codes to be in the name space
end #ABC123
end #ABC
User avatar
michaelwhksg
Postby TIG » Sat Apr 01, 2017 2:03 pm
Can you please format your code using the 'code' tags and indent it.
It's very hard to read as it is...
Your example is still changing the shipped class, so it will probably fail EWH checking...
You can but submit it, and wait and see.
You do not need the convolutions you added - they do nothing to a DC and still change the shipped class.
I can see no way you can do this and distribute it via the EWH, unless they agree to your class additions which technically break their strict rules...
User avatar
Global Moderator
Postby michaelwhksg » Mon Apr 03, 2017 3:57 am
Hi TIG. Sorry, will use the "code" tags in future.
Will try to submit once I have cleaned up the code.
Fingers crossed, but I have a feeling that you are right. It might get rejected.
It will be a pity though, because I believe there are many members who are able to build up the dynamic components (which can speed up and simplify the entire modelling process), but there's no way to prevent the DC from being distributed without the authors' agreement.
User avatar
michaelwhksg
Postby Dan Rathbun » Tue Apr 04, 2017 1:04 am
michaelwhksg wrote:Hi TIG. Sorry, will use the "code" tags in future.
(1) A better idea is to edit your previous post, and insert the code tags.
(2) The example is STILL wrong in that the check for method definition still uses the name atan2.
(3) Yes, please use a unique method name, as your implementation of the atan2 method (specifically the parameter list) is not how the rest of the world would define it for use by ALL coders.
    I'm not here much anymore. But a PM will fire email notifications.
    User avatar
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby michaelwhksg » Wed Apr 05, 2017 6:33 am
    Hi Dan,
    Thanks for the feedback.
    1. Have already edited the previous posts with the code tags.
    2. Have changed the example slightly (removal of the name atan2).
    3. Will use my unique name for the formula in the DCFunctionsV1 class.
    Will try to submit the extension after I clean up my code.
    Thanks.
    User avatar
    michaelwhksg
    Postby michaelwhksg » Sat May 06, 2017 12:52 am
    Hi TIG, Dan,
    Is there any resources online that shows how we can input the licensing code to our script? The below web link automatically directed me to another webpage instead of the licensing tutorial.
    http://www.sketchup.com/intl/en/develop ... _licensing
    User avatar
    michaelwhksg
    Postby Dan Rathbun » Mon May 15, 2017 8:36 pm
    The licensing tutorial was removed pending an overhaul. No amount of asking has resulted in any estimation of when the tutorial will be edited and reposted.
    Julia Christina Eneroth has posted her own licensing tutorial with test code at GitHub:
    https://github.com/Eneroth3/Sketchup-Api-Licensing-Test
      User avatar
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby Dan Rathbun » Mon May 15, 2017 8:39 pm
      There is a problem with licensing. You will likely NOT pass the extension review if you alter the DCFunctionsV1 class in your extension code.
        User avatar
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Postby TIG » Mon May 15, 2017 10:42 pm
        This has been discussed in a circle !
        I said earlier that any code which was altering a 'built-in' class [like the DC's] was like to fall foul of the EW checkers, and of course [thereby] its licensing regime...
        It would be possible to write a 'non-compliant' extension which did change the DC's class and publish it BUT it can't be downloaded through the EW [there are many other options] - and if it's to be licensed it'll have to be done through another licensing system [again there are several others]...
        It is somewhat perverse that SketchUp freely distributes its DC tools, but then does not allow any additions to be made to that code - even with the strictest trapping to avoid overwriting new methods or clashing with other authors - it seems to make the DCs something of an evolutionary dead-end...
        User avatar
        Global Moderator
        Postby Dan Rathbun » Fri May 19, 2017 9:22 pm
        (TIG, I know you said this, but apparently the OP didn't understand it well.)
        I would prefer that Trimble updates the DC code to add all those missing math functions that Scott did not implement, (... perhaps because Google Docs Spreadsheets did not support them at that time ?)
        And then I'd like them to be serious about implementing nifty new DC Functions that users request, in a timely manner !
          User avatar
          Dan Rathbun
          PluginStore Author
          PluginStore Author
          Postby michaelwhksg » Sun May 21, 2017 10:16 pm
          Thanks, Dan. Will take a look at Julia's tutorial.
          I do agree that some improvements can be made to the DC functionalities. This will definitely benefit a lot of users.
          User avatar
          michaelwhksg
          Postby michaelwhksg » Wed Jun 07, 2017 6:06 am
          Just an update to everyone.
          After a few rounds of re-submission of my extension to meet the stringent requirements, this time, it is taking slightly longer than usual. I am still waiting for the status of being published in the Extended Warehouse.
          In any case, below are some of the screenshots I have created for the extension.
          User avatar
          michaelwhksg
          Postby michaelwhksg » Fri Jun 16, 2017 5:35 pm
          Hi, does anyone know how long it takes to get an extension approved by the Extension Warehouse Team normally?
          After a few rounds of back and forth and updating the extension, I submitted the extension again on 29May. Aside from getting the one auto-response, I did not hear anything else.
          I then resubmitted again on 13June. Still no change in the status.
          Any advice on this?
          User avatar
          michaelwhksg
          Postby Dan Rathbun » Fri Jun 16, 2017 10:57 pm
          They have been known to be slow. Perhaps it's the summer vacation season ?
            User avatar
            Dan Rathbun
            PluginStore Author
            PluginStore Author
            Postby michaelwhksg » Sat Jun 17, 2017 1:01 am
            Oh I see. Thanks a lot Dan. Will wait for the feedback from them then.
            User avatar
            michaelwhksg
            Postby michaelwhksg » Fri Jun 23, 2017 12:39 am
            Hi TIG and Dan, good news. My extension is being approved by the EWH team and the trial version is now in the Extension Store.
            http://extensions.sketchup.com/en/content/extension-warehouse-dynamic-components
            Like you mentioned previously, the EWH team initially rejected the idea of having the DCFunctionsV1 approach. After I explained the rationale of using it, they finally gave the approval.
            Seems like there's light at the end of the tunnel.
            Thanks.
            My next challenge will be the licensing issue.
            I went thru Julia Christina Eneroth's tutorial, but still have some questions. For example, in the code, ext_id = "15dfa30f-4957-4549-8cdb-e97b5727a13a", I am unsure how this comes about.
            Anyway, one way I circumvent this is to have the trial version in the Extension Store and the full version in my website (still fixing up the shopping cart in my website though).
            Thank for the guidance. You guys rock!
            User avatar
            michaelwhksg
            Postby TIG » Fri Jun 23, 2017 1:09 am
            A miracle for common-sense - well done !
            User avatar
            Global Moderator
            by Ad Machine » 5 minutes ago
            Ad Machine
            Robot
            Next
            Return to Developers' Forum
            cron
            Who is online
            Visit our sponsors:
