Ruby selection
Ruby selection
Postby yalhassanpro » Wed Mar 08, 2017 9:33 am
Hello forum,
I have a model which consists of faces and unconnected lines. How do I select the lines only using Ruby? I have attached an image file.
yalhassanpro
Re: Ruby selection
Postby TIG » Wed Mar 08, 2017 1:04 pm
First we set up some references.
model = Sketchup.active_model
ss = model.selection
Then depending on how you want to 'start' off your plugin...
edges = model.active_entities.grep(Sketchup::Edge)
An array of all edges in the active context***
OR
edges = ss.grep(Sketchup::Edge)
An array of all edges in the current selection.***
Now resolve the selection:
ss.clear
ss.add(edges)
***The 'rep' finds all edges, including those bordering faces.
So if you want to select just those edges without faces then you can extend the 'grep' code thus
... .grep(Sketchup::Edge).find_all{|e| e.faces.length == 0 }
The array 'edges' then just lists those edges without faces...
Global Moderator
Return to Developers' Forum
Users browsing this forum: charlest63, lucasmassola and 8 guests
