Subtraction with Intersect Method
Postby medeek » Wed Mar 08, 2017 12:07 am
Has anyone ever tried using the intersect method to perform boolean subtraction of two solids?
http://ruby.sketchup.com/Sketchup/Compo ... nce_method
I really need to do boolean subtraction on some new modules I'm working on but I want to make sure I'm compatible with SketchUp Make and not force the user to go to Pro if I don't have to.
Nathaniel P. Wilkerson PE
Medeek Engineering Inc
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: Subtraction with Intersect Method
Postby Dan Rathbun » Wed Mar 08, 2017 9:05 pm
All Solid Tools boolean API methods are Pro only. (This used to be indicated in the docs.)
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby medeek » Fri Mar 10, 2017 2:54 am
    I have to intersecting cubes in my model. I then run this ruby code:
    Code: Select all
    group1 = entities[0]
    group2 = entities[1]
    trans1 = group1.transformation
    trans2 = group2.transformation
    group1.intersect_with(false, trans2, group1, trans1, false, group2)
    Which then gives the following error:
    Code: Select all
    Error: #<NoMethodError: undefined method `intersect_with' for #<Sketchup::Group:0x0000000dd92350>>
    <main>:in `<main>'
    SketchUp:1:in `eval'
    design.medeek.com
    medeek
    PluginStore Author
    PluginStore Author
    Postby sdmitch » Fri Mar 10, 2017 1:54 pm
    medeek wrote:I have to intersecting cubes in my model. I then run this ruby code:
    Code: Select all
    Code: Select all
    <main>:in `<main>'
    .intersect_with needs the group.entities
    Code: Select all
    group1.entities.intersect_with(false, trans1, group1.entities, trans1, false, group2)
    http://sdmitch.blogspot.com/
    sdmitch
    PluginStore Author
    PluginStore Author
    Postby medeek » Fri Mar 10, 2017 4:13 pm
    Got it. Thank-you Sdmitch. As always your guidance with the syntax is impeccable. Even after a year I'm still feel like a bull in a china shop
    I'm still a bit of a ways away from a boolean subtraction but at least I have something to work with now.
    design.medeek.com
    medeek
    PluginStore Author
    PluginStore Author
    Return to Developers' Forum
    Users browsing this forum: WLucas and 4 guests
