Any way to install two copies of SU (same version)?  Topic is solved
Postby derei » Sun Dec 25, 2016 11:15 pm
I am wondering if is any way to (force?) install two copies of same sketchup version on a machine...
the reason would be to keep a light version for testing stuff (ruby, etc) and the other one to be the "usual" sketchup that has all the plugins and things that I am using for modelling.
I know that I can run different versions of SU on the same machine, but the reason why I want a second installation for the same SU would be speed - to avoid loading all the plugins that the "usual" version would load.
I would welcome other options too, like a way of starting SU without the plugins (to have a alternate location, from where I only load the tested plugin)...
Thanks.
DESIGNER AND ARTIST DEREI.UK
derei
Re: Any way to have installed two copies of SU (same version
Postby derei » Mon Dec 26, 2016 4:24 pm
Garry K wrote:You can do it with 2 plugin folders and 2 desktop shortcuts to 2 batch files.
Wow, this is a very tricky solution! I love it! Thank you very much Garry.
derei
Any way to have installed two copies of SU (same version)?
Postby Jim » Tue Dec 27, 2016 3:13 pm
I don't care for the idea of renaming the folder although it's probably fine.
First just set an environmental variable from the batch file, and use it in a Ruby script to select a plugins sub-folder to load from.
Second, SketchUp accepts a command line argument which is a Ruby script to run. It can be located anywhere. Search this forum for RubyStartup.
I have a GutHub repo with and example of portable plugins loading. https://github.com/jimfoltz/SketchUp-Po ... ins-Loader
Jim
Global Moderator
Postby Box » Tue Dec 27, 2016 3:18 pm
You could use 'sets' to easily turn off and on multiple plugins.
Postby Jim » Tue Dec 27, 2016 6:23 pm
There are also 2 settings available through the Sketchup module that may be of interest.
They are plugins_disabled and debug_mode.
http://ruby.sketchup.com/Sketchup.html
Jim
Global Moderator
Postby derei » Tue Dec 27, 2016 10:43 pm
Thank you very much to all of you! Great options, great ideas!
I tried some of them and until now the results are promising... but I still have a problem that is nasty actually:
I tried on SU2017 and when pointed to a directory without plugins it loaded only with the toolbars that it had from the built-in tools. But - and now starts to be messy - when I returned it to the folder where all my plugins are, I got a toolbar mess...
I believe a way to save the toolbar positions and restore them would be ideal, not only for my current situation, but also for Backup/Restore. We have the bundles in Extension Store, which saves a lot of time, but still arranging toolbars is left to the user (yes, this depends on resolution, available plugins, etc), but considering the same display resolution and the full set in the bundle, would speed-up the restore process.
derei
Postby Jim » Wed Dec 28, 2016 3:06 am
It may be possible to backup and restore the registry for various configurations in your batch file.
Export:
Code: Select all
reg export "HKCU\Software\Sketchup\SketchUp 2017" Sketchup_2017.reg
Import:
Code: Select all
reg import Sketchup_2017.reg
Jim
Global Moderator
Postby derei » Wed Dec 28, 2016 3:59 am
Thank you very much Jim!
In the meantime I solved it by myself starting from this old post: viewtopic.php?f=15&t=37990&hilit=toolbar+registry&start=30
derei
Postby Dan Rathbun » Thu Dec 29, 2016 4:30 pm
derei wrote:I am wondering if is any way to (force?) install two copies of same sketchup version on a machine...
The easiest way that I use is to create a new "Test" user account, and log onto that account for testing. This "Test" user then does not make changes to my normal user account. (SketchUp keeps a separate set of registry values, for each user, in each different user's registry hive.)
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby derei » Thu Dec 29, 2016 8:46 pm
    Dan Rathbun wrote:The easiest way that I use is to create a new "Test" user account, and log onto that account for testing. This "Test" user then does not make changes to my normal user account. (SketchUp keeps a separate set of registry values, for each user, in each different user's registry hive.)
    So, you say that SketchUp keeps totally separate settings for each system account? Nothing gets mixed-up (plugins, toolbars, settings) ?
    derei
    Re: Any way to install two copies of SU (same version)?
    Postby Dan Rathbun » Fri Dec 30, 2016 4:27 pm
    This is correct. SketchUp's settings are written to the currently loaded user (HKCU/Software) hive of the registry. So user "Jane"'s settings cannot affect user "Dick"'s settings.
    Try it.
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby derei » Fri Dec 30, 2016 6:38 pm
      Dan Rathbun wrote:This is correct. SketchUp's settings are written to the currently loaded user (HKCU/Software) hive of the registry. So user "Jane"'s settings cannot affect user "Dick"'s settings.
      Try it.
      I will try. Thank you.
      But just beware, even if Jane's settings can't affect Dick's, Dick can affect Jane's settings... because he's a dick... :mrgreen:
      derei
      Postby Dan Rathbun » Sat Dec 31, 2016 2:44 pm
      Hmmm,... you must have seen the movie (or the remake.)
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Postby tomot » Tue Mar 07, 2017 2:31 am
        If you are really serious about running another copy or another version of SU, without it interfering with the registry then you should consider virtualization a version of your SU software.
        https://my.vmware.com/web/vmware/downloads
        Example: I'm currently using SU 2015 as my main workhorse for daily work. Having found out that SU 2016 wont run many of my Ruby scripts. I created a virtual copy of SU 2016, also known as a Portable version, using vmware.
        Warning: this process should not be attempted without a good understanding of Windows and what virtualization is.
        Here is a short description of how I make a portable copy.
        1. I always have a fresh bootable install of Windoz only, on a new UBS3 HDD
        2. I install vmware and SketchUp on 1
        3, With vmware running I make a new Bootable copy of SketchUp
        Now I can run a portable version of SketchUp from my USB3 HDD or move that Portable to any other HDD
        If you are competent in using vmware you can make versions that allow you to add addons scripts to your portable version, this is very important.
        good luck!
        tomot
        PluginStore Author
        PluginStore Author
        Return to Developers' Forum
        Users browsing this forum: No registered users and 4 guests
