DAE for Sdmitch or other coders!
I see no problem
License type:Free/Make?
I believe its a Pro feature
At the start of the session I import the DAE file but...
I have this! Do you think it's because i have SketchUp Make and not the PRO ?
Same result with all possibilies of import DAE options!
Can you post your cube as DAE exported from your SketchUp ? -
I believe its a Pro featureI don't believe!
When I export objects from SU Make as DAE format
I can import them at any moment as DAE format!
Very mysterious! -
I believe its a Pro featureNo problem in SU2014 Free.
Can you post your own export DAE for see if i can reload it?
Curious I can reload it in 2015 but not in 2016!
Work in the 2015! (import the DAE)
Seems existing in the 2016 but I see it only on the Structure!
Not on the screen!
(saved as 2014)
Not on the screen!
(saved as 2014)The model seems to be empty but Model Statistics shows that there is 1 ComponentInstance.
Interesting but I haven't a clue as to why.
I make some "New" and sometimes that works, sometimes not! (in 2016)
In any case I have not more since your dae file the Message "Empty component")I believe the object is very tiny!
Maybe this explain that ? -
Maybe this explain that ?[attachment=0:l0jt4utq]<!-- ia0 -->very_tiny.jpg<!-- ia0 -->[/attachment:l0jt4utq]
Very possible.
Seems make some "New" and take a more scaled new object resolve this curious problem!
I had the error message (empy component) but after some "New"
that is working!
Maybe also general Axes Position/ Screen ?... -
To test if size is the problem, you can edit the .dae file and change line 99
<scale sid="scale">0.001 0.001 0.001</scale>
to
<scale sid="scale">1 1 1</scale>
I just test in take 1000 unities in the Start program : that makes 1 m inside SketchUp
And seems now working fine! -
And Yep with your code that works like a charm!
The mystery is why that works for you and Solo for the original and not for me!
Have you a secret resizing?
