by Dan Rathbun » Sat Mar 12, 2016 7:10 pm
Here is Marthmatica's example, cleaned up and properly namespace wrapped. (ref: viewtopic.php?f=180&t=23441&p=589250#p589171) Basically if you use it as a template, you replace the outermost namespace module name "Author" with your own toplevel namespace module name. (And you can also rename the plugin module to whatever you wish, as well.) I cannot test it currently as I have LibreOffice installed (instead of MS Office.)XLTiler_0_2_3.rb - Code: Select all
# encoding: UTF-8 # # Example SketchUp extension: Geometry creation from Excel worksheet data
require 'sketchup.rb' require 'win32ole'
module Author # outer Author namespace module module XLTiler # this particular plugin module
VERSION = '0.2.3'
EXCEL = 'Excel.Application'
@@loaded = false unless defined?(@@loaded)
class << self # anonymous singleton proxy class instance
def init() # @xl = nil # end ### init()
def connect_to_excel() # if @xl.nil? # Use WIN320LE.new to start a new spreadsheet instance. @xl = WIN32OLE::new(EXCEL) else # Connect to an already open spreadsheet application. # Use WIN320LE.connect to connect to an already open Excel instance. @xl = WIN32OLE::connect(EXCEL) end # @xl.visible = TRUE # rescue false end ### connect_to_excel()
def get_value(row,col) # @xl.activesheet.cells(row,col).value # end ### get_value()
def get_size( *size ) @rows = 24 if @rows.nil? # Rows are face count to create @cols = 12 if @cols.nil? # Columns have all 4 face points
# Note cols is the face pts x1,y1,z1; x2,y2,z2... 1 through 4 xyz points; or 12 cols # XL row 1= pt1: 1, 1, 0 pt2: 1, 2, 0 pt3: 2, 2, 0 pt4: 2, 1, 0 # XL row 2= pt1: 2, 1, 0 pt2: 2, 2, 0 pt3: 3, 2, 0 pt4: 3, 1, 0 # and so on...
if size.empty? # Use defaults rows = @rows # Rows are face count to create cols = @cols # Columns have all 4 face points # Now prompt user to change or confirm size: begin result = UI.inputbox(["Rows","Cols"],[rows,cols],"Matrix Size") rescue => e UI.messagebox(e.message) retry else rows, cols = result end else rows, cols = size end # return rows,cols # end ### get_size()
# Define the method that is activated from that added menu item click def get_xltiler()
unless connect_to_excel() UI.messagebox("Could not connect to Excel !") return end
# Instantiate tile matrix origin for Excel rows and columns reference. # We'll use a hash whose keys are the integer row numbers. The values # will be arrays consisting of #{cols} number of values. matrix = {}
# A return array of faces created: faces = []
# Set row and column count result = get_size() return if !result # false if user cancelled inputbox. @rows, @cols = result
# rows is how many face tiles you are creating in SketchUp, 1 face tile, per each row
# BUILD matrix # step through all the XL rows for r in 1..@rows # Each row is an array of #{cols} number of values matrix[r]= [] # In every row populate the matrix from Excel cell values: for c in 1..@cols matrix[r] << get_value(r,c) end # Advance loop to next row. end # THE MAIN FACE CREATING ROUTINE # stepping through rows, as how many tiles you are creating is total rows, # then stepping through cols to populate all 4 face pts per row # Get handles to our model and the Entities collection it contains. model = Sketchup.active_model act = model.active_entities group = act.add_group cpt = group.entities.add_cpoint( [0,0,0] ) # We add a cpoint to keep group from garbage collection ents = group.entities
pts = [] for r in 1..@rows row = matrix[r] pts.clear row.each_slice(3) {|ary| pts << Geom::Point3d::new(ary) } # Add new face per this row: ents.add_face( *pts ) # Advance loop to next row. end
cpt.erase! # no longer needed
@xl = nil # release Excel reference
return group # an group of the face objects created
end ### get_xltiler()
end # anonymous singleton proxy class instance
### RUN ONCE CODE # if !@@loaded
# Add a menu item to launch our plugin, # in its SketchUp menu default name target, # and the name we are giving our function in the "Tools" menu. UI.menu("Tools").add_item("Get XLTiler") { # UI.messagebox("Ye Excel! come up from hell!") get_xltiler() }
init()
@@loaded = true
end # this particular plugin module end # outer Author namespace module
I'm not here much anymore. But a PM will fire email notifications.
Dan Rathbun
- PluginStore Author
- Name: Dan Rathbun
- Operating system: Windows
- SketchUp version: 2015
- License type: Pro
- SketchUp use: education
- Level of SketchUp: Advanced
by Dan Rathbun » Thu Mar 31, 2016 9:45 am
Updated to v 0.2.1Changes to get_size() method: - Had neglected to assign good results from inputbox.
- Wrapped inputbox in begin...rescue to trap and retry input type errors.
Dan Rathbun
- Name: Dan Rathbun
- License type: Pro
by Dan Rathbun » Wed Apr 27, 2016 12:34 am
Updated to v 0.2.2Fixed get_size() method inputbox begin ... rescue block. - Added else clause, and moved rows,cols = results statement inside it. (Was attempting to reference results out of scope.)
Updated to v 0.2.3Fixed get_xltiler() method: - Fixed call to group.entities.add_cpoint( [0,0,0] )
(Argument was a list of 3 values. Need to be an Array or Geom::Point3d object.)
NOTE: There is a faces = [] statement that is unused in the get_xltiler() method. Originally I returned the created faces in an array, but realized they needed to be in a group to prevent unintended geometry interaction. And later,... forgot to remove the statement.
Dan Rathbun
- Name: Dan Rathbun
- License type: Pro
by picpic020960 » Thu Sep 01, 2016 9:07 am
Bonjour ,
verry intresting ! i test with excel and SU14 but when i click on tools/get xltiler after load the .rb file
, exel open and 'matrix size' window appear , and when click this issue ----------------------------------------------------- load 'c:\temp\XLTiler_0_2_3.rb' true Error: #<TypeError: no implicit conversion to float from nil> c:/temp/XLTiler_0_2_3.rb:128:in `initialize' c:/temp/XLTiler_0_2_3.rb:128:in `new' c:/temp/XLTiler_0_2_3.rb:128:in `block (2 levels) in get_xltiler' c:/temp/XLTiler_0_2_3.rb:128:in `each' c:/temp/XLTiler_0_2_3.rb:128:in `each_slice' c:/temp/XLTiler_0_2_3.rb:128:in `block in get_xltiler' c:/temp/XLTiler_0_2_3.rb:125:in `each' c:/temp/XLTiler_0_2_3.rb:125:in `get_xltiler' c:/temp/XLTiler_0_2_3.rb:154:in `block in <module:XLTiler>' -e:1:in `call' -------------------------------------------------------------- thanks for help or little tutorial with all step (excel and sketchup/ruby)
Regards
picpic020960
- Name: picpic020960
by picpic020960 » Thu Sep 01, 2016 12:19 pm
OK
works fine !
but only read data.
how to for write data to excel from ruby ?
other question :
exists 'macro' recorder as in Excel ?
thanks
picpic020960
by Dan Rathbun » Fri Sep 02, 2016 9:11 pm
picpic020960 wrote:how to for write data to excel from ruby ?
Try something simple like: - Code: Select all
def set_value(row,col,val) # @xl.activesheet.cells(row,col).value = val # end ### set_value()
picpic020960 wrote:other question :
[Do you know if there] exists 'macro' recorder as in Excel ?
Whatever exists in Excel, and has a built-in VisualBasic interface, can be accessed via WIN32OLE (from Ruby.) So, refer to the VisualBasic object model for Excel: MSDN: Object model (Excel VBA reference)
Dan Rathbun
- Name: Dan Rathbun
- License type: Pro
- Robot
Return to Developers' Forum
