[SOLVED]Reloading Component via DefinitionsList.load Problem
Postby TommyK » Thu Jan 08, 2015 5:13 pm
I have been having issues with DefinitionsList.load. I am trying to reload an external component that has been updated externally via Ruby.
I encounter the following behaviours:
Code: Select all
[ruby]model = Sketchup.active_model
# We have a single component in the model
old_definition = model.entities[0].definition
puts old_definition.path #=> '/HD/Users/User/cylinder.skp'
puts model.definitions.count #=> 1
# Note that the definition was saved to '/HD/Users/User/cylinder.skp', and
# the file was then edited independently
# Attempt to reload the component
new_definition = model.definitions.load '/HD/Users/User/cylinder.skp'
puts old_definition.guid #=> 1736b32a-8dd3-3040-bdfd-62a05e188985
puts new_definition.guid #=> 1736b32a-8dd3-3040-bdfd-62a05e188985
#  The same GUID! The file was NOT loaded, as it has been edited since.
# And a new (renamed) defninition was not added to the definitions list:
if new_definition == old_definition
  puts "The definitions are the same!  This shouldn't happen, no?"
# However, loading a new component that does not share a path with another component works:
second_new_definition = model.definitions.load '/HD/Users/User/cube.skp'
puts model.definitions.count #=>2
# Other things I have tried:
# - Renaming the old definition before load - same result:
old_definition.name= "new name"
puts new_definition.name #=> "new_name"[/ruby]
It seems that Sketchup refuses to reload a component from a path if there is a component with that path in the model already. This is driving me a bit mad.
...Or is it just me? Any suggestions for workarounds?
TommyK
PluginStore Author
PluginStore Author
Re: Reloading Component via DefinitionsList.load Problem
Postby TIG » Thu Jan 08, 2015 5:26 pm
Do a save_as on the current-component into a random-number-named SKP file in the user's Temp folder.
It's stored path in the original model's definitions is then changed.
Reload the externally changed component from its 'usual' external fixed-path, now it should overwrite in the model...
Delete the randomly number-named SKP file in the user's Temp folder, using File.delete(full_path)...
Global Moderator
Postby TommyK » Thu Jan 08, 2015 7:29 pm
TIG wrote:Do a save_as on the current-component into a random-number-named SKP file in the user's Temp folder.
I did think of this workaround as a worst case scenario. It troubles me because of the (wasted) CPU time required to write the new file. I have potentially tens of MB of Skp files I need to load at a time. If I have to save an equivalent size of file every time, then, it potentially doubles the amount of CPU time.
Another option is to rename the file to be loaded first, then change it back after the load, although in this case, the path the newly loaded component points to would then be wrong.
We could really do with a new API function I think: ComponentDefinition.path=
Any other suggestions would be welcome!
TommyK
PluginStore Author
PluginStore Author
Postby TIG » Thu Jan 08, 2015 8:11 pm
How about this alternative...
definition1.name >>> 'A'
definition1.name = definitions.unique_name(definition1.name) ### e.g. A#1
Now RE-load the component SKP ['A.skp'] and there is nothing in its way.
Let's assume it's referenced as 'defintion2'.
It should arrive named 'A'.
Now swap over definition1.instances.each{|i| i.definition = definition2 }
Next definition1.entities.clear!
If this whole operation is enclosed in a model.start_operation... model.commit_operation that now unused [an empty] 'definition1' [temporarily named as A#1] is automatically removed from the definitions-list...
:ugeek:
Global Moderator
Postby TommyK » Thu Jan 08, 2015 11:35 pm
TIG wrote:How about this alternative...
Unfortunately, the component doesn't arrive named 'A'. definitions.load path returns the existing definition if the path is identical.
I have tried this:
# Rename the component
old_definition.name = model.definitions.unique_name(old_definition.name)
puts "The definitions are the same! This shouldn't happen, no?" #=> ...but it does
It appears that the problem is not the clash of definition names when a definition is loaded, but the clash of paths between the new and old components. And you just can't change a definition path other than by loading it! Quite an omission in the API methinks.
In the meantime, my only other option is to temporarily rename the skp file from which the component is loaded using File.rename. It's messy, but it should work ok.
BTW - I am on Mac, Sketchup Pro 2015, and I experience this issue. I would be interested if this is the case on other platforms.
TommyK
PluginStore Author
PluginStore Author
Postby Jim » Fri Jan 09, 2015 1:05 am
Which is worse: CPU time or Disk I/O time?
You will need to do your own testing, but here's another possible work-around..
in Windows, save the definition as "nul" (or "\\Device\\Null"), and Mac as "/dev/null/"
These are special files that will not actually write to disk, but just throw away the data. But the definition path will be changed.
It's not exactly what you are asking for, but maybe better than creating double files on disk.
Jim
Global Moderator
Postby TommyK » Fri Jan 09, 2015 11:55 am
Jim wrote:Which is worse: CPU time or Disk I/O time?
Thank you for your suggestion, Jim. I have made the test as you suggested:
Code: Select all
definition = Sketchup.active_model.entities[0].definition
n = 50
Benchmark.bm do |x|
  x.report("save to nul ") { for i in 1..n; definition.save_as("/dev/null"); end }
  x.report("save to desk") { for i in 1..n; definition.save_as("/Volumes/.../Desktop/cubes.skp"); end }
                    user     system      total        real
save to /dev/null   7.770000   0.440000   8.210000 (  8.380249)
save to desktop     8.180000   0.630000   8.810000 ( 10.576788)
There is a marginal improvement. I imagine it would be a greater improvement if the save_as path was a network drive, so well worth noting.
Another lesson I learned in the process was understanding how fast the save_as method was. The component in the benchmark above was 3MB when saved. This works out at 0.055 seconds/MB on my Mac Pro (2008).
This contrasts markedly from the Definitions.load method, which guzzles a lot of CPU (it takes 6 times longer):
Code: Select all
n = 50
Benchmark.bm do |x|
  x.report("load/save") {
    for i in 1..n
      definition = model.definitions.load("/Volumes/Storage/Users/Tommy/Desktop/Component.skp")
  x.report("save to null ") { for i in 1..n; Sketchup.active_model.entities[0].definition.save_as("/dev/null"); end }
load/save      59.010000   2.180000  61.190000 ( 61.211738)
save to null   8.720000   0.440000   9.160000 (  9.310672)
So the way ahead is clear. Save to change the path, then load only once.
TommyK
PluginStore Author
PluginStore Author
Postby tt_su » Fri Jan 09, 2015 12:36 pm
Have you tried to "touch" the old definition first by making a small change like entities.add_cpoint(ORIGIN) then trying to load the new?
tt_su
SketchUp Team
SketchUp Team
Postby Jim » Fri Jan 09, 2015 10:28 pm
Hmm, if you add an empty Group instead of a CPoint it also works; and then you may need to worry less about cleaning up since the empty group will get swept away.
Jim
Global Moderator
Postby TommyK » Sun Jan 11, 2015 10:56 pm
tt_su wrote:Have you tried to "touch" the old definition first by making a small change like entities.add_cpoint(ORIGIN) then trying to load the new?
Yes, I did! And it works. Happy camper.
TommyK
PluginStore Author
PluginStore Author
Postby tt_su » Mon Jan 12, 2015 12:19 pm
Jim wrote:Hmm, if you add an empty Group instead of a CPoint it also works; and then you may need to worry less about cleaning up since the empty group will get swept away.
Good point. (No pun intended)
I'll file up the issue internally so we'll look into it.
tt_su
SketchUp Team
SketchUp Team
Re: [SOLVED]Reloading Component via DefinitionsList.load Pro
Postby masp » Tue Feb 05, 2019 4:31 am
This is a very useful thread: I'm trying to apply this workaround (add_cpoint) but I'm still getting an identical GUID. Would you mind posting the actual solution, so there's an explicit example I can refer to? For what it's worth, this is my attempt (I'm trying to automate re-loading certain components from their .skp files):
Code: Select all
    selection_set = model.selection
    selection = selection_set[0]
    definition = selection.definition
    definition.entities.add_cpoint(ORIGIN)   # not sure if I'm applying this to the correct entity
    new_definition = model.definitions.load(definition.path)
    puts "Old GUID: " + definition.guid
    puts "New GUID: " + new_definition.guid
I'm not sure if I'm applying add_cpoint() to the right entity; also I'm not sure whether creating an empty group is a better workaround as suggested in the thread, or how to do that!).
Finally, this is how I hope to replace the instances (based on someone else's example):
Code: Select all
      definition.instances.each { |instance|
        instance.parent.entities.add_instance(new_definition, instance.transformation)
        instance.erase!
Many thanks, and hugely appreciated!
Mike
masp
Postby TIG » Tue Feb 05, 2019 1:37 pm
Your first block of code changes the selected instance's definition's entities, by adding the cpoint.
At that point I'd also rename it e.g. definition.name=definition.name+rnd.to_s
This should then mean that a re-load of the original definition from the external SKP makes a new definition, auto-reusing its earlier name.
Next you need to swap out any existing instances of the original definition, to use the new definition...
definition.instances.each{|i|i.definition=new_definition}
Finally you can clear the entities of the original definition to remove it from the model's definitions list.
definition.entities.clear!
Note that you need to have all of this code inside a model.start_...commit_operation block for it to take immediate effect...
Global Moderator
Postby masp » Wed Feb 06, 2019 6:24 am
Thanks for the quick reply! I think I've done everything right, but I only get a new definition (loaded) when I use the write-to-dev-null trick (but it's painfully slow!). When I use the add_cpoint() or add_group() trick my SKP file is ignored and I get the same GUID back. Here's my full script, if you don't mind taking a look:
Code: Select all
require "sketchup.rb"
module RefreshComponent
  def self.force_reload_component_definition!(model, definition)
    definition_path = definition.path
    definition_name = definition.name
    definition.name = definition.name + rand.to_s
##    definition.entities.add_cpoint(ORIGIN)     ## <== this causes GUIDs to match (fail)
    definition.save_as("/dev/null")              ## <== this causes new definition load (success)
    reloaded_definition = model.definitions.load(definition_path)
    puts "New GUID: " + reloaded_definition.guid
    reloaded_definition
  def self.reconnect_component_instances!(model, old_definition, new_definition)
    model.start_operation("Remap instances")
    old_definition.instances.each { |instance| instance.definition = new_definition }
  def self.delete_component_definition!(model, definition)
    model.start_operation("Delete Definition")
    definition.entities.erase_entities(definition.entities.to_a)
  def self.refresh_component(model, definition)
    model.start_operation("Reload current component definition", true)
    reloaded_definition = force_reload_component_definition!(model, definition)
    reconnect_component_instances!(model, definition, reloaded_definition)
  def self.start
    model.start_operation("Reload component definitions from file", true)
    model
      .selection
      .select { |entity| entity.is_a?(Sketchup::ComponentInstance) }
      .map { |instance| instance.definition }
      .uniq
      .each { |definition| refresh_component(model, definition) }
unless file_loaded?("refresh_component.rb")
    UI.add_context_menu_handler do |context_menu|
      context_menu.add_item("Reload Current Component Definition") {
        RefreshComponent.start
   file_loaded("refresh_component.rb")
masp
Return to Developers' Forum
Users browsing this forum: drcustomwood and 6 guests
