[Plugin] SketchyFFD (Updated 20130203)
Re: [Plugin] SketchyFFD (Updated May 9 2008)
Postby REGIS » Tue Nov 18, 2008 8:39 am
It works fine now.
Thanks a lot.
cheers
REGIS
Postby Tobobo » Thu Nov 27, 2008 11:14 am
Chris,
I can't get it to work.
I an trying to bend the centre of the netting but when i move the control points there is no 'Update FFD' option on the right-click menu.
I've posted the model so you can have a look and tell what i'm doing wrong.
Thanks in advance.
Toby
Philippians 4:13
User avatar
Tobobo
Postby REGIS » Thu Nov 27, 2008 11:38 am
Hi Tobobo
It's due to the hidden geometry.
Look at this one, it's different with the hidden geometry, you can easilly deform it where you want.
Just create the group and choose your FFD setting.
curtain.skp
cheers
Edit
After some FFD
curtainFFDv6.skp
cheers
REGIS
Postby Tobobo » Thu Nov 27, 2008 12:05 pm
Thanks REGIS
I'll have to think of another way to deform the netting.
Toby
Philippians 4:13
User avatar
Tobobo
Postby REGIS » Thu Nov 27, 2008 12:34 pm
Perhaps ypu can subdvide it using subdivide=true when you create your FFD control box.
Cheers
REGIS
Postby SKELL » Wed Dec 10, 2008 2:59 pm
I am trying to take a simple rectangular solid and deform it. i have to sub divide the surface? how can i go about this?
Thanks,
-Tony
SKELL
Postby pilou » Wed Dec 10, 2008 4:53 pm
One possibility
Draw a rectangle
Pull it with Ctrl any time you want
Select all (triple click)
Move it one time + CTRL = Copy
Type "10*" (or more) = Multiple
Group it
Select group Right Click / FFD
Edit the goup "FFD"
Move points
Et voilà ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby michaelland » Mon Dec 15, 2008 4:07 am
Hi Chris, I've to say your work for this amazing RB is really great help for me! Thanks for your great job and sharing with us!!
Michael Xie
michaelland
Postby •BTM » Tue Dec 16, 2008 2:53 am
SKELL wrote:I am trying to take a simple rectangular solid and deform it. i have to sub divide the surface? how can i go about this?
Thanks,
-Tony
There's a subdivide feature in the script.right click> FFD> NxN> set subdivide to true.
•BTM
PluginStore Author
PluginStore Author
Postby pilou » Tue Dec 16, 2008 3:29 am
Yes but will be any effect on the subdivide of a simple rectangle!!!
Nothing will arrive when you will move a point of the FFD!
Seems the only easy methode is draw a rectangle with the Sandbox :)
Speedy Galerie
User avatar
Top SketchUcator
Postby jonorman » Tue Dec 30, 2008 1:06 am
Hi..
I think there might be a problem with FFD an ASGVIS V-ray for scetchup.. FFD did not work while i had V-ray installed but now that i have uninstalled V-ray FFD works fine again.. Same problem as with subdivide and smooth script..
can anyone else confirm this ?? Btw, FFD is a brilliant script. :thumb:
jonorman
Premium Member
Premium Member
Postby GJV » Tue Jan 06, 2009 11:33 pm
woooaaaa
amazing plugin
just what I needed
thanx a lot :D !!!!
GJV
Postby Dee256 » Mon Feb 16, 2009 2:31 pm
Works nice! But "transformations reset" needs sometimes before FFD starts.
Dee256
Postby ideas_arte » Tue May 12, 2009 12:20 am
.. thanks a million! :berserk: :berserk:
really useful too :thumb:
ideas_arte
Postby niarfe » Wed May 13, 2009 4:54 am
this looks like a wonderful ruby!!!
too bad it's not working for me, it doesn't do anything, and when I try undoing it beaks my geometry apart!
would have loved to use it :(
niarfe
Postby Chris Fullmer » Wed May 13, 2009 5:06 am
Its not over yet. If its not working, then its installed wrong or your using it wrong. Or you have version 4 of SU :)
Could you provide a better description of what its doing wrong? Perhaps screenshots, maybe a video. Just give us some more detail and we'll get it working for you.
User avatar
SketchUp Team
SketchUp Team
Postby sprezzaturon » Wed May 13, 2009 6:39 pm
I'm running Sketchup 7 and just added your FFD tool. I can move points but there is no 'update FFD' option when I'm finished. Is FFD not compatible with Sketchup 7?
sprezzaturon
Postby remus » Wed May 13, 2009 8:26 pm
The shape should update automatically, you might have to give it a bit of time, though.
If that doesnt work delete the control points, explode the group, regroup and try again.
remus
Postby sprezzaturon » Wed May 13, 2009 11:39 pm
After waiting on a 2.4 GHz dual core XP system, nothing changed. I've just installed FFD on my computer (2.1 GHz dual core) and created a circle so I could elongate one point. Nothing. This is disappointing.
sprezzaturon
Postby remus » Wed May 13, 2009 11:40 pm
Have you tried it on 3d geometry? i think it can work on 2d things, but ive never gotten the hang of it.
remus
Re: SketchyFFD (Free Form Deformation)
Postby hasan » Sun Aug 16, 2009 3:37 pm
CPhillips wrote:
Coen Naninck wrote:I can't get this script to work. Nothing happens.
I create a sphere, group it, right-click and do 3x3 FFD, enter the new group with Construction Points, move some to another position, exit the group, right-click the sphere group and choose Update FFD. Nothing happens.
Can you open the ruby console and see if it is printing any errors?
hasan
Postby steven-arts » Fri Aug 21, 2009 4:23 pm
Hi Chriss,
it really makes fun to work with FFD! I looked at your code and found the factorial function where you mentioned to encrease performance by adding a table for factorials. I made it dynamic and it boosts your code! Just replace the section with:
Code: Select all
#used by calcBernstein. could be replaced by a table since in
#this application n is never more than 3 (number of control points).
$fTable = []
def factorial(n)
    sum = $fTable.rassoc(n)
    if sum
       return sum[0]
    else
   sum = 1
   sum.upto(n) { |i| sum *= i }
   $fTable << [sum, n]
   return sum
Ciao, Stefan
steven-arts
Postby CPhillips » Mon Aug 24, 2009 8:10 pm
Thanks Stefan! Its a nice idea. I updated the plugin with an adaption of the code and applied it to the Bernstein Polynomial as well. It sped up the initial weighting of a big model from 75 seconds to 15 seconds.
I also figured out a way (in theory) to speed up the actual deformation by like 50x. The only problem is I would have to handle moving the control points without using any of Sketchups tools like select, move and rotate. Ugh!
CPhillips
PluginStore Author
PluginStore Author
Re: [Plugin] SketchyFFD (Updated Aug 22, 2009)
Postby Jim » Mon Aug 24, 2009 9:53 pm
Just wanted to bump this and make folks aware of the update.
viewtopic.php?f=180&t=6029
Jim
Global Moderator
Postby mitcorb » Tue Aug 25, 2009 12:06 am
Thank you for the update. It really is an effective modeling tool.
User avatar
mitcorb
Top SketchUcator
Postby CPhillips » Tue Aug 25, 2009 1:03 am
I found another way to speed the updates. A model with 11300 verts takes about 90 seconds to update in this version and about 6 seconds with the new method.
But it order to get it ready for release I would almost have to rewrite it. Because it would be a significant amount of work I am thinking I might make the new one a "Pro" version.
Question: How many would be willing to pay for a version with some significant updates? And what would be a fair price to charge?
CPhillips
PluginStore Author
PluginStore Author
Postby EarthMover » Tue Aug 25, 2009 1:09 am
Sounds like a significant speed improvement. I would pay for a Pro version with a few new features. I think in the range of $15 is fair.
Content Creator at Skapeup
User avatar
EarthMover
Premium Member
Premium Member
Postby MALAISE » Tue Aug 25, 2009 6:56 am
By the way, about 10 € ( 15$) seem to be a fair sum, as far as this version is also
available for SU ( not the Pro version )...
MALAISE :thumb:
User avatar
MALAISE
Postby boofredlay » Tue Aug 25, 2009 9:23 pm
I would pay for it too. $15 seems reasonable.
User avatar
boofredlay
Global Moderator
Postby lancaster » Thu Sep 03, 2009 3:36 pm
REGIS wrote:Hi Tobobo
curtain.skp
cheers
Edit
After some FFD
curtainFFDv6.skp
cheers
FFD isn't working on my computer aswell, so i've read the whole topic to see for an answer. Unfortunately there are no answers yet.
I've downloaded the curtain.skp-file so I could try to FFD it with the sketchup version I am using. That worked fine! Other objects drawn in the curtain.skp-file transformed aswell by using the FFD plugin. However, copying the curtain into a new file: no result, no transformation.
I'll just try some other options and hopefully I or someone else will come up with an answer on why the FFD-plugin not always work...
EDIT:
In a new file I've created an 10x10 patch to transform. The transformation is succesful with an NxN FFD with default settings (4x4x4 false) and moving all 4 guidepoints.
Other tried and failed setting: 4x4x1 false, 4x4x2 false, 4x4x3 false, 4x4x5 false, 4x4x4 true, 5x5x4 false....
Seems like only the default setting work at my computer.
lancaster
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: FJKARCH and 17 guests
Visit our sponsors:
