Shadow Control Possible? (solved)
Postby renderiza » Sat Jun 22, 2013 8:34 pm
I want to create a plugin that will set scenes with different rendering styles so I can then export them to Photoshop.
To get better idea of what I want to create through code please open this LINK to see the rendering setting to set scenes for Color, Shadows, Alpha Channel and ZDeapth.
I can't seem to find a way to control Shadows parameter like 'Light' and 'Dark' values. Also the only way to active Shadows through code that I know of is this the following...
Sketchup.send_action(1213)
I am just starting this so I don't have much but here is a WIP to creat aplha channel (still not complete).
Code: Select all
###Alpha Channe###
Sketchup.active_model.rendering_options['DisplayFog']=false
Sketchup.active_model.rendering_options['BackgroundColor']=[0, 0, 0]
#Ground
Sketchup.active_model.rendering_options['DrawGround']=false
#Sky
Sketchup.active_model.rendering_options['DrawHorizon']=false
#EndPoint (lines)
Sketchup.active_model.rendering_options['DrawLineEnds']=false
#Profile (lines)
Sketchup.active_model.rendering_options['DrawSilhouettes']=false
#Display Lines?
Sketchup.active_model.rendering_options['EdgeDisplayMode']=0
#Back Face Color
Sketchup.active_model.rendering_options['FaceBackColor']=[255, 255, 255]
#Front Face Color
Sketchup.active_model.rendering_options['FaceFrontColor']=[255, 255, 255]
#Fog Color
Sketchup.active_model.rendering_options['FogColor']=[255, 255, 255]
If anyone can help me I will be very greatfull. Thanks!
renderiza
Premium Member
Premium Member
Re: Shadow Control Possible?
Postby TIG » Sat Jun 22, 2013 10:31 pm
You also need to consider the shadow_info and its ['Light'] & ['Dark'] settings [%] ?
Global Moderator
Postby renderiza » Sat Jun 22, 2013 11:01 pm
For example if I want to set the Alpha Channel scene I need to set the following shadow settings with code...
Shadow Settings:
>> Use Shadow = false
>> Light = 0
>> Dark = 100
>> Use sun for shading = true
If I am not mistaken the shadow_info Api is only to extract their values so it cannot let me set their values right?
Maybe the solution is to provide SketchUp File with all the scenes with styles settings already provided and just import the them somehow but not sure if that is possible. I need to do some more research! :ugeek:
renderiza
Premium Member
Premium Member
Postby TIG » Sat Jun 22, 2013 11:11 pm
No. :roll:
Play around in the Ruby Console to see what changing things does...
Sketchup.active_model.shadow_info['Dark']=0
Sketchup.active_model.shadow_info['Light']=100
Will both change things as you might expect :?
Global Moderator
Postby renderiza » Sat Jun 22, 2013 11:38 pm
WOW!
TIG, did I said you are awesome! :ecstatic:
Thanks!
renderiza
Premium Member
Premium Member
Postby renderiza » Sun Jun 23, 2013 1:41 am
The following is the code for creating an Alpha Channel Scene...
Code: Select all
###Alpha Channe###
###Create Scene###
Sketchup.send_action(CMD_PAGE_NEW)
###Style###
Sketchup.active_model.rendering_options['RenderMode']=5
#Edge Settings
#Face Settings
#Background Settings
#Watermark Settings
Sketchup.active_model.rendering_options['DisplayWatermarks']=false
###Shadow Settings###
Sketchup.active_model.shadow_info['DisplayShadows']=false
Sketchup.active_model.shadow_info['UseSunForAllShading']=true
Sketchup.active_model.shadow_info['Light']=0
Sketchup.active_model.shadow_info['Dark']=100
###Fog Settings###
###Update###
model = Sketchup.active_model
pages = model.pages
c_page = pages.selected_page
c_page.update
Only thing I wish didn't happen is the Warning! message saying "You are creating or updating a scene and have not saved the changes you've made to your style."
Is there a way to get rid of that?
Anyways just wanted to post what I had so far...thanks!
renderiza
Premium Member
Premium Member
Re: Shadow Control Possible? (solved)
Postby renderiza » Sun Jun 23, 2013 2:12 am
Here is an interesting plugin...
Rendering Favourites (v1.1) by Trogluddite - This is a plugin which can store style options and its great to store things like Alpha Channels, ZDeapth, Color, ect.
renderiza
Premium Member
Premium Member
WIP for Style Rendering Channels
Postby renderiza » Sun Jun 23, 2013 8:41 pm
Here is what I assume to be a BUG... When the code creates the Zdepth page even though the Fog settings appear to be applied it doesn't display it! This is strange and for it to work I need to move the distance slider a nudge manually which defeats the purpose. :?
Here is the code...Notice I saved the style properties into folder and I am just importing them so the rest of the code works on Shadow & Fog properties.
Code: Select all
pages = model.pages
###Aplha################################
###Fog Settings###
pages.add("Aplha")
styles = Sketchup.active_model.styles
status = styles.add_style "c:\\styles\\Aplha Style.style", true
selpage = pages.selected_page
selpage.update
###Zdepth###############################
###Fog Settings###
Sketchup.active_model.rendering_options["FogEndDist"]=35.m
Sketchup.active_model.rendering_options['DisplayFog']=true
pages.add("Zdepth")
status = styles.add_style "c:\\styles\\Zdepth Style.style", true
selpage.update
Any help will be appreciated! :thumb:
renderiza
Premium Member
Premium Member
Postby renderiza » Mon Jun 24, 2013 12:45 am
Seems the Fog part is working now but not sure what was that I did to fix it. For the most part I think I am finish but just need to worry about the interface part of things now.
Code: Select all
pages = model.pages
###Alpha################################
###Fog Settings###
###Add Page###
pages.add("Alpha")
status = styles.add_style "c:\\styles\\Alpha Style.style", true
###Update###
selpage.update
###Cley#################################
Sketchup.active_model.shadow_info['Light']=50
Sketchup.active_model.shadow_info['Dark']=15
###Fog Settings###
###Add Page###
pages.add("Cley")
status = styles.add_style "c:\\styles\\Cley Style.style", true
###Update###
selpage.update
###Color################################
###Fog Settings###
###Add Page###
pages.add("Color")
status = styles.add_style "c:\\styles\\Color Style.style", true
###Update###
selpage.update
###Color by Layer#######################
###Fog Settings###
###Add Page###
pages.add("Color by Layer")
status = styles.add_style "c:\\styles\\Color by Layer Style.style", true
###Update###
selpage.update
###Line################################
###Fog Settings###
###Add Page###
pages.add("Line")
status = styles.add_style "c:\\styles\\Line Style.style", true
###Update###
selpage.update
###Profile##############################
###Fog Settings###
###Add Page###
pages.add("Profile")
status = styles.add_style "c:\\styles\\Profile Style.style", true
###Update###
selpage.update
###Shadow################################
Sketchup.active_model.shadow_info['DisplayShadows']=true
###Fog Settings###
###Add Page###
pages.add("Shadow")
status = styles.add_style "c:\\styles\\Shadow Style.style", true
###Update###
selpage.update
###Texture################################
###Fog Settings###
###Add Page###
pages.add("Texture")
status = styles.add_style "c:\\styles\\Texture Style.style", true
###Update###
selpage.update
###Fog Settings###
Sketchup.active_model.rendering_options['FogEndDist']=35.m
###Add Page###
pages.add("Zdepth")
###Update###
selpage.update
renderiza
Premium Member
Premium Member
Postby mrsailboat83 » Tue Jul 17, 2018 3:24 am
dude, did you know that everytime you save a scene there is the option to save it with the current settings? Maybe this wasn't the case back in 2013 but there you go
mrsailboat83
Return to Developers' Forum
Users browsing this forum: No registered users and 9 guests
