From this topic, here's a few command-line options for SketchUp.
$ Sketchup.exe [opts] [file.skp]
Where [opts] are:
-DisableRubyAPI
-RubyStartup "/path/to/ruby.rb"
-template "/path/to/template.skp"
-notemplate
-page "Scene1"
-timing
These may be options, but I haven't been able to verify they work:
-DisableAutoSave
-DisableWarnIfReadOnly
-thumbnail
-thumbprefs
SketchUp Command Line Switches
• Page 1 of 1
Re: SketchUp Command Line Switchescheers Jim,
on a mac, because of the ridiculous Google Folder you need to use, unless you add it to the ~.profile /Applications/Google\ SketchUp\ 8/Sketchup.app/Contents/MacOS/SketchUp -DisableRubyAPI anyway, that one works... EDIT: it seems to work [as in it starts SU], but when you actually click SU, it continues loading, including the Plugins... john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: SketchUp Command Line Switches-lang ru
where the language is exactly the name of the localization folder in the resources directory. For example create a new folder of your favorite dialect (pfl) and load it with -lang pfl. It seems that eastern asian languages need also a special SketchUp.exe binary.
Re: SketchUp Command Line Switchesknew I'd seen it before, needs a boolean
cd / Applications/Google\ SketchUp\ 8/SketchUp.app/Contents/MacOS/SketchUp -DisableRubyAPI YES john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: SketchUp Command Line SwitchesIs it possible to start Sketchup with different location for plugins folder. For example - a thumbdrive or "disk name/MyFavoritePluginsFolder" ?
Re: SketchUp Command Line SwitchesSketchUp always includes its own Tools folder [and the nested Ruby folders] and your user Plugins folder in it load-path [$:]
You can include addition plugins folders in the load-path array, and any scripts in there will load as SketchUp starts. Fredo wrote a clever extension to do this for you. https://sketchucation.com/pluginstore?p ... ginFolders Read its More Info... pages for usage etc... TIG
• Page 1 of 1
Users browsing this forum: Google Bot, horacio88 and 12 guests
