Tool.onCancel - Reselect tool?
https://developers.google.com/sketchup/docs/ourdoc/tool#onCancel
1: the user re-selected the same tool from the toolbar or menu.
I can't seem to get reason code 1 to trigger. Only 0 and 2.
I thought I'd used it before - but I'm unsure. -
Test snippet:
<span class="syntaxdefault"><br />class MyTool<br /><br /> def activate<br /> puts </span><span class="syntaxstring">"activate: #{self}"<br /></span><span class="syntaxdefault"> end<br /><br /> def deactivate</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> view </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> puts </span><span class="syntaxstring">"deactivate: #{self}"<br /></span><span class="syntaxdefault"> end<br /><br /> def onCancel</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">reason</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> view</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> puts </span><span class="syntaxstring">"MyTool was cancelled for reason #{reason}"<br /></span><span class="syntaxdefault"> end<br /><br />end<br /></span>
I thought I'd used it before - but I'm unsure.Never got code 1 either. So I usually only test 0 or not 0
Fred
Is 1 (technically) possible?
Do "radio" toolbar buttons trigger an action if the current state is not changed?
Do toolbar buttons in the OS X version behave the same way? -
You can click a menu or toolbar button that activates a tool. It does triggesr the action and activates the tool again, but it deactivates the tool instead of calling this event.
(Devil's Advocate)
Are you dealing with a single re-usable
Tool
instance ?Or does the command create a new
Tool
instance each time the menu item is chosen ? -
Tool
Tool
instance each time the menu item is chosen ?Either way - I'm unable to trigger that event.
This seems like a documentation error. However when re-selecting a tool the deactivate and activate methods seems to be called right after each other so maybe comparing a timestamp can be used to detect when a tool is re-activated.
That's what I do, including for simulating a double-click on icon.
However, you cannot avoid the calls toactivate()
anddeactivate()
, just shortcut them.I just realize that, should Trimble fix this issue, there could be some regression in my scripts, because I only test status 0.
Fredo
