There is a problem wit the html-menues after the lions update.
What's the error?
last Lions Update
• Page 1 of 1
last Lions UpdateThere is a problem wit the html-menues after the lions update.
What's the error? Please, register (free) to access all the attachments on the forums. Wir planen Ihre Büroeinrichtung mit SketchUp. http://www.momo-moebel.de
Re: last Lions UpdateWhat is the problem? What is expected result?
Re: last Lions UpdateIn the past the right fields have white ground with black letters.
The first field is the result after double click. Wir planen Ihre Büroeinrichtung mit SketchUp. http://www.momo-moebel.de
Re: last Lions UpdateHTML form styling has always been a difficult beast. Different browsers style each element differently - some allow more styling than others.
When I do HTML form now I use minimal if no styling - so that the form at least renders consistently for the user - as oppose to the mix you see in your screenshot. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: last Lions UpdateHi,
we've recently had such a case in the Help Forum (Components Options dialog, which – not obvious – uses some html). It seems some setting in webkit or Safari is broken that provides the so-called "system colors", to match websites to the native UI. But I can't tell for sure as I don't have/use OS X. What exact update was that? Would OS X users be able to revert the update?
Re: last Lions UpdateThere has been previous updates to Safari/Webkit that's broken stuff. Very annoying these incompatibilities.
Same problem here. for me it started 2 days ago when I upgraded to osx Lion 10.7.4
Any chance this will be fixed in the near future?
Re: last Lions UpdateThey didn't fix the last time they broke something. It was a "feature"...
Re: last Lions UpdateIt isn't the WebKit system colors, someone showed me how they look now and that's what used to be.
The html and css of the momo Möbel plugin doesn't contain anything that could cause this. So it is either something else in the 10.7.4 update or something in SketchUp that didn't emerge before the update. Can someone with OS X and WebInspector check on the Elements tab in the right Styles sidebar, whether there is anything else causing an override for the <input> element?
Re: last Lions UpdateI see this as well after latest Lion update.
Its just when invoked from SketchUp - but its not a SketchUp problem because I have the same wrong coloring if I run SketchUp 7 too. Looks like Lion update broke applying CSS correctly. I have a input.text rule which is no longer applied - my hunch is its something to do with having 'placeholder' attributes. Adam Developer of LightUp http://www.light-up.co.uk
Re: last Lions Updatesooo, my problem with <input> loosing the CSS after the Lion upgrade turned out to be programmer-error.
I'm not sure why I got away with: <input type='text' ...> working before, yet I actually meant to write: <input type='text' class='text' ...> which now works fine under 10.7.4 - I'll roll into the next release of LightUp. So perhaps the 10.7.4 release just tightened up the rules some. Adam Developer of LightUp http://www.light-up.co.uk
Re: last Lions UpdateSo is there a solution for this? I have had issues with the black input fields as well. Is it something that can be easily fixed?
Re: last Lions UpdateHi Whaat,
it's a compositing problem with text fields with default (=no) background color in a WebKit WebView (see Peter Saal's link to StackOverflow, and there the chances for a fix by Apple or SketchUp): viewtopic.php?f=11&t=45382#p406422 It has been suggested there that you could work-around it by forcing a input[type=text]{background-color: white}, but many haven't succeded with this solution.
SketchUcation One-Liner AdvertsVertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
• Page 1 of 1
