by RichMorin » Sun Apr 29, 2012 12:57 am
As you may know, Scott Lininger recently posted an encouraging entry on the SketchUp API blog: ... I'm here to assure you that Trimble is committed to preserving the vitality of SketchUp’s developer community. ... In the longer term, I expect [this change] to improve the state of our APIs and developer resources. Trimble wants to invest strongly in SketchUp as a platform, and advance its mission of "3D for Everyone." ... -- A new home for SketchUp http://sketchupapi.blogspot.com/2012/04 ... tchup.html
I am quite willing (nay, delighted) to believe that "Trimble wants to invest strongly in SketchUp as a platform". What I'm not sure about is what this could mean for me as a developer. Over the past several years, many of us have made suggestions, only to be told "that's a great idea, but the resources aren't available". Well, what if the resources were available? What projects should Scott propose to Trimble and/or John Bacus? Well-known "clean up" items aside, what new projects would we like Scott to propose? What things could his team do if they had (say) another half-dozen programmers? FYI: Constructive comments and suggestions are welcome, but please take any negativity elsewhere. We all have gripes about the past and worries about the future; this topic isn't the place for them. Let's see if we can give Scott some help, while he's busy packing for the move... I'll start with some general items: - concurrency (eg, actors, distributed Ruby)
- debugging support (eg, logging framework)
- documentation (eg, API, best practices, examples)
- interpreter (eg, Ruby 1.9.x, mruby)
- library support (eg, full standard library, gem access)
- plugin management (eg, installation, signing, vetting)
- plugin namespacing (eg, classes and modules, files)
API changes really deserve their own section, eg: - improved access to menu items
- improved API for WebDialogs (eg, WebSockets)
What am I missing, folks? (ducks) -r
RichMorin
- Name: Rich Morin
- Operating system: Mac
- SketchUp version: 8
- License type: Pro
- SketchUp use: interior design
- Level of SketchUp: Beginner
by thomthom » Sun Apr 29, 2012 3:48 am
I could make a very loooong post. Better wait until I've sovered uip.!
- Global Moderator
- Name: thomthom
- Operating system: Windows
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by kwalkerman » Wed May 02, 2012 2:32 pm
*Make it possible to explode components within Sketchup.active_model.start_operation and Sketchup.active_model.abort_operation tags... without crashing Sketchup
*Allow me to selectively lock components - I'd like to be able to supply the user with a component they can move, rotate & copy, but can't edit the internal definition.
kwalkerman
- Name: Karen
by thomthom » Wed May 02, 2012 2:43 pm
kwalkerman wrote:*Make it possible to explode components within Sketchup.active_model.start_operation and Sketchup.active_model.abort_operation tags... without crashing Sketchup
Got an example of this? I've never experienced this. (Sure you don't have some observers attached that is misbehaving? Or that you are not holding on to stale entity references?)
- Global Moderator
- Name: thomthom
- License type: Pro
by daiku » Wed May 02, 2012 6:24 pm
Expose the dimension objects in the API.
daiku
- Name: Clark Bremer
by TIG » Thu May 03, 2012 12:19 am
Expose Text and Section-Planes in the API.
- Global Moderator
- Name: TIG
- License type: Pro
by kwalkerman » Thu May 03, 2012 12:34 am
thomthom wrote:kwalkerman wrote:*Make it possible to explode components within Sketchup.active_model.start_operation and Sketchup.active_model.abort_operation tags... without crashing Sketchup
I have had this issue on various machines running both SU7 and SU8. After exploding a group, the program crashes on commit_operation. I am unable to reproduce it right this moment in the ruby console or webconsole, which is curious.
kwalkerman
- Name: Karen
by Dan Rathbun » Sun May 06, 2012 10:49 am
A Geom::Axis class.
Dan Rathbun
- Top SketchUcator
- Name: Dan Rathbun
- License type: Pro
- SketchUp use: education
by lestercavey » Mon May 07, 2012 9:04 pm
Retrieve the location and dimensions of any Group shape created from "Draw -> Shapes", even after it has been moved or resized.
lestercavey
- Name: Lester Cavey
by Dan Rathbun » Tue May 08, 2012 3:52 am
lestercavey wrote:Retrieve the location and dimensions of any Group shape created from "Draw -> Shapes", even after it has been moved or resized.
That is a plugin (with a submenu,) not part of the API.
Dan Rathbun
- Top SketchUcator
- Name: Dan Rathbun
- License type: Pro
by Jeff Hammond » Tue May 08, 2012 3:56 am
layout api
dotdotdot
Jeff Hammond
- Global Moderator
- License type: Pro
by lestercavey » Tue May 08, 2012 8:31 pm
Well, since "Draw -> Shapes" is a plugin, my wish is to include SketchUp API Group subclasses of common 3D shapes (Box, Cylinder, etc). Those subclasses would be able to return the shape's current size and location, even after transformations and scaling take place.
lestercavey
by thomthom » Wed May 09, 2012 9:10 am
lestercavey wrote:Well, since "Draw -> Shapes" is a plugin, my wish is to include SketchUp API Group subclasses of common 3D shapes (Box, Cylinder, etc). Those subclasses would be able to return the shape's current size and location, even after transformations and scaling take place.
Surely you can just use the current API for that?
- Global Moderator
- Name: thomthom
- License type: Pro
by pc0158 » Wed May 09, 2012 5:02 pm
kwalkerman wrote:*Allow me to selectively lock components - I'd like to be able to supply the user with a component they can move, rotate & copy, but can't edit the internal definition.
Agree. For example, I have a sundial object that, once created, can be moved around via translation and still work find but will break if it is rotated on any axis. It would be nice to prevent users from rotating it, while permitting scaling and translation. Maybe this is possible with a DC (including some morphing when gross changes in latitude/longitude take place) but this is just a hobby with me; I'm not willing to shell out for the pro version.
pc0158
by kwalkerman » Wed May 09, 2012 10:13 pm
pc0158 wrote:kwalkerman wrote:*Allow me to selectively lock components - I'd like to be able to supply the user with a component they can move, rotate & copy, but can't edit the internal definition.
There are some things you can do with dynamic components. You can fix the rotation or the location, and restrict scaling. However, if the user can edit the component definition, they can still create problems.
kwalkerman
- Name: Karen
by RichMorin » Wed May 09, 2012 10:45 pm
To keep my initial posting brief, I mentioned some wish list items without providing any explanations. Here are some follow-up posts which clarify what I have in mind: Wish List - plugin management and namespacing http://forums.sketchucation.com/viewtopic.php?f=180&t=45083Wish List - Ruby interpreter and libraries http://forums.sketchucation.com/viewtopic.php?f=180&t=45148Other posts of this type may be forthcoming; watch for titles of the form "Wish List - ...". -r
RichMorin
- Name: Rich Morin
- License type: Pro
by aadbuild » Tue May 15, 2012 4:25 am
HI all I have been working on a ruby now for over 4 years, I created it so that I can draw faster and smarter. It is almost finished and I think it will change the way home owners Architects and builder design and create domestic homes whilst creating a bill of quantities, orders and quotation requests (BIM). Now I have a ruby that is very comprehensive that has cost me a lot of money to build for my self. I was wondering if anyone had any advice on the best way to release it or what I should do to protect my intellectual property? I beleive it will revolutionalise the way we draw homes in Sketchup.
aadbuild
- Premium Member
- Name: aadbuild
- License type: Pro
by thomthom » Tue May 15, 2012 8:04 am
aadbuild wrote:I was wondering if anyone had any advice on the best way to release it or what I should do to protect my intellectual property?
Use the Scrambler: https://developers.google.com/sketchup/ ... stributing (See Step 2)
- Global Moderator
- Name: thomthom
- License type: Pro
by AdamB » Fri May 18, 2012 1:49 pm
aadbuild wrote:HI all I have been working on a ruby now for over 4 years, I created it so that I can draw faster and smarter. It is almost finished and I think it will change the way home owners Architects and builder design and create domestic homes whilst creating a bill of quantities, orders and quotation requests (BIM). Now I have a ruby that is very comprehensive that has cost me a lot of money to build for my self. I was wondering if anyone had any advice on the best way to release it or what I should do to protect my intellectual property? I beleive it will revolutionalise the way we draw homes in Sketchup.
Just my 0.02 worth. You need to be clear what you're trying to achieve. Scrambler won't stop people copying your IP, though it does provide some basic protection to stop people peeking at how you do what you do. If this is going to be a commercial venture beyond earning some 'beer bucks' money, you do need more than Scrambler. Adam
AdamB
- LightUp
- Name: AdamB
by RichMorin » Fri May 18, 2012 3:43 pm
Please, folks, don't hijack this topic (or any topic, really) for unrelated discussions. Just start a new topic with an appropriate Subject; your karma will benefit greatly ...
RichMorin
- Name: Rich Morin
- License type: Pro
by Dan Rathbun » Sat May 19, 2012 4:28 pm
Fix the Set class ( dang it!) see my beta fix here (and how easy it is!): viewtopic.php?f=180&t=45443
Dan Rathbun
- Top SketchUcator
- Name: Dan Rathbun
- License type: Pro
by aadbuild » Sun May 20, 2012 10:43 pm
Sorry about that I was not thinking. There are many improvements that would be fanatastic if were added. Has there been any thing mentioned that we will still be able to access the back end of Sketchup? Or do we have to become some sort of partner with Trimble and only a select few will have access? No point in asking for more access when there is a possibility we will have less. It would be greatto get a comment from the powers to be
aadbuild
- Premium Member
- Name: aadbuild
- License type: Pro
Return to Developers' Forum
