SketchUcation Premium Membership
looping all entities
Postby Pout » Thu Mar 01, 2012 9:27 am
I'm a bit puzzled.
Sketchup.active_model.entities.each{|e|e.erase! if e.valid?}
works but doesn't delete all entities
Sketchup.active_model.entities.to_a.each{|e|e.erase! if e.valid?}
works and deletes all entities
Now, does this mean that to loop all entities in a model i always have to put them in an array first?
I never have run into any problems before using the first method.
Additionaly
Code: Select all
f=0
Sketchup.active_model.entities.each{|ent|
   f+=1
   Sketchup.active_model.selection.clear
   Sketchup.active_model.selection.add ent
   ent.erase!
puts f
returns 4095 (on a 11200 entities model)
while
Code: Select all
f=0
   f+=1
   #ent.erase!
puts f
returns 11200 (on a 11200 entities model)
I must be missing something essential here... :shock: :?: :?:
Pout
Re: looping all entities
Postby thomthom » Thu Mar 01, 2012 10:05 am
A few points:
1. Bulk operations are much faster than single operations.
Code: Select all
model.entities.erase_entitiesarray_of_entities
Is faster than
Code: Select all
for entity in array_of_entities
  e
.erase!
But when you want to clear the entire Enitites collection you can just use
Code: Select all
model.entities.clear
2. Never iterate the Entities collection directly when you modify it.
Code: Select all
for entity in model.entities
  e
.erase!
This will make some entities be skipped as you are modifying the Entities object you iterate.
Instead make an array copy of the entities:
Code: Select all
for entity in model.entities.to_a
  e
.erase!
This will not skip any entities.
3. Model.entities does not contain every entity in the model - only the root of the model hierarchy. Entities in Groups and Components are stored in the definitions in model.defintions.
But if you want to empty the whole model, model.entities.clear! is still the easiest.
http://www.thomthom.net/thoughts/2012/0 ... -sketchup/
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby Pout » Thu Mar 01, 2012 10:21 am
ThomThom
Thanks for the fast reply!
I did the test on a single box (not a group nor instance) and even then it went wrong
So I can assume that Sketchup.active_model.entities.each{|e|
can always be incorrect even when just checking for something (eg. check if the current entity has a certain value in it's attribute dictionary)?
On point 1, what would be faster
Code: Select all
check=e.get_attribute'x','y'
if check==1
e.erase!
or
Code: Select all
test=[]
if check==1
test<<e
model.entities.erase_entities(test)
Pout
Postby thomthom » Thu Mar 01, 2012 10:25 am
Pout wrote:went wrong
What went wrong? Examples?
Pout wrote:So I can assume that Sketchup.active_model.entities.each{|e|
can always be incorrect even when just checking for something?
No, just when you modify it. If you just read states and properties there should be no problems.
Pout wrote:On point 1, what would be faster
The second - using .erase_entities.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pout » Thu Mar 01, 2012 10:33 am
thomthom wrote:What went wrong? Examples?
It goes wrong caused by the fact that the entities object is edited while executing the loop. So as you stated.
thomthom wrote:No, just when you modify it. If you just read states and properties there should be no problems.
Modify (like in push pull) or only when the entity is deleted?
thomthom wrote:The second - using .erase_entities.
In the second case I could use Sketchup.active_model.entities.each (without the to_a) Correct? And if so would that be faster then with to_a?
Thx again!
Pout
Postby thomthom » Thu Mar 01, 2012 10:54 am
Pout wrote:It goes wrong caused by the fact that the entities object is edited while executing the loop. So as you stated.
Yes, this is where you need to use to_a.
Pout wrote:Modify (like in push pull) or only when the entity is deleted?
Anything that adds or removed entities to the collection.
Pout wrote:Correct? And if so would that be faster then with to_a?
That won't be of much difference. What makes a difference is using bulk methods that affect multiple entities in one operation over methods that affect only one entity at a time.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pout » Thu Mar 01, 2012 10:55 am
Excellent information.
Thank you ThomThom, much appreciated!
Pout
Artisan Organic Toolset - a set of powerful organic modeling tools.
Return to Developers' Forum
Users browsing this forum: Alexa Bot and 6 guests
