SketchUcation Premium Membership
[Tutorial] SketchUp Ruby C Extension
Postby thomthom » Fri Nov 04, 2011 11:10 am
Current WIP
https://bitbucket.org/thomthom/sketchup ... -extension
Working OSX and Windows "Hello World" example.
This question comes up from time to time, how to compile a Ruby C Extension that works for SketchUp.
Following tutorials for standard Ruby will not work for SketchUp without modifications. It would be nice if we could properly document this.
For OSX I think I have all the info, thanks to AdamB that explained that it needed to be compiled into a flat namespace: viewtopic.php?f=180&t=28673&start=0#p249370
However, would be nice if anyone knew how to generate a make file with the correct flags so one does not have to edit it manually every time - like I do... :? :oops: )
For Windows it's even more to be done. TBD helped me out here with his Pelles C project. However, I was unable to create and set up a project for compilation myself and I have no idea what is needed to make it compile correctly. I'd like to learn this.
One thing is that the C Extension under windows requires you to install a standard ruby installation and modify config.h to bypass a MSC check. (Or does anyone have a solution that doesn't require this?)
I see Dana is using a make file that seem to be used on both platforms: https://github.com/danawoodman/google-s ... eLists.txt
However, that project doesn't work in SketchUp yet.
So, the short story is, can we (the devs here) put together a step by step tutorial on how to compile a SketchUp Ruby C Extension for OSX and Windows?
(I can write it up, but I need someone to provide with the technical and explains how and why.)
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: SketchUp Ruby C Extension tutorial - can we make one?
Postby tbd » Fri Nov 04, 2011 1:01 pm
can you fork https://github.com/TBD/OpenSUP/tree/master/SUExt and send a pull request for the OSX version ?
will try to make a step by step page for compiling on PellesC (I will not install VStudio on virtual machine ;)
SketchUp Ruby Consultant | Podium 1.x developer
http://plugins.ro
tbd
Postby thomthom » Fri Nov 04, 2011 1:05 pm
TBD wrote:send a pull request for the OSX version ?
There is an OSX version? I'm not sure what you mean about sending a pull request... :oops:
What would be nice is along with the tutorial we could set up the framework for making and compiling on both platforms with minimum mount of per-platform files. If possible?
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Fri Nov 04, 2011 1:07 pm
I clicked Fork when I was under SUExt - and it forked the whole repository. I guess there is no way to fork a part of a repository... ?
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Fri Nov 04, 2011 1:08 pm
Clicking "Pull Request" and I get a message:
"Oops! The TBD:master branch is already up-to-date with thomthom:master — maybe you want to try something else?"
....I should stop clicking now... :oops:
Global Moderator
SketchUp version: 8
License type: Pro
Postby tbd » Fri Nov 04, 2011 1:12 pm
fork - it creates a duplicate of the entire project in your account. you can change only in one subdirectory if you want.
pull request - you make the changes in your forked project and send a pull request so I can integrate your changes
you need to add some changes to send a pull request to me first.
http://plugins.ro
tbd
Postby thomthom » Fri Nov 04, 2011 1:19 pm
Right. Should I leave the other folders alone?
Just thinking it might be nice with a repo just for C Extension - nothing else. Just to keep it clean and simple. :?:
Global Moderator
SketchUp version: 8
License type: Pro
Postby tbd » Fri Nov 04, 2011 1:32 pm
https://github.com/sketchucation is ready to accept projects ;)
http://plugins.ro
tbd
Postby thomthom » Fri Nov 04, 2011 1:36 pm
TBD wrote:https://github.com/sketchucation is ready to accept projects ;)
Right'o. So can we create an "SketchUp Ruby C Extension" project? Then start adding stuff.
Global Moderator
SketchUp version: 8
License type: Pro
Postby tbd » Fri Nov 04, 2011 2:02 pm
http://plugins.ro
tbd
Postby thomthom » Sat Nov 05, 2011 10:36 pm
I just got a very simple Hello World example working under OSX. Will create another example with some basic Ruby object interactions and expand a little on my comments. Then I will upload it to a repository. Think I'll focus on the step by step for OSX first to get the structure up. Then Windows - seem to be a bit more tweaking to get that working.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Chris Fullmer » Sun Nov 06, 2011 2:34 am
This sounds great Thom and TBD and everyone one else who gets involved. I keep being afraid that I might need to learn some of this for my upcoming work.
Chris
All my Plugins I've written
SketchUp Team
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Postby thomthom » Sun Nov 06, 2011 11:09 am
What you got cooking?
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Sun Nov 06, 2011 2:47 pm
Right - attempting to build on Windows.
I have Visual C++ Express 201 installed and I'm trying to build using nmake. Getting some errors:
I'm not sure what that means. Though I have a suspicion I need to specify the path to where windows.h is located... Though I don't know where to do so...
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Sun Nov 06, 2011 2:48 pm
Uploaded my WIP at: https://bitbucket.org/thomthom/sketchup ... extension/
Working on OSX 10.5.
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Sun Nov 06, 2011 2:50 pm
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Sun Nov 06, 2011 3:04 pm
Think I got one step further. This thread mentions that vcvars32.bat needs to be run from the prompt: http://social.msdn.microsoft.com/Forums ... 56a2f14cd/
And this (http://stackoverflow.com/questions/6622 ... with-nmake)
So after I did that I got a different error. Missing crt file...
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Sun Nov 06, 2011 3:08 pm
( Apologies for those with the know-how - I will be posting lots of silly stuff as I work through this. Posting to make a record of what I am doing. "Thinking out loud". )
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Sun Nov 06, 2011 3:36 pm
:berserk:
Got it working!
Uncommented a #pragma comment(lib, "crt.lib"); I had. TBD's SUExt project had a reference to it. Which is what I based my project on. Seeing how it also referred to #pragma comment(lib, "msvcrt-ruby18.lib"); I just tried to see what happened if I removed the ref to crt.lib. Everything worked fine after that point.
Now I wonder what the other lines do:
#pragma comment(lib, "kernel32.lib")
#pragma comment(lib, "gdi32.lib")
#pragma comment(lib, "user32.lib")
#pragma comment(lib, "shell32.lib")
I'm looking at this tutorial: http://blogs.law.harvard.edu/hoanga/200 ... n-windows/
It made no reference to any of this. ( what is it? Is it really required? )
I'm guessing #include <windows.h> is required though.
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Sun Nov 06, 2011 3:38 pm
Now... I'd like to find a way to make any output from extconf.rb and make/nmake put everything is a separate directory - for each platform.
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Sun Nov 06, 2011 4:02 pm
Huh... I removed all of that stuff completely, as http://blogs.law.harvard.edu/hoanga/200 ... n-windows/ made no reference to it at all. Worked fine without. Guess it was required due to the way the Pelles C project was set up... :?:
Global Moderator
SketchUp version: 8
License type: Pro
Re: [Tutorial] SketchUp Ruby C Extension
Postby thomthom » Sun Nov 06, 2011 4:46 pm
Hey Chris, when we get around to writing up the step by step instructions, are you willing to be a guinea pig?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Chris Fullmer » Sun Nov 06, 2011 10:25 pm
Absolutely!
SketchUp Team
SketchUp version: 8
License type: Pro
Postby thomthom » Sun Nov 06, 2011 11:37 pm
Great!
I'm writing up a Basic example that shows a little more than Hello World.
Then I start on making the step by step Wiki tutorial. I hope people with more know how can fill the in the "why" to much of it. And that people will try it and give feedback on what is unclear and what turns out not to work.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Dan Rathbun » Mon Nov 07, 2011 5:02 am
thomthom wrote:Though I have a suspicion I need to specify the path to where windows.h is located... Though I don't know where to do so...
To do so via the IDE... from the menu Tools > Options...
.. brings up the "Options" dialog.
Choose "VC++ Directories" from the "Projects and Solutions" branch in the nav tree.
You can see the dirs for catagories by selecting the cat from the "Show directories for:" dropdown control:
Executable files:
Include files:
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: education
Postby Dan Rathbun » Mon Nov 07, 2011 5:10 am
Don't forget the "help" topic here:
[Info] C/C++ Ruby extensions & SketchUp plugins
.. and read Adan Nelson's posts (links on the above list.)
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Dan Rathbun » Tue Nov 08, 2011 11:37 pm
from the info file "win32.readme" in the Ruby C source:
You can NOT use a path name [that] contains any white space characters as
the ruby source directory, this restriction comes from the behavior of include directives of NMAKE.
(- you may call it a bug. -)
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby tbd » Wed Nov 09, 2011 8:31 am
Thom: #pragma comment(lib, "*.lib") adds the libraries to the link phase (that hold imports and functions code)
it was a way to make sure that it will compile even if you create a new project and don't use in mine in PellesC.
http://plugins.ro
tbd
Postby thomthom » Wed Nov 09, 2011 8:36 am
Right'o! Gotcha. Been reading more up on C and GCC.
Global Moderator
SketchUp version: 8
License type: Pro
Postby tomasz » Wed Nov 09, 2011 2:44 pm
Thanks Thomas for the example.
I do not understand what is 'extconf.rb' for. I have compiled my extension under VC++ 2008 without running the file and without using any makefile... Is it bad ? :? :mrgreen:
tomasz
SU2TH & SU2KT Developer
SketchUp version: 8
License type: Pro
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Next
Return to Developers' Forum
Users browsing this forum: Breezemont, gregpettigrew and 4 guests
