How can I disable keyboard shortcuts while in a tool?
• Page 1 of 1
How can I disable keyboard shortcuts while in a tool?I'm developing a plug-in to allow for First Person Shooter style WASD movement in SketchUp, and I'm wondering if it's possible to disable or override SketchUp's keyboard shortcuts when it's active? Right now, my janky fix is to require that Shift be held down while navigating with WASD, since that seems to block out shortcuts, but obviously having to keep holding down the shift key isn't ideal. Thanks!
Re: How can I disable keyboard shortcuts while in a tool?You can't...
You can only disable the VCB in a tool, but keys are read anyway... Use the arrow-keys, or number-keypad - these shouldn't be short-cutted... TIG
.. which I do not understand. We can 'intercept' all manner of key combos... but the keys still "bubble up" to the application window! It's annoying! It can cause another tool to inadvertently become active in the middle of a Ruby tool process.
Yup. I've requested a few times that we should be able to return true/false to the key events in order to control the event bubbling. I've often wanted to intercept the key presses. There are some characters that can be pressed while a tool is active, if they are typed after a number. c d e g m s - so we can type, 1m 1mm 1cm 1dm 1deg 1s etc... So SketchUp natively intercepts keys for its own usage. So I really think custom Ruby tool should have that power as well. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: How can I disable keyboard shortcuts while in a tool?Hi, I am running on this same issue... Has this been fixed yet or is there a trick around this?
Thanks in advance!
• Page 1 of 1
Users browsing this forum: khanhnhkts and 20 guests
