by TIG » Fri May 06, 2011 9:23 am
Please read this http://cfcl.com/twiki/bin/view/Projects ... _Functionswhich covers how to add your own 'custom functions' to a DC. There are also some other useful sections about DC attributes etc... This is actually Rich Morin's [although I did help in a small way with some coding ideas...] and it does refer back to this forum too... This DC 'custom function' possibility is potentially a wide reaching effect because any Ruby API method can be invoked this way as a DC function. Jim and Dan have already discussed it in this thread /viewtopic.php?f=10&t=21474 specific to adding an extra trig function... but it's wider implications for extending DCs doesn't seem to have 'clicked' yet... As well as returning values it could also execute code which might in turn modify the DC itself - e.g. swap in/out sub-DCs... Someone recently asked about filleting two edges into an arc inside a DC, where the angle between the lines and the arc's radius were infinitely variable [so no chance of a set of possible solutions to be nested in it] - now I think this method could allow it to be done as a custom function, calling a complex Ruby code script, that modifies a unique instance of a sub-DC, which is itself within the calling DC, and could indeed do the required complex math/trig to form the fillet, face it and extrude it into a 3d form. I'm not saying it'd be easy to do... BUT I now think that it is at least possible...
- Global Moderator
- Name: TIG
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by TIG » Fri May 06, 2011 10:52 am
To use custom functions here's an example - Code: Select all
if defined?($dc_observers) # Open SketchUp's Dynamic Component Functions (V1) class. # only if DC extension is active class DCFunctionsV1
protected # return volume # Usage: =volume() def volume(a) return @source_entity.volume end protected:volume # open UI.messagebox # Usage: =messagebox() def messagebox(a) UI.messagebox(@source_entity.to_s+' '+a.to_s) end#if protected:messagebox end#class
end#if
Put this code in a .rb file that loads when Sketchup runs - it adds two new functions to your DC: 'volume' - which returns the volume in cu" - and a 'messagebox' - which displays the id of the DC itself and any value[s] passed to it. In the following example it displays the id + volume, with an 'onClick'... Make a simple DC and add three items: two Custom Attributes mymessage: =messagebox(myvolume) myvolume: =volume()and a Behavior onClick: redraw(mymessage())Now when you click on the DC instance it displays a messagebox showing its instance id and volume... I know this is pretty useless stuff... BUT it shows that we can run things outside of the DC in Ruby to change the model, or the DC itself [ @source_entity.definition.entities...] ...
- Global Moderator
- Name: TIG
- License type: Pro
by kwalkerman » Fri May 06, 2011 3:20 pm
Cool!
kwalkerman
- Name: Karen
by jason_maranto » Fri May 06, 2011 7:02 pm
This is very cool! I've been wondering about this for a long time and it looks like I will need to dig deeper into ruby now Best, Jason.
jason_maranto
- Name: Jason Maranto
- License type: Pro
- SketchUp use: illustration, cartoons
by Jeff Hammond » Sat May 07, 2011 5:38 pm
TIG wrote:Someone recently asked about filleting two edges into an arc inside a DC, where the angle between the lines and the arc's radius were infinitely variable [so no chance of a set of possible solutions to be nested in it] - now I think this method could allow it to be done as a custom function, calling a complex Ruby code script, that modifies a unique instance of a sub-DC, which is itself within the calling DC, and could indeed do the required complex math/trig to form the fillet, face it and extrude it into a 3d form. I'm not saying it'd be easy to do... BUT I now think that it is at least possible...
so i guess that was me that asked about filleting inside a DC.. i've done it only using DC's custom functions instead of going out to ruby: viewtopic.php?f=289&t=37037but.. it results in a collection of edges inside various sub-components.. do you think it's possible to use ruby along with the DC to somehow extract all of the edges and face them as a single component? a real use for me being able to do something like that would be for a stair stringer which isn't actually a collection of individual components.. i'd like to be able to make a stair DC in which i can pull out the stringer and it's one solid piece. [or, it'd be sweet if i could make the stringer out of individual solid components which then automatically uses the solid tools' outer shell to make it a single component with no coplanar lines etc..
dotdotdot
Jeff Hammond
- Global Moderator
- Operating system: Mac
- License type: Pro
by TIG » Sat May 07, 2011 6:47 pm
Jeff
I think it would be possible... We can form the outline in DC code or a DC-Ruby hybrid and then ass the face and pushpull it in Ruby etc within the DC's definition entities... Can you outline 'blow-by-blow' exactly what is is you want to do so I could perhaps sketch out how it might be done in DC_Ruby ?
- Global Moderator
- Name: TIG
- License type: Pro
by Jeff Hammond » Sat May 07, 2011 7:12 pm
i'm having second thoughts about diving too far into this stuff  but, with the stairs, i think i can accomplish what i want with a few clicks using the outliner, selection toys, and outer shell. i'm going to try to make the stairs today and i'll upload a .skp showing the DC result and the desired 'finished' component. with the other thing (the arc to angle blend), i would want it to do everything it's doing except there's a face or possibly a thickness to it.. (imagine that outline being drawn on a piece of 3/4ply and cut out). i can accomplish that now but i have to explode everything a few times in order to make a face.. i haven't used bomb.rb in a year or two because it was super slow but maybe it wouldn't be that bad on this(?).. i'll give that a shot in a little bit.
dotdotdot
Jeff Hammond
- Global Moderator
- License type: Pro
by Jeff Hammond » Sun May 08, 2011 12:42 am
so, i've yet to see a good example of a DC stair stringer so i tried making one of my own (all of the other ones appear to ignore the fact that stairs are typically built out of standard sized materials) [but, if anyone knows of some good ones, feel free to share : ) ] ..very early into it, i ran into the problem (rather, limitation?) of dynamic components.. you can't change angles of faces/edges/etc on a component.. to do that, you have to break the component down into smaller sub-components and by doing so, you lose the ability to have a single/solid component.. if you ruby geniuses could figure out a way to either A) add faces to nested edges or b) find a way to control individual faces/edges within a component via DC then these things could be awesome.. otherwise, DCs appear to be limited to cubes for any practical construction application (and that's a huge limit imo because the cube type stuff is super easy to draw anyway).. here's the file for my Stringer dc: DC_stringer.skp if that stringer could somehow become one solid component then i'd be --> otherwise, it's still a decent (and definite timesaver) calculator for the stringer but it's not so good for making .skp drawings of them.. regardless, i'm going to expand on the DC to include the support wall and stringer cap which will still let me make super quick cutlists on the job site..
dotdotdot
Jeff Hammond
- Global Moderator
- License type: Pro
by TIG » Sun May 08, 2011 12:14 pm
To make the DC stringer as a 'solid 3D object' you'd still do the 'inputs' as before, BUT then output them to a new custom function - called say '=jcstringer(height,riser,board)' in the DC that runs when you update one of the values. You would not necessarily need the built-in DC functions used to calculate number of notches etc as these are now done inside Ruby-side code... The associated custom Ruby code would be 'def jcstringer(a)', which always takes its input as one array 'a', so height=a[0].to_l, riser=a[1].to_l, board=a[2].to_l etc... You could also pass a variable stringer-width, tread-width, and any other data etc etc...
We can readily find the DC instance's definition and thereby its entities. First you'd erase that definition's entities: then take the passed values, use iterations etc and make a set of coplanar points for each vertex of the 'cut' stringer and add a face to the DC defn's entities using those. Then pushpull that face to the right width [here 2"] and finally do a Ruby-side DC redraw etc [if needed]. This way you'll get a full 3D solid object as the stringer without any subcomponents in it. Whenever that stringer's value is changed the Ruby side discards the old geometry and makes new geometry...
Initially it might be easier to start with something like a simple L-shape 'box' with 3 or 4 changeable dims. Then try remaking that with a custom function in Ruby code called from the DC. Once that's cracked you can move on to the more complex iterations etc in the Ruby to make 'step-notches' etc...
- Global Moderator
- Name: TIG
- License type: Pro
by Dan Rathbun » Sun May 08, 2011 12:19 pm
markozeta in Re: ATAN2(y,x) for dynamic components wrote:Jim wrote:Drop this in your plugins folder... - Code: Select all
class DCFunctionsV1 protected def atan2(*a) return Math::atan2(a[0], a[1]) end end
Lemme do a quick fix on that... - Code: Select all
class DCFunctionsV1 protected def atan2(a) return Math::atan2(a[0], a[1]).radians end end
You are correct for the argument, in that the DC extension always passes the function arguments as an Array (so the * expansion operator is not needed.) However, all the other trig functions do not have built-in radians to degrees conversion, and to follow convention, the internal code for the function should be as Jim showed. If you wish degrees from a result that returns radians, you should use the DC function degrees( radian_arg ), as in: degrees( atan2(n1,n2) )- Code: Select all
require('dynamiccomponents.rb') if defined?($dc_observers) # only if DC extension is active class DCFunctionsV1 protected def atan2(a) return Math::atan2(a[0], a[1]) end #def end #class end #if
NOTE: modifying this class no longer makes it version 1
Dan Rathbun
- Top SketchUcator
- Name: Dan Rathbun
- License type: Pro
- SketchUp use: education
by TIG » Sun May 08, 2011 5:14 pm
Jeff This is the cut-stringer as a Ruby formula - Code: Select all
def jh_stringer(ar) ### ar==array of data... ### ents=Sketchup.active_model.entities ### for testing ### for a DC class DCFunctionsV1 class def you change to ### ents=@source_entity.definition.entities ### h=ar[0].to_l ### total height floor to floor e.g. 48" r=ar[1].to_l ### max riser e.g. 7.25" b=ar[2].to_l ### stringer board size e.g. 10" [from 2x10] ### g=9.25 ### going [i.e. tread size] 9.25" t=2.00 ### stringer thickness 2" tt=1.00 ### tread thickness say 1" ? *** hh=h-tt n=((hh/r)+0.5).round r=h/n a=Math.atan(r/g) b1=r/Math.acos(a) b2=b-b1 gg=g*n bt=(b*Math.cos(a))-r g1=gg-((hh-bt)/Math.tan(a)) pts=[[0,0,0]] ### start at the bottom of the first riser n.times{|i| ### no lower tread to 1st riser pts << [g*i,0,r+(r*i)-tt] ### front edge of each tread pts << [g+(g*i),0,r+(r*i)-tt] ### back edge of each tread } pts << [gg,0,(hh-bt)] ### the top u/side of stringer pts << [g1,0,0] ### the bottpm u/side of stringer ### f=ents.add_face(pts) f.pushpull(t) end
As a test def it makes the stringer in model entities. See the note on how to add it to the DC definition etc... Use as a custom function =jh_stringer(height, rise, stringer_boardwidth)
- Global Moderator
- Name: TIG
- License type: Pro
by Jeff Hammond » Mon May 09, 2011 6:20 am
tig, thanks i gotta admit though, i really don't feel like going down that rabbit hole.. i can see the possible addiction and i don't think i can afford another addiction at this point in my life  i tried out a new approach and i think it's going to work out good for me.. i can make these types of DCs a lot faster/easier because there are less factors to account for as these cutters only need to be exact on their cutting edges.. lengths/thicknesses/positions etc. can just run wild in many cases. for final components with multiple parts, i'll be able to reuse certain cutters instead of needed to reenter the parameters etc.. here's the stringer example... DC_stringer_cutter.skp i think this opens up a lot of possibilities with DCs (at least with the way my brain works  ) i'll try some things out this week with more complex shapes (ie- the things that i'd actually want to use DCs for) and post the results if they end up being decent.. [edit] - i guess i should point out that this method requires sketchup PRO.. but that's obvious, right? : )
Please, register (free) to access all the attachments on the forums. dotdotdot
Jeff Hammond
- Global Moderator
- License type: Pro
by TIG » Mon May 09, 2011 9:32 am
That's fine if you're happiest with this approach...
- Global Moderator
- Name: TIG
- License type: Pro
by quiver » Thu Apr 05, 2012 2:32 pm
Jeff Hammond wrote:if you ruby geniuses could figure out a way to either A) add faces to nested edges or b) find a way to control individual faces/edges within a component via DC then these things could be awesome.. otherwise, DCs appear to be limited to cubes for any practical construction application (and that's a huge limit imo because the cube type stuff is super easy to draw anyway)..
I wholeheartedly echo that request.. this would overcome a variety of issues for my work. I design for events, and have made all my own lighting fixtures / speakers / projectors etc, which are all DC's that I can adjust the attributes of (some of my library is published here: http://sketchup.google.com/3dwarehouse/cldetails?mid=e94a8eafed72d755701d728505a21ed0&prevstart=12). But I come across that stumbling block frequently, with wanting to do something as simple as move one face of a cube (not in alignment with the cube, but side-to-side.. like a parrallelogram).. Custom functions are a helpful half-way point but if everyone needs the same ruby script installed to be able to utilise it, they don't serve all that well. Is there any way to address individual edges/faces of a component using ruby in a DC spreadsheet formula? If I can do that, and modify them using existing functions, then I'd be more than satisfied. Thanks !
quiver
- Name: Tad Errey
by Jim » Sat Apr 07, 2012 5:30 pm
--use component options to determine dimensions --in outliner, click on 'CUTTERS' --select 'Outer Shell' via solid tools --select 'Subtract' via solid tools --click on the orange board (stringer_uncut) --explode --the stringer will be a single solid component named 'Stringer'
Once the DC is configured, these steps could be automated into a single step (via a menu or tool button.) I am making the assumption of consistent Component names being used i.e Components named "Cutters" are always subtacted from Components named "Stringer_Uncut"
Jim
- Global Moderator
- Name: Jim
- License type: Pro
- SketchUp use: other
by Jeff Hammond » Sun Apr 08, 2012 1:42 am
Jim wrote: Once the DC is configured, these steps could be automated into a single step (via a menu or tool button.) I am making the assumption of consistent Component names being used i.e Components named "Cutters" are always subtacted from Components named "Stringer_Uncut"
hey Jim. since the time of this thread, I have automated the finishing parts of the DC using AppleScript. I found a pretty decent way to create macros for sketchup.. the macros are osx 'services' which (can) reside in a specific app's menus (or they can be available system wide) which reminds me. maybe I should type up a thread showing how to accomplish this.
dotdotdot
Jeff Hammond
- Global Moderator
- License type: Pro
by Dan Rathbun » Sun Apr 08, 2012 2:53 am
Jeff.. please DO. Then if we can find a PC complement (likely OLE,) these "services" could be wrapped as Ruby objects or classes. A platform conditional if block would define the Ruby interface, using AppleScript on the Mac, and OLE on PC. In this way we could have a cross-platform Ruby interface for plugins.
Dan Rathbun
- Top SketchUcator
- Name: Dan Rathbun
- License type: Pro
by Jeff Hammond » Sun Apr 08, 2012 3:33 am
Dan Rathbun wrote:Jeff.. please DO. Then if we can find a PC complement (likely OLE,) these "services" could be wrapped as Ruby objects or classes. A platform conditional if block would define the Ruby interface, using AppleScript on the Mac, and OLE on PC. In this way we could have a cross-platform Ruby interface for plugins.
hmm. I'm not too sure it would work with what you're suggesting. (at least the way I've been going about it) I'm doing GUI scripting so it's basically just keystrokes and menu items.. you can accomplish quite a bit this way (I actually have one script that uses a little but of ruby in there via the console  ) the thing that's good about it is it's not very complicated so a lot of people should be able to make their own macros this way (and a bonus is that you don't have to install any additional software)..
dotdotdot
Jeff Hammond
- Global Moderator
- License type: Pro
by Jim » Sun Apr 08, 2012 3:55 am
Jeff Hammond wrote:I'm doing GUI scripting so it's basically just keystrokes and menu items..
The Windows equivalent can be accomplished via Windows Scripting. Here's a VBScript example: - Code: Select all
Sub Wait Wscript.Sleep(1500) End Sub
set WshShell = WScript.CreateObject("WScript.Shell") 'WshShell.AppActivate "- SketchUp" Command = """C:\Program Files (x86)\Google\Google SketchUp 8\SketchUp.exe""" 'MsgBox Command WshShell.Run(Command) Wait WshShell.SendKeys "%u" ' My SU Shortcut to open Ruby Console Wait WshShell.AppActivate "Ruby Console" Wait WshShell.SendKeys "require_all 'c:/plugins'{ENTER}"
Jim
- Global Moderator
- Name: Jim
- License type: Pro
by Jeff Hammond » Sun Apr 08, 2012 4:18 am
Jim wrote:Jeff Hammond wrote:I'm doing GUI scripting so it's basically just keystrokes and menu items..
set WshShell = WScript.CreateObject("WScript.Shell") 'WshShell.AppActivate "- SketchUp" Command = "C:\Program Files (x86)\Google\Google SketchUp 8\SketchUp.exe" MsgBox Command WshShell.Run Command WScript.Sleep 1000 WshShell.SendKeys "%u" ' My SU Shortcut to open Ruby Console WScript.Sleep 1000 WshShell.AppActivate "Ruby Console" WScript.Sleep 1000 WshShell.SendKeys "require_all 'c:/plugins'" WScript.Sleep 1000 WshShell.SendKeys "{ENTER}"
is something like that easy to run from within sketchup? (that's sort of the beauty of osx services.. they become a menu item so activating the script is the same for anything else in sketchup.) regardless, you guys could probably write a macro recorder in ruby that in turn produces these services :enlighten: nothing to do with recording cursor movement etc.. AppleScript can't handle it.. (eg- edit component, select all, explode, generate faces, exit component) those steps are what ruby watches, then places the commands in a .scpt format and moves them to the services folder. [edit-- sorry for not cleaning up the quotes in my replies.. im on a phone and deleting big chunks of text is no fun  ]
dotdotdot
Jeff Hammond
- Global Moderator
- License type: Pro
by Dan Rathbun » Sun Apr 08, 2012 5:19 am
Yep.. what Jim said.. however, his example can also be written in Ruby (on PC using the Win32ole.so extension, which many users have already installed to their " Plugins" directory, or they have it in their full Ruby library directory, if they have installed the full Ruby edition, and pushed it's lib path into the $LOAD_PATH array.) So to use the " SendKeys" example (which seems to be a common function name in many of the programming languages available, from low-level C, to the higher level languages such as VB, C# etc.) Goal: To provide a cross-platform Ruby method, named SendKeys() that sends keystrokes to the Sketchup application. 1) Choose a community namespace. As an example, lets say (for argument's sake,) this will go within the SKX project namespace, and beneath that we'll wrap it within a GUI submodule. - Code: Select all
module SKX; end # make sure outer namespace is defined
module SKX::GUI
if RUBY_PLATFORM =~ /(darwin)/i # on Mac
def self.SendKeys(keystring) # the Mac code using AppleScript end
else # on Windows
def self.SendKeys(keystring) # the WIN code using Windows Scripting Host end
end # module SKX::GUI
This is the one file approach, which may not be the best, because it makes everyone update their file(s) even when a revision is made for a certain platform. I show it to make an important point about Ruby, in that it is a dynamic language that can be defined during runtime. (In this example, we would define the same method, two different ways, depending upon which platform it will run on.) The separate file approach may be better. Where a user chooses an install package for the proper platform, so that their " Plugins/SKX/GUI" directory, only contains the Ruby object definitions for their platform. To use this proposed feature, scripters would simply require the proper module definition file: require("SKX/GUI/keyboard.rb") SKX::GUI::SendKeys("require_all 'c:/plugins'"+SKX::GUI::KBD::ENTER)P.S.: Locally within a custom module or class, a scripter can create 'nickname' shortcut references that point at long nested qualified objects, like: gui = SKX::GUI @kbd = SKX::GUI::KBDor even: ENTER = SKX::GUI::KBD::ENTERSo don't be afraid of well organized, multi-nested module namespaces. Also.. if say, the KBD submodule was just a mixin module of constants, scripters could, if they wished, mix it into their module(s) or class(es) by inclusion: - Code: Select all
module Author::FancyPlugin require("SKX/GUI/keyboard.rb") include(SKX::GUI::KBD) # now all constants in KBD module, are mixed in. end
Dan Rathbun
- Top SketchUcator
- Name: Dan Rathbun
- License type: Pro
by Jeff Hammond » Sun Apr 08, 2012 6:10 pm
the wording in AppleScript is keystroke.
keystroke "v" (for the v key) keystroke "V" (is for shift + v) keystroke "V" using command down (for shift-cmmd-v or paste in place)
likewise, you can also do menu items:
click menu item "Outer Shell" of menu "Tools"
dotdotdot
Jeff Hammond
- Global Moderator
- License type: Pro
by Dan Rathbun » Sun Apr 08, 2012 11:28 pm
Jeff Hammond wrote:the wording in AppleScript is keystroke.
Yea.. and what is the point your making ??
Dan Rathbun
- Top SketchUcator
- Name: Dan Rathbun
- License type: Pro
by Jeff Hammond » Mon Apr 09, 2012 1:19 am
Dan Rathbun wrote:Jeff Hammond wrote:the wording in AppleScript is keystroke.
just saying that ruby could write the macro script. (but I'm pretty sure I'm not thinking about doing this the right way  ) like if a user turns on the macro recorder (.rb plugin) then does a series of commands they want to automate then click 'stop ecording'(or whatever).. ruby will then write the commands used in a scpt file in the format of my previous post.. then puts it in the services folder so the user now has a sketchup macro without leaving sketchup or manually typing up an AppleScript. edit. oh, I was also just saying it's 'keystroke' in applescript as opposed to 'sendkeys'
dotdotdot
Jeff Hammond
- Global Moderator
- License type: Pro
by bmike » Mon Apr 09, 2012 2:23 am
Jeff,
Very much hope you do a thread on how to use services in Mac. I've moved back to Mac after a too long trip through various PCs and am very curious about Services, AppleScript, and Automator. Anything you put together for Services in SketchUp would be appreciated.
bmike
by Jeff Hammond » Mon Apr 09, 2012 5:35 pm
bmike wrote:Jeff,
I'm going to do a thread today on it. I think I'll keep it super basic at first then the thread can evolve from there into the other possibilities.
dotdotdot
Jeff Hammond
- Global Moderator
- License type: Pro
by bmike » Mon Apr 09, 2012 5:38 pm
Jeff Hammond wrote:bmike wrote:Jeff,
Great! I'll keep an eye out for it!
bmike
by Jeff Hammond » Mon Apr 09, 2012 8:50 pm
ok. I made a little macro example in this thread: viewtopic.php?f=15&t=44503.
dotdotdot
Jeff Hammond
- Global Moderator
- License type: Pro
Return to Developers' Forum
