Determine OS bit version with ruby
Postby Pout » Wed Apr 20, 2011 10:32 am
Is there a way to determine wether the OS where Sketchup is installed on is 32 or 64 bit?
puts RUBY_PLATFORM gives me i386-mswin32 (which is probably the ruby version since i am working on 64 bit)
machine_bytes = ['foo'].pack('p').size
machine_bits = machine_bytes * 8
Also gives me 32, again probably because ruby/SU is 32 bit
Is there another way?
Thx!
Pout
Re: Determine OS bit version with ruby
Postby tbd » Wed Apr 20, 2011 12:24 pm
why do you need that in the first place ?
for me (OSX), the ruby command 1.size is
* 4 -> 32 bit SU Ruby
* 8 -> 64 bit command line Ruby
on Windows you can check for GetSystemWow64Directory as it is not present on 32bit version
SketchUp Ruby Consultant | Podium 1.x developer
http://plugins.ro
tbd
Postby Dan Rathbun » Sat Apr 23, 2011 7:50 pm
Code: Select all
# define these methods within your module or class
def is_windows_32bit?
  ( not is_windows_64bit? )
def is_windows_64bit?
  ENV.has_key?('ProgramFiles(x86)')
Note: ENV['PROCESSOR_ARCHITECTURE'] may return a label for a 64bit CPU (like "AMD64",) but still could have a 32bit Windows OS installed.
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby Pout » Tue Apr 26, 2011 8:30 am
    thx TBD and Dan
    I need it to determine where certain file are located.
    For now i have used a similuar aproach as Dan suggested in which you look if Program Files(x86) 'exists'
    But i think his method is better.
    Pout
    Postby tbd » Tue Apr 26, 2011 8:39 am
    as I dont have 64bit Windows to test it up, take in account this as well - "The %ProgramFiles% itself depends on whether the process requesting the environment variable is itself 32-bit or 64-bit"
    http://plugins.ro
    tbd
    Postby thomthom » Tue Apr 26, 2011 9:24 am
    And some versions of Windows doesn't even have folders names "ProgramFiles" but instead a localized version. Hard coded paths are not reliable, they should be requested from the system.
    PluginStore Author
    PluginStore Author
    Postby Dan Rathbun » Tue Apr 26, 2011 7:19 pm
    The NAMES of the environment vars should NOT change, and their VALUES should be the localized language folder names.
    So it is much safer to test FIRST if ENV.has_key? THEN use the value of the varible (IF it is present,) to check if the folder exists using:
    Code: Select all
    if ENV.has_key?('ProgramFiles(x86)') &&
       File.exist?(ENV['ProgramFiles(x86)']) &&
       File.directory?(['ProgramFiles(x86)'])
      # safe to access directory
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby Dan Rathbun » Tue Apr 26, 2011 7:28 pm
      TBD wrote:as I dont have 64bit Windows to test it up, take in account this as well - "The %ProgramFiles% itself depends on whether the process requesting the environment variable is itself 32-bit or 64-bit"
      %ProgramFiles% = ENV['ProgramFiles']
      But I told him to use %ProgramFiles(x86)% (which is ENV['ProgramFiles(x86)'],) and should not be present on 32bit systems.
      On a 64bit system, running a 32bit process (in this case 32bit Sketchup, running 32bit Ruby as a subprocess,) a copy of the enviroment is created for the process. Both the vars ENV['ProgramFiles'] and ENV['ProgramFiles(x86)'] should contain a pathstring that points at the same 32bit localized "program files" directory.
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Return to Developers' Forum
