ruby <-> cmd command line: How to get return value?
Postby Aerilius » Tue Mar 08, 2011 12:23 am
Hello,
I'm just beginning with ruby and have not much practice with it. My aim is to launch a command on Windows cmd (actually later a bash shell) and get a return value into the ruby console. I have found how to launch external programs or for example a batch file, however I didn't find if it's possible to receive a result from the batch script.
Is there another command or parameter necessary in ruby or do I have an error in the batch script (exit %a%)?
ruby:
x="E:/new_batch.bat"
UI.openURL(x)
returns only true
batch file:
Code: Select all
@echo off
set a="Hello World"
ECHO %a%
exit %a%
Aerilius
PluginStore Author
PluginStore Author
Re: ruby <-> cmd command line: How to get return value?
Postby Dan Rathbun » Tue Mar 08, 2011 1:15 am
In the console... you can use backquoted strings to run shell commands.
`dir`
An aleternate to using backquotes, is to use %x dilimiters. The delimiter character is your choice, or you can choose one of the bracket sets ( ), [ ] or { }, ex:
listing = %x[dir]
So a backquoted shell string will return the STDOUT from the shell command (in the example above I store it in the string reference listing.)
And, before you ask, there's a bug / annoyance in Ruby where we can't suppress having the shell window pop up for a half-second or so.
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby Dan Rathbun » Tue Mar 08, 2011 1:24 am
    Also I see you are using Environment variables.
    The set of Environment variables is accessed from Ruby via the ENV hash.
    So on my system:
    ENV['USERNAME']
    >> Dan
    There are differences between MAC and PC... on a MAC it would be:
    ENV['USER']
    To list the Enviroment variables from Ruby, you can do (cross-platform):
    ENV.each {|k,v| puts "#{k} = #{v}" }
    but it's simpler, to do (for PC):
    `set`
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby TIG » Tue Mar 08, 2011 10:18 am
      This might be clearer
      ruby:
      Code: Select all
      x="E:/new_batch.cmd"
      UI.openURL(x)
      returns true
      batch file:
      Code: Select all
      @echo off
      echo "Hello World"
      echo
      pause
      exit
      Waits for you to close it...
      x="file:/E:/new_batch.cmd"
      will also work...
      Writing the bat or cmd file to the root directory would probably be better if it were into a Temp folder ?
      Global Moderator
      Return to Developers' Forum
      Users browsing this forum: Google Bot, steveot4 and 1 guest
