SketchUcation Premium Membership
State of Observers Redux — 18 August 2011
Postby thomthom » Sun Sep 12, 2010 1:38 pm
I've begun on a revision of the State of Observers:
http://www.thomthom.net/software/sketchup/observers/
Could you please have a look and let me know if have information that would fit in this.
(p.s. The page is in HTML5 - so if you use silly old browsers it might not look good - I've not tested it yes, just in Firefox 3.6. Atm I'm focusing on the content.)
Added public bug tracker to the BitBucket repo:
https://bitbucket.org/thomthom/sketchup ... tatus=open
People can add reports of broken observer events there.
User avatar
Global Moderator
Name: Thomas Thomassen
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: State of Observers Redux — 12 September 2010
Postby thomthom » Sun Sep 12, 2010 2:02 pm
Was there an observer hidden in the API docs somewhere that was listed in between the methods of another class instead of a class of its own?
User avatar
Global Moderator
License type: Pro
Postby Dan Rathbun » Sun Sep 12, 2010 2:38 pm
thomthom wrote:Was there an observer hidden in the API docs somewhere that was listed in between the methods of another class instead of a class of its own?
Yes.. it is the FrameChangeObserver, see the Pages class.
Dan Rathbun in post Re: Ruby to trigger DC onClick Function wrote:
mtalbott wrote:I am trying to animate objects based on Scene Changes and not with the interact tool.
topic: Dynamic Components that react to scene (aka page) changes
in this post: Re: Using an observer to delete a screen note I said the following:
Chris Fullmer wrote:That's interesting. I've never noticed that [FrameChangeObserver observer] ...
Yes that is because is one of the API missing class boo-boos. It IS mentioned within the API, in passing.
Pages.add_frame_change_observer
Pages.remove_frame_change_observer
It was featured (documented) in the Sketchup API BlogSpot:
('scenes.rb') Code properly formatted (by Todd Burch) at:
http://www.smustard.com/forum/viewtopic.php?f=9&t=25
It basically only has one event callback:
frameChange( fromPage, toPage, percent_done ),
the intialize method, plus any custom method(s) you need inside to keep your code readable and organized.
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
SketchUp use: education
Postby Dan Rathbun » Sun Sep 12, 2010 2:45 pm
And I think Jim had doubts whether it worked during an animation export.
PS, the table page looks fine under MSIE 7.
"Depreciated" has no "i" in it. And the methods that were removed can not be "Deprecated", they are "Abandoned", "Deceased".. whatever they are no longer even in the Observer protoclass.
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby Krisidious » Sun Sep 12, 2010 2:55 pm
they should have you on staff Thom...
Kristoff Rand
Home Designer
Custom House Plans with a Point of View
User avatar
Krisidious
SketchUp version: 8
License type: Pro
Postby Dan Rathbun » Sun Sep 12, 2010 3:01 pm
MaterialsObserver.onMaterialRefChange
"When purging materials, or right-clicking a material in the Material Browser this event triggers one time for every entity with a material. This cause a long series of events to trigger unnessesary."
should read:
"When purging materials, or right-clicking a material in the Material Browser, this event triggers one time for every entity with a material. This causes a long series of events to trigger unnecessarily."
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby Jim » Sun Sep 12, 2010 3:08 pm
Great work, and great resource. Thanks for doing it.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
Postby thomthom » Sun Sep 12, 2010 3:48 pm
Thanks Dan, knew it was hiding somewhere.
Thanks for the spelling control - I didn't run a spell-checker or proofread yet.
Dan Rathbun wrote:"Depreciated" has no "i" in it. And the methods that were removed can not be "Deprecated", they are "Abandoned", "Deceased".. whatever they are no longer even in the Observer protoclass.
It's what the API docs said. I've not tested if the events are actually removed, or just aliased to their new names...
User avatar
Global Moderator
License type: Pro
Postby thomthom » Sun Sep 12, 2010 3:50 pm
http://dictionary.reference.com/browse/ ... ref&ch=dic :?:
User avatar
Global Moderator
License type: Pro
Postby thomthom » Sun Sep 12, 2010 3:52 pm
Oh, "Depreciated" refer to value...
*grumble something about English and too similar words*
User avatar
Global Moderator
License type: Pro
Postby thomthom » Sun Sep 12, 2010 4:04 pm
Another issue, I imagine I read some reports on MaterialObserver.onMaterialSetCurrent not working as it should on OSX in some versions of SU?
User avatar
Global Moderator
License type: Pro
Postby Dan Rathbun » Sun Sep 12, 2010 4:06 pm
thomthom wrote:It's what the API docs said. I've not tested if the events are actually removed, or just aliased to their new names...
I did test the MaterialObserver's Bulk change method. It has been removed from the superclass, so when you create an instance of a MaterialObserver subclass, it just is not there, and if you were to explicitly call the callback, a NoMethodError exception will be raised. Ie, there is no aliasing to the individual change callback(s).
So if you wanted to handle events in a bulk manner, you'd need to do it on the Ruby side, perhaps with a Ruby standard Observer class, or a bulkchange boolean flag variable and an Array of changed objects (each individual SU change callback would need to push it's object into the Array.)
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby Dan Rathbun » Sun Sep 12, 2010 4:12 pm
thomthom wrote:Another issue, I imagine I read some reports on MaterialObserver.onMaterialSetCurrent not working as it should on OSX in some versions of SU?
YES.. I posted the answer that Scott gave me. He says it's logged as an internal bug.
See GG post: Materials.current on OS X
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby thomthom » Sun Sep 12, 2010 4:17 pm
http://code.google.com/apis/sketchup/do ... e_observer
Sketchup::Pages.add_frame_change_observer(FrameChangeObserver.new)
This, surprisingly worked.
I'd thought you'd have to reference the model first...
Sketchup.active_model.pages.add_frame_change_observer(FrameChangeObserver.new)
User avatar
Global Moderator
License type: Pro
Postby thomthom » Sun Sep 12, 2010 4:19 pm
So it's bugged on SU6, SU7.0, SU 7.1?
User avatar
Global Moderator
License type: Pro
Postby thomthom » Sun Sep 12, 2010 4:20 pm
bulk change event? Is that one that has been removed from the API?
That was a troublesome points when I made this chart - they recently removed some events from the API....
User avatar
Global Moderator
License type: Pro
Postby Dan Rathbun » Sun Sep 12, 2010 4:27 pm
thomthom wrote:So it's bugged on SU6, SU7.0, SU 7.1?
Careful.. the collection getter method Materials.current IS bugged, the question remains, is the MaterialsObserver bugged as well. You'd need to test versions on the Mac to find out.
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby Dan Rathbun » Sun Sep 12, 2010 4:34 pm
thomthom wrote:bulk change event? Is that one that has been removed from the API?
Yes.. the MaterialsObserver.onMaterialRemoveAll callback was removed, as it never worked, and/or never got called. So there was no point in deprecating it.
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby thomthom » Sun Sep 12, 2010 4:42 pm
I'd like to add it for historic purpose - anyone remembers it parameters?
User avatar
Global Moderator
License type: Pro
Postby thomthom » Sun Sep 12, 2010 4:43 pm
Ah - already got it. :D
Thought there was an event named onBulkChange, like the SelectionObserver has.
User avatar
Global Moderator
License type: Pro
Postby thomthom » Sun Sep 12, 2010 4:45 pm
aiaiai... *sigh*
User avatar
Global Moderator
License type: Pro
Postby thomthom » Thu Aug 18, 2011 10:57 pm
User avatar
Global Moderator
License type: Pro
Re: State of Observers Redux — 18 August 2011
Postby Dan Rathbun » Thu Aug 18, 2011 11:19 pm
You have that the AppObserver::onQuit is working...
It's is bugged in v8 (at least. And I did report a bug last beta cycle.)
It does not wait until the callbacks return, before shutting down the application.
Trying to use the callback to save plugin settings, and so forth, often fails for me.
Also, trying to dettach the observer itself from within onQuit causes a GPF (if I remember right.)
In addition coders should NOT open any "owned" windows (like WebDialogs and messageboxes,) during the callback, until they fix the 'non-blocking' issue.
Can't remember if v7 had any of these problems.
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby Dan Rathbun » Thu Aug 18, 2011 11:41 pm
InstanceObserver
I'm wonding if you can do this
Code: Select all
class InstSpy < Sketchup::InstanceObserver
  if RUBY_PLATFORM =~ /(darwin)/
    def onQuit()
      Sketchup.active_model.definitions.instances.each{|i|
        i.remove_observer(self)
      # what about Groups?
  end #if
  def initialize(*args)
    Sketchup.add_observer(self) if RUBY_PLATFORM =~ /(darwin)/
  # define your Instance callbacks:
  def onOpen(instance)
    puts("onOpen: " + instance.to_s)
  def onClose(instance)
    puts("onClose: " + instance.to_s)
end # class
(Note how I changed the example, from UI.messagebox to puts.
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby thomthom » Fri Aug 19, 2011 8:19 am
Dan Rathbun wrote:You have that the AppObserver::onQuit is working...
Ok - I'll add that. Never used it. All the observers I've not tried and not heard any reports on I assume is working.
Dan Rathbun wrote:InstanceObserver
Dan Rathbun wrote:# what about Groups?
Groups and Images all are listed in model.definition.
Dan Rathbun wrote:(Note how I changed the example, from UI.messagebox to puts.
I wish the docs would do that. Messageboxes are double plus ungood - especially in observer events.
User avatar
Global Moderator
License type: Pro
Postby thomthom » Fri Aug 19, 2011 8:43 am
Dan, how do you test AppObserver::onQuit ?
If I had a test case that illustrates the symptoms I could quickly run it on SU 6-8.
User avatar
Global Moderator
License type: Pro
Postby Dan Rathbun » Fri Aug 19, 2011 2:48 pm
thomthom wrote:Dan, how do you test AppObserver::onQuit
Tough one... as it DOES fire. (It just doesn't wait for the callback to finish.)
Well I first found it because I wanted to save the pos & size of several windows using Win32API calls.
But it wasn't working.
So I tried putting a debug popup messagebox inside onQuit(), thinking the shutdown process should stop, until I clicked "OK". But it DIDN'T stop, the messagebox came up, but everything else shutdown. And when I closed the messagebox, it's owner (the Sketchup App window,) no longer existed, so Windows poped up the VS Just in Time debugger query box (you know.. "DO want Debug now?")
So next I tried, to open a WebDialog.. and that made things even worse. (I got a post-shutdown BugSplat!) They were either GPF or "Unhandled Win32 Exception".)
I was trying to call a method that saved a whole bunch of data into the Registry, and that method may have called another method as well. Anyway, I even tried "lean" the process way down, putting all statements inside the onQuit(), and removing every extra reference assignment I could. But Sketchup just would not wait. It seemed to be processing all the onQuit callbacks, in the Ruby thread, but at the same time, cleaning up the main App thread, and disposing of all it's child windows.
Perhaps it's a unique thing because I want to save window object data, ...that most other plugins would not encounter.
I plan to try using Ruby define_finalizer, and see if that works for me.
As far as testing.. I'll have to think more on this... perhaps a trace function.
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby Dan Rathbun » Fri Aug 19, 2011 2:50 pm
I don't have a Mac to test this InstanceObserver workaround.
(And I fixed the example. I don't know why, but every single time I go to write an initialize() method, I forget to put def in front of it!)
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby thomthom » Fri Aug 19, 2011 3:17 pm
In TT_Lib2 I got a function TT.debug that outputs a string to any system debugger, like DebugView. That can probably be used to track onQuit.
User avatar
Global Moderator
License type: Pro
Postby thomthom » Thu Aug 02, 2012 12:58 pm
User avatar
Global Moderator
License type: Pro
by Ad Machine » 5 minutes ago
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Premium Members get 20% discount!
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: sergg and 7 guests
