I used soap skin bubble as part of my weld tutorial, and have continued to use this method for my current mountian bike model. However for large joints there becomes quite a large number of individual 'welds' all generally having the same amount of pressure applied via ssb.
What I would like to be able to do is select multiple skins and apply the same pressure to each, but ssb will only apply this pressure to one ssb skin at a time.
Having to select each weld and apply pressure to each individually is very time consuming, and I thought someone may be able to help create a ruby script that would work in conjunction with ssb??
