Ruby to rotate overhead view 90 degrees around blue axis?
Postby daiku » Wed Aug 18, 2010 8:02 pm
I'm trying to create a plan view, so I select camera | parallel projection, and then camera | standard views | top. But of course it's rotated 90 degrees from the view I want. For the life of me I can't figure out how to rotate the camera - it really jumps around when you are looking straight down. And of course you can never get it exactly lined up using the mouse. Is there a ruby out there that does this? CB.
User avatar
daiku
PluginStore Author
PluginStore Author
Re: Ruby to rotate overhead view 90 degrees around blue axis
Postby Box » Wed Aug 18, 2010 8:22 pm
I did see a ruby that allows you to change the default of the standard views, but i don't remember where. If I find it I'll post back.
I'm sure someone will chime in soon.
In the mean time have you considered just rotating the entire model 90deg?
User avatar
Postby TIG » Wed Aug 18, 2010 9:10 pm
Use eye, target AND up.
User avatar
Global Moderator
Postby Jim » Wed Aug 18, 2010 9:36 pm
I posted a small plugin to do just this. It's around here somewhere...
viewtopic.php?t=25174
Jim
Global Moderator
Postby Dan Rathbun » Wed Aug 18, 2010 9:51 pm
OR .. go to the Help menu ...
click "Welcome to Sketchup"
choose Template..
pick one of the Plan View Templates.
-1
    I'm not here much anymore. But a PM will fire email notifications.
    User avatar
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby daiku » Thu Aug 19, 2010 2:27 pm
    Jim wrote:I posted a small plugin to do just this. It's around here somewhere...
    Perfect! I did a quick search before I posted, but didn't think to use the term "roll". That's exactly what I needed. Thanks Jim! CB.
    User avatar
    daiku
    PluginStore Author
    PluginStore Author
    Postby Jim » Thu Aug 19, 2010 2:33 pm
    You're right; I've edited the title of that post to include "rotate". That will make it easier to find. I'm glad it's useful.
    Jim
    Global Moderator
    Postby MartinRinehart » Thu Aug 26, 2010 6:32 pm
    MartinRinehart
    Postby DavidBoulder » Mon Aug 30, 2010 8:00 pm
    You can also take an object oriented the way you want your plan, and create a new axis using that object. For your new axis blue is still on the Z axis for your model, set the green axis to go in the direction that you want to be at the top of your screen in plan view.
    You can save this as a scene and always jump back to it.
    David Goldwasser
    OpenStudio Developer
    National Renewable Energy Laboratory
    User avatar
    DavidBoulder
    by Ad Machine » 5 minutes ago
    Ad Machine
    Robot
    Return to Developers' Forum
    Who is online
    Users browsing this forum: rocha and 6 guests
    Visit our sponsors:
