Trace() - display message with traceback to caller
I use this routine trace() to display debug messages from ruby files.
For instance, including:
trace("Entities in model: %s", Sketchup.active_model.entities.length)
in a ruby function, will display something like:
Entities in model: 1 ^^^trace_sample.rb:24:in `test_trace'
Showing the ruby file name and line number where you placed the trace.
trace(format, values) can be used like puts or printf(), but you do not need to add a \n to get the carriage return. (This saves me millions of keystrokes a month - not typing in \n )
Try the attached file. When you type in: load "trace_sample.rb" you should see a message like:
In actual use, I usually define trace() within each class or module, so that I am not creating a global function. (Which might interfere with, be be overridden by, global functions from other developers.
e.g.
class RPS_class def trace(*args) ... (rest of code) end#def end#class
Here is the source for trace if you want to grab it and use it:
(Or else get it from the attachment - which also includes a sample use of trace())def trace(*args) scall = caller(1)[0].to_s # who called the routine scall2 = File::basename(scall) # only the file name itself - no path begin smess = sprintf(*args) puts smess + "\n ^^^" + scall2 rescue warn "arg ERROR in trace called from: " + caller(1)[0].to_s end end#def
Good stuff.
Though, I have a thought:
Why not define the trace method in a Trace class, and then include the class to the methods you want. That way you don't have multiple copies all over the place? -
@thomthom said:
:thumb: Good stuff.
Why not define the trace method in a Trace class, and then include the class to the methods you want. That way you don't have multiple copies all over the place?Good idea, I could include it in a module of functions.
But I would still have to distribute the trace module with each application.
And there might be a problem with versions. When a user had installed more than one RPS application, say a new version of A and and old version of B, then A might wind up inheriting from the B version of the module, if the B version was loaded into SketchUp after the A version.
At one point we considered having a common set - called RPS_common. But still the problems of installing and uninstalling became difficult.
