SketchUcation Plugin Store
WebDialog help - hide scrollbars
Re: WebDialog help - hide scrollbars
Postby thomthom » Sun Oct 18, 2009 7:15 pm
I use STRICT doctype and <body scroll="no">. Since this is for an application I don't care that it's not standard.
Global Moderator
Name: Thomas Thomassen
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby chrisglasier » Mon Oct 19, 2009 2:44 am
thomthom wrote:I use STRICT doctype and <body scroll="no">. Since this is for an application I don't care that it's not standard.
Don't you think in good time such application may well need web connectivity, say, to get or set remote data? Making things comply with today's standards could save future hassles for following generations.
chrisglasier
SketchUp version: 8
License type: Free/Make
SketchUp use: other
Postby thomthom » Mon Oct 19, 2009 7:36 am
I'm a strong proponent of webstandards. But I'm also pragmatic - this is to work around an SU bug where the scrollbar argument in SU's Webdialog class doesn't take effect.
It's not something that will cause problems for future plugins - if future SU corrects the bug, then this little attribute don't do much.
Global Moderator
License type: Pro
Postby chrisglasier » Mon Oct 19, 2009 8:54 am
thomthom wrote:I'm a strong proponent of webstandards. But I'm also pragmatic - this is to work around an SU bug where the scrollbar argument in SU's Webdialog class doesn't take effect.
Ok no big deal except I am working on the API webdialog (which will include snippets). It seems there is a conflict between this:
Code: Select all
body{
border:0px;
margin:0px;
overflow:hidden   }
and STRICT doctype, so shouldn't the solution be within HTML compliance and standards and not within Sketchup webdialogs?
It would be useful for me to understand.
Chris
chrisglasier
SketchUp version: 8
SketchUp use: other
Postby thomthom » Mon Oct 19, 2009 9:20 am
I don't know why the overflow with STRICT doctype within a Webdialog doesn't work - it's how you do it with websites.
chrisglasier wrote:so shouldn't the solution be within HTML compliance and standards and not within Sketchup webdialogs?
Seeing that the Webdialog has a scroll property for it's creating of the ruby class I'd expect that the scrollbars should be set from ruby. I think that the embedded IE control has a scroll property which developers who wish to embed HTML content can set to a fixed override. Why this argument isn't adhered to, I don't know.
I wonder if the SU dev team has been made aware of the scrollnar bug.
Was it so that this is PC only - that it works as expected on Mac?
Global Moderator
License type: Pro
Postby chrisglasier » Mon Oct 19, 2009 9:38 am
Thanks Thomas. BTW I think it therapeutic to use a STRICT doctype then abuse it by doing something non-standard - appeals to cynical Brits like me!
chrisglasier
SketchUp version: 8
SketchUp use: other
Postby thomthom » Mon Oct 19, 2009 9:45 am
chrisglasier wrote:Thanks Thomas. BTW I think it therapeutic to use a STRICT doctype then abuse it by doing something non-standard - appeals to cynical Brits like me!
It's make the standard conformant me twitch. x_X
Global Moderator
License type: Pro
Postby thomthom » Mon Oct 19, 2009 9:51 am
Ah!
There is a standard conformant way!
Code: Select all
html
  overflow: hidden;
When removing scoll="no" and adding that to the CSS the scrollbars disappeared in STRICT mode.
Armed with that, you could sub-class the Webdialog class and tap into it's .new method and pass on the scroll argument to the webdialog when it's ready. Unless you're fine with just having it defined in the CSS and ignore the Ruby argument.
I was going to make a wrapper for myself, that took care of the matter where the size is only being read the first time it's created. At the moment, if you try to change the size arguments for a non-resizable webdialog they won't take effect unless you purge the saved settings.
Global Moderator
License type: Pro
Postby chrisglasier » Mon Oct 19, 2009 10:20 am
Good and noted! And used here.
chrisglasier
SketchUp version: 8
SketchUp use: other
Postby thomthom » Mon Oct 19, 2009 10:33 am
I don't know why I didn't try that before. I know that when switching between STRICT and quicks the behaviour of HTML and BODY changes.
Glad we finally worked it out.
Global Moderator
License type: Pro
Postby thomthom » Mon Oct 19, 2009 11:44 am
NewOne wrote:One more thing: JS statement element.selected = true; did not worked on my native SU instalation. After I updated my Internet Explorer from 6 to 7, it did worked... how is this possible, because in SU I still have IE4 ?
You don't have IE4 in SU. You have whatever is installed on the system.
That's one of the reason I would prefer is SU used a standalone web-frame that isn't linked to the system.
Global Moderator
License type: Pro
Postby NewOne » Mon Oct 19, 2009 12:46 pm
thomthom wrote:You don't have IE4 in SU. You have whatever is installed on the system.
Please run this.
Code: Select all
@my_dialog = UI::WebDialog.new('Check Version', false,"",400, 100, 300, 300, true)
html = '<html>
<body>
<script type="text/javascript">
var browser=navigator.appName;
var b_version=navigator.appVersion;
var version=parseFloat(b_version);
document.write("Browser name: "+ browser);
document.write("<br />");
document.write("Browser version: "+ version);
</script>
</body>
</html>'
@my_dialog.set_html(html)
@my_dialog.show{}
@my_dialog.bring_to_front
NewOne
Postby thomthom » Mon Oct 19, 2009 1:13 pm
You can't rely on navigator.appVersion. Since IE4 and up it has always reported 4 for legacy support reasons. You must parse the navigator.userAgent string.
http://javascript.gakaa.com/navigator-appversion.aspx
http://www.quirksmode.org/js/detect.html
Global Moderator
License type: Pro
Postby NewOne » Mon Oct 19, 2009 5:13 pm
If so, why does it renders buttons so old-way? :(
NewOne
Postby thomthom » Mon Oct 19, 2009 5:18 pm
IE is quick to do weird stuff to form control. In general - form controls in any browser is unpredictable.
If it'd been rendering like IE4 it would be permanently stuck in Quicks mode. Standard mode in IE wasn't introduced until IE6.
Global Moderator
License type: Pro
Postby Dan Rathbun » Sun Nov 01, 2009 6:34 pm
NewOne wrote:If so, why does it renders buttons so old-way?
Sometimes Standards Compliant mode on MSIE turns MS Common Controls back to the old 'unthemed' set (they look like old Win 3.x ugly controls.)
See my post in the other WebDialog thread for a META tag that goes in the HEAD section.
Sometimes it can turn the 'XP themed' ver 6 controls back on.
I don't know if they work in Strict mode, but the tag should work for Tranistional mode.
http://forums.sketchucation.com/viewtopic.php?f=180&t=22698#p196706
Dan Rathbun
Top SketchUcator
License type: Pro
SketchUp use: education
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Next
Return to Developers' Forum
Users browsing this forum: mkahler and 7 guests
