Are Swig generated Ruby bindings compatible with Sketchup?
I'm hoping for someone to share some tips on how to efficiently link C++ code into Sketchup via the Ruby scripting engine. We are currently using Swig, which works fine in a stand-alone Ruby interpreter, but crashes Sketchup when loaded via the Sketchup console or as an extension.
Our C++ library that has been successfully used via Ruby (and Python) via Swig generated bindings. The code has been tested pretty extensively on MacOS, and works fine with the the system supplied Ruby and with self-compiled versions of Ruby. However, the moment it is loaded into Sketchup via the console (i.e. "require 'mymodule'"), Sketchup crashes in the function "st_lookup".
To simplify debugging, I created the standard "hello factorial world" test, and it too crashes sketchup:
factorial.c
int fact(int n) { if (n == 0) return 1; return (n * fact(n-1)); }
factorial.i
%module factorial int fact(int n);
extconf.rb
require 'mkmf' create_makefile('factorial')
So nothing fancy. To create the extension, first "swig -ruby factorial.i" is run, followed by "ruby extconf.rb && make". The resulting factorial.bundle file works fine in irb (via "require 'factorial'"). Try to load it in Sketchup via the Ruby Console, and Sketchup crashes with the following backtrace:
Process: SketchUp [26702] Path: /Applications/Google SketchUp 7/SketchUp.app/Contents/MacOS/SketchUp Identifier: com.google.sketchupfree7 Version: SketchUp 7 (7.1.4870) Code Type: X86 (Native) Parent Process: launchd [117] Date/Time: 2009-10-04 20:21:46.504 -0400 OS Version: Mac OS X 10.6.1 (10B504) Report Version: 6 Interval Since Last Report: 194104 sec Crashes Since Last Report: 4 Per-App Interval Since Last Report: 686 sec Per-App Crashes Since Last Report: 2 Anonymous UUID: DD7CA090-136F-4294-89AE-7E0032D6E21A Exception Type: EXC_CRASH (SIGABRT) Exception Codes: 0x0000000000000000, 0x0000000000000000 Crashed Thread: 2 Application Specific Information: abort() called Thread 0: Dispatch queue: com.apple.main-thread 0 libruby.1.dylib 0x1d17f63e st_lookup + 15 1 libruby.1.dylib 0x1d1542fb rb_intern + 62 2 libruby.1.dylib 0x1d10b18e rb_define_module + 32 3 factorial.bundle 0x1a9c9452 Init_factorial + 38 (factorial_wrap.c:1480) 4 com.google.rubyframework 0x022971a6 dln_load + 285 5 com.google.rubyframework 0x022ad4c0 rb_require_safe + 623 6 com.google.rubyframework 0x022ace5d rb_f_require + 35 7 com.google.rubyframework 0x022a9ca2 call_cfunc + 315 8 com.google.rubyframework 0x022a90a4 rb_call0 + 1660 9 com.google.rubyframework 0x022aa83c rb_call + 700 10 com.google.rubyframework 0x022a2c3d rb_eval + 10073 11 com.google.rubyframework 0x0229d322 eval_node + 96 12 com.google.rubyframework 0x022ab60a eval + 1068 13 com.google.rubyframework 0x0229db8a rb_eval_string + 120 14 com.google.rubyframework 0x022a8211 rb_protect + 191 15 com.google.rubyframework 0x0229dbcb rb_eval_string_protect + 42 16 com.google.sketchupfree7 0x001967f5 0x1000 + 1660917 17 com.google.sketchupfree7 0x0017f552 0x1000 + 1566034 18 com.google.sketchupfree7 0x0017f5e2 0x1000 + 1566178 19 com.apple.AppKit 0x9883d14a -[NSApplication sendAction:to:from:] + 112 20 com.apple.AppKit 0x9891c891 -[NSControl sendAction:to:] + 108 21 com.apple.AppKit 0x9899614b -[NSTextField textDidEndEditing:] + 773 22 com.apple.Foundation 0x935c82fc _nsnote_callback + 345 23 com.apple.CoreFoundation 0x90fa4c29 __CFXNotificationPost + 905 24 com.apple.CoreFoundation 0x90fa465a _CFXNotificationPostNotification + 186 25 com.apple.Foundation 0x935bd120 -[NSNotificationCenter postNotificationName:object:userInfo:] + 128 26 com.apple.AppKit 0x989f157a -[NSTextView(NSPrivate) _giveUpFirstResponder:] + 553 27 com.apple.AppKit 0x989f1346 -[NSTextView(NSKeyBindingCommands) insertNewline:] + 531 28 com.apple.AppKit 0x989f1080 -[NSResponder doCommandBySelector:] + 77 29 com.apple.AppKit 0x989f0997 -[NSTextView doCommandBySelector:] + 240 30 com.apple.AppKit 0x989dfa1f -[NSKeyBindingManager(NSKeyBindingManager_MultiClients) interpretEventAsCommand:forClient:] + 1911 31 com.apple.AppKit 0x989e32bf -[NSTextInputContext handleEvent:] + 1604 32 com.apple.AppKit 0x989df088 -[NSView interpretKeyEvents:] + 209 33 com.apple.AppKit 0x989e2b45 -[NSTextView keyDown:] + 751 34 com.apple.AppKit 0x98914194 -[NSWindow sendEvent:] + 5757 35 com.apple.AppKit 0x9882cceb -[NSApplication sendEvent:] + 6431 36 com.google.sketchupfree7 0x00178aa1 0x1000 + 1538721 37 com.apple.AppKit 0x987c06fb -[NSApplication run] + 917 38 com.apple.AppKit 0x987b8735 NSApplicationMain + 574 39 com.google.sketchupfree7 0x00003772 0x1000 + 10098 40 com.google.sketchupfree7 0x00003699 0x1000 + 9881
I've tried compiling against different versions of Ruby (matching the 1.8.5 that appears to be in Sketchup currently), and even looking through the ruby source at the implementation of "rb_intern" and call to "st_lookup" for inspiration, to no avail. So I'm hoping there's some brilliant developer out there who's figured out what this is all about and can help save my sanity.
Again, any thoughts or tips are appreciated.
Thanks,
Simeon
This is all over my head. But I won't let that stop me from responding
The Ruby installed with SketchUp is a very minimal install. It is missing many major support files, methods, classes, etc., that might come with the full install. So I do not know what st_lookup is, but if it is a method or external file, then you will need to include it as a separate file with your installation, and have SU Ruby load it before attempting to load your script, so that your script will have access to it.
That is all I have to offer though. If it is more complex than that, I am out of ideas,
Chris
I thought it was 1.8.0 ...
Checked in SU7.1 just to be sure they haven't updated it:
Object::RUBY_VERSION >> 1.8.0
I'm going to provide my "armchair CS major" version of what I think is going on.
I've had some experience with SWIG and Ruby extensions and, from what I've read, the wrapper/extension has to be linked to the same libruby that was linked with the ruby runtime, i.e. the executable called "ruby" (or "ruby.exe" for the win32 version) in a stand-alone installation.
In SketchUp's case, the environment is inside the SketchUp executable, and the libruby included (in my SU7.1/win32 install) is 'msvcrt-ruby18.dll'.
So, what you need to do is find out how to link against a 1.8.0 version of the ruby library. It goes without saying that said library also has to be compiled for the same machine/OS as the one SU is using. Actually, the one extension I compiled for SU was linked against the 1.8.7 version of "msvcrt-ruby18.dll" and still worked (well, it didn't actually work, but that was because it also used OpenGL for graphics, but it didn't crash SU, at least).
Ideally, you would link to the actual library included in the SU installation. I think on OSX it would be called "libruby-1.8.dylib" (or something like that).
Of course, having absolutely no experience with OSX, I don't know how to deal with things like multiple processor architecture support and such, or even whether that applies to this situation .
A bit long-winded, but I hope it helps
I should have been clear about versions:
I'm running Sketchup 7.1 (7.1.4870) on MacOS 10.5.8. This is what I get from the ruby console:
> Object::RUBY_VERSION 1.8.5
I thought SketchUp used the already installed Ruby on Macs, and ships with a .dll on Windows?
What happens when a Mac user upgrades to Ruby 1.9? Do the differences between platforms continue to diverge when in fact they need to unite?
A bit long-winded, but I hope it helpsActually it helps quite a bit. Pointing out that the ruby runtime was "minimalist" is a good hint. On MacOS the libraries, resources, etc. are provided as "Framework" bundles. Normally a Framework bundle contains the header files and libraries, and older versions of Sketchup had the "minimalist" header files. Now even those are missing, leaving the Framework bundle as mostly empty directories with the exception of a single file called "Ruby", which is (confusingly) the shared library and not the interpreter (no idea why they leave the extension off in Frameworks).
So that's my long-winded way of saying that your arm-chair analysis gives me a coule things to try out Thanks!
Simeon
That's interesting...
I'm using SU7.1.4871 on PCWonder why the different platforms has different builds...
...While Ruby is included in modern MacOS versions, applications can have their own versions (of most any library) in their application bundle. In this case it's "SketchUp.app/Contents/Frameworks/Ruby.framework". Compared to the system Ruby Framework, it's very sparse:
Sketchup.app/Contents/Frameworks
Ruby.framework Ruby.framework/Resources Ruby.framework/Ruby Ruby.framework/Versions Ruby.framework/Versions/A Ruby.framework/Versions/A/Resources Ruby.framework/Versions/A/Resources/English.lproj Ruby.framework/Versions/A/Resources/English.lproj/InfoPlist.strings Ruby.framework/Versions/A/Resources/Info.plist Ruby.framework/Versions/A/Ruby Ruby.framework/Versions/Current
/System/Library/Frameworks
Ruby.framework Ruby.framework/Headers Ruby.framework/Resources Ruby.framework/Ruby Ruby.framework/Versions Ruby.framework/Versions/1.8 Ruby.framework/Versions/1.8/Headers Ruby.framework/Versions/1.8/Headers/config.h Ruby.framework/Versions/1.8/Headers/defines.h Ruby.framework/Versions/1.8/Headers/digest.h Ruby.framework/Versions/1.8/Headers/dl.h Ruby.framework/Versions/1.8/Headers/dlconfig.h Ruby.framework/Versions/1.8/Headers/dln.h Ruby.framework/Versions/1.8/Headers/dtrace.h Ruby.framework/Versions/1.8/Headers/env.h Ruby.framework/Versions/1.8/Headers/intern.h Ruby.framework/Versions/1.8/Headers/missing.h Ruby.framework/Versions/1.8/Headers/node.h Ruby.framework/Versions/1.8/Headers/re.h Ruby.framework/Versions/1.8/Headers/regex.h Ruby.framework/Versions/1.8/Headers/ruby.h Ruby.framework/Versions/1.8/Headers/rubyio.h Ruby.framework/Versions/1.8/Headers/rubysig.h Ruby.framework/Versions/1.8/Headers/st.h Ruby.framework/Versions/1.8/Headers/util.h Ruby.framework/Versions/1.8/Headers/version.h Ruby.framework/Versions/1.8/Resources Ruby.framework/Versions/1.8/Resources/English.lproj Ruby.framework/Versions/1.8/Resources/English.lproj/InfoPlist.strings Ruby.framework/Versions/1.8/Resources/Info.plist Ruby.framework/Versions/1.8/Resources/version.plist Ruby.framework/Versions/1.8/Ruby Ruby.framework/Versions/1.8/usr Ruby.framework/Versions/1.8/usr/bin Ruby.framework/Versions/1.8/usr/bin/erb Ruby.framework/Versions/1.8/usr/bin/gem Ruby.framework/Versions/1.8/usr/bin/gem_mirror Ruby.framework/Versions/1.8/usr/bin/gemlock Ruby.framework/Versions/1.8/usr/bin/gemri Ruby.framework/Versions/1.8/usr/bin/gemwhich Ruby.framework/Versions/1.8/usr/bin/irb Ruby.framework/Versions/1.8/usr/bin/rdoc Ruby.framework/Versions/1.8/usr/bin/ri Ruby.framework/Versions/1.8/usr/bin/ruby Ruby.framework/Versions/1.8/usr/bin/testrb Ruby.framework/Versions/1.8/usr/bin/update_rubygems Ruby.framework/Versions/1.8/usr/lib Ruby.framework/Versions/1.8/usr/lib/libruby.1.dylib Ruby.framework/Versions/1.8/usr/lib/libruby.dylib Ruby.framework/Versions/1.8/usr/lib/ruby Ruby.framework/Versions/1.8/usr/share Ruby.framework/Versions/1.8/usr/share/ri Ruby.framework/Versions/Current ... (continues for ~37,000 more lines)
The fact that Google doesn't include the header files that it used in its version of the ruby runtime makes it a little bit tricky to compile with Swig (and cmake, in my case); you kinda have to mix and match Framework components.
Simeon
Success!
Forcing the linking of the shared library in Sketchup.app was the trick (can't just add it to the library search path).
For other cmake users, here's the CMakeLists.txt fragment that did the trick:
CMakeLists.txt
... find_package(Ruby REQUIRED) if(HAVE_SKETCHUP) set(SKETCHUP "/Applications/Google\ SketchUp\ 7/SketchUp.app") set(SKETCHUP_RUBY "${SKETCHUP}/Contents/Frameworks/Ruby.framework") set(SWIG_RUBY_LIB "${SKETCHUP_RUBY}/Ruby") else() set(SWIG_RUBY_LIB "${RUBY_LIBRARY}") endif() swig_add_module(${RUBY_MODULE_NAME} ruby "${INTERFACE_FILES}") include_directories(${RUBY_INCLUDE_PATH}) swig_link_libraries(${RUBY_MODULE_NAME} "${MYEXTENSION_LIB}" "${SWIG_RUBY_LIB}") ...
Interestingly, when linking against this, MacOS is smart enough to encode the path to the Ruby library relative to the executable, so that if Sketchup.app is installed in a different location, it still works fine:
otool -L MyExtension.bundle
@executable_path/../Frameworks/Ruby.framework/Versions/A/Ruby (compatibility version 1.8.0, current version 1.8.5) /usr/lib/libstdc++.6.dylib (compatibility version 7.0.0, current version 7.4.0) /usr/lib/libgcc_s.1.dylib (compatibility version 1.0.0, current version 1.0.0) /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 111.0.0)
I hope someone else finds this useful. I'm glad I don't have to resort to a client/server type implementation and associated headaches.
Thanks for all your help!
Simeon
@metasim said:
Success!
CMakeLists.txt
> ... > find_package(Ruby REQUIRED) > if(HAVE_SKETCHUP) > set(SKETCHUP "/Applications/Google\ SketchUp\ 7/SketchUp.app") > set(SKETCHUP_RUBY "${SKETCHUP}/Contents/Frameworks/Ruby.framework") > set(SWIG_RUBY_LIB "${SKETCHUP_RUBY}/Ruby") > else() > set(SWIG_RUBY_LIB "${RUBY_LIBRARY}") > endif() > > swig_add_module(${RUBY_MODULE_NAME} ruby "${INTERFACE_FILES}") > include_directories(${RUBY_INCLUDE_PATH}) > swig_link_libraries(${RUBY_MODULE_NAME} "${MYEXTENSION_LIB}" "${SWIG_RUBY_LIB}") > ... >
> @executable_path/../Frameworks/Ruby.framework/Versions/A/Ruby (compatibility version 1.8.0, current version 1.8.5) > /usr/lib/libstdc++.6.dylib (compatibility version 7.0.0, current version 7.4.0) > /usr/lib/libgcc_s.1.dylib (compatibility version 1.0.0, current version 1.0.0) > /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 111.0.0) >
Simeon
Thx Simeon ... Someone else did find this useful
@metasim said:
Success!
[...]I hope someone else finds this useful. I'm glad I don't have to resort to a client/server type implementation and associated headaches.
SimeonHello,
I've taken the time to register in SketchEducation just to be able to thank you for this excellent tip. Thanks to you I've been able to succeed after many headaches with my .bundle Swig/CMake generated Ruby/Sketchup extension files causing segfaults every time I used "require" to load them.
Linking against the Sketchup 2016 embedded Ruby library solved the problems and now I can use the extension!!
It was extremely useful. Thank you very much!
