Use Ruby To Apply Materials to Spacific Layers
Postby Eric_Erb » Mon Sep 28, 2009 10:11 pm
Hello, and Thank you all in advance for your advice. I'd like to start my saying I've been modeling in sketchup, rhino, and solidworks for years but I am very new to programing. The program we use automatically exports our designs as .dxf files with layers. Part of my job requires me to import these files to sketchup and apply a material to each layer of the dxf. These layers are always named the same and the materials are always the same so there must me a way to write a little ruby script that will automatically apply those materials to their respective layers. Can anyone help me out?
Eric_Erb
Re: Use Ruby To Apply Materials to Spacific Layers
Postby thomthom » Mon Sep 28, 2009 10:49 pm
SU doesn't read the layer colour of DWGs?
Just to clarify:
1) You want to apply materials to the actual geoemtry instead of using Colour By Layers?
or
2) You want to set up a layer colour scheme which you can apply when you import DWGs?
PluginStore Author
PluginStore Author
Postby Eric_Erb » Mon Sep 28, 2009 11:55 pm
I have to do like 50 of these things a day so I'd like to automate it basically. I really don't care what method or medium I need to use as long as it will for instance apply the brick material to any layer named Wall_Surfaces whenever I open a file. It just seemed like from my research Ruby would be my best bet, but I am wide open to other options.
Eric_Erb
Postby Jim » Tue Sep 29, 2009 12:16 am
I think there's a little confusion about what exactly you need.
SketchUp has a "Color by Layer" feature built in. So i think what needs clarified is if you are using "Color by Layer" and need to assign materials to the Layers, or if you need to apply the materials to objects in the Model as a function of their Layer.
And I hope that's clearer than mud.
Jim
Global Moderator
Postby Eric_Erb » Tue Sep 29, 2009 12:19 am
I need to apply the materials to objects in the Model based on their Layer... Hopefully automatically
Eric_Erb
Postby Jim » Tue Sep 29, 2009 12:25 am
Well, that's not hard.
I would set up a template that contains your materials in-model.
Is there a relationship between the Layer names and Material names? No matter, but it would make the code smaller.
What happens when we hit a Group? Does the material get applied to the Group, or do you need to apply the materials to the entities in the Group?
What about Component Instances? Is the material applied to the Instance, the entities in the Instance, or even the Instance's Definition?
The following (untested) code might be enough to get you going. It applies materials to the top-level entities only, and does not try to drill-down into Group or Components.
Jim
Global Moderator
Postby Eric_Erb » Tue Sep 29, 2009 6:44 pm
Thank you Jim! I'm trying to make that bit of code work now. To answer your questions...I could easily rename the materials if it meant simpler code. My layer names are formatted "Wall_Surfaces", "Roof_Surface", etc. so I could rename the material on the walls "Wall_Surface" if that would help. I'm not sure what the difference is in applying a material to a group or the entities within a group. If you're asking if groups will need to include different materials for it's entities, no. All the entities within a group are the same material. Also, there is only one instance of each component.
Eric_Erb
Postby Eric_Erb » Tue Sep 29, 2009 7:32 pm
Alright, I've been messing around with the code... This is it as it is now...
module Eric_Erb
def self.color_by_layer
su_materials = Sketchup.active_model.materials
my_materials = Hash.new
my_materials["Wall_Surfaces"] = su_materials["Roofing_Metal_Standing_Seam_Red"]
my_materials["Roof_Surface"] = su_materials["Roofing_Slate_Tan"]
# .. and so on.
begin
Sketchup.active_model.start_operation("Color By Layer", true)
rescue ArgumentError
Sketchup.active_model.start_operation("Color By Layer")
# Loop through entities & apply material based on layer name
Sketchup.active_model.entities.each do |entity|
if entity.is_a? Sketchup::Drawingelement
entity.material = my_materials[entity.layer.name]
Sketchup.active_model.commit_operation
UI.menu('Plugins').add_item("Color by Layer") { Eric_Erb.color_by_layer }
I didn't add anymore Layers to apply materials to just to see if I could get it running as is. It doesn't apply materials though. The line: su_materials = Sketchup.active_model.materials, I thought that might mean "referance the materials already active in the model", so I created a couple shapes on different layers and applied the materials I wanted to use to those and when I ran the plug-in it actually removed the materials from my new layers, so I guess I interpreted that line wrong. I'm sure my error is completely obvious to people like you that can rap their heads around coding like this (which is absolutely amazing by the way), but can you tell me where I'm messing this up?
Eric_Erb
Postby RunnerPack » Wed Sep 30, 2009 8:44 am
Eric_Erb wrote:The line: su_materials = Sketchup.active_model.materials, I thought that might mean "referance the materials already active in the model", so I created a couple shapes on different layers and applied the materials I wanted to use to those and when I ran the plug-in it actually removed the materials from my new layers, so I guess I interpreted that line wrong.
No, you interpreted correctly. That is exactly what it means. The only explanation I have for the code removing materials (which I assume means setting them to the default material) is that there is a mismatch between the names of your materials or layers and the contents of your hash.
My idea would be to skip the hash and just make sure the names of layers and their respective materials are the same. i.e. anything on the "Roof" layer is painted with the material called "Roof", and so on.
Here's the code for that (which also checks if the material exists before changing it):
Code: Select all
module Eric_Erb
    def self.paint_by_layer
        mod = Sketchup.active_model
        su_materials = mod.materials
        begin
            mod.start_operation("Paint By Layer", true)
            mod.start_operation("Paint By Layer")
        Sketchup.active_model.entities.each do |e|
            mat = su_materials[e.layer.name]
            unless mat.nil?
               if e.is_a? Sketchup::Drawingelement then
                   e.material = mat
               e.back_material = mat if e.respond_to?('back_material=')
        mod.commit_operation
unless file_loaded? File::basename(__FILE__)
    UI.menu('Plugins').add_item('Paint by Layer') { Eric_Erb.paint_by_layer }
    file_loaded File::basename(__FILE__)
(As you can see, I also attached it for downloading.)
If you do stick with the hash, it may make it easier to edit if you declare it like:
Code: Select all
my_materials = {
    "Wall_Surfaces" => su_materials["Roofing_Metal_Standing_Seam_Red"],
    "Roof_Surface" => su_materials["Roofing_Slate_Tan"]
    # .. and so on.
Also, when testing, don't paint the objects beforehand. Just make some layers, make a material for each layer with the same name, make a face on each layer, and run the script.
I hope that helps.
You might have noticed... I'm a bit of a ferpectionist.
RunnerPack
Postby Eric_Erb » Wed Sep 30, 2009 5:13 pm
Thank you RunnerPack, I'll try that approach right now. Yes, I did mean setting them to the default materials
Eric_Erb
Postby Eric_Erb » Wed Sep 30, 2009 5:46 pm
On Sketchup Load it's returning... undefined method `file_loaded' for main:Object. is there something here I'm supposed to change before I save it to plugins? By the way unless it will crash the script otherwise, there's no need for the script to make sure there's a material that matches the layer name before it runs. Like I said... The Layers are always named the same so when I create materials named after the layer names there will always be a material for each of the layers.
Eric_Erb
Postby bagatelo » Wed Sep 30, 2009 11:19 pm
I want a plugin that deletes some materials of the scene, even if they are in use, in a similar way that as we deleted several emails in our email account. Maybe if it was possible to substitute several materials for one in one time, this would be also interesting. Another thing that I want would be the possibility of add a word or number in begin of all the materials of the object or scene.
"I'm organizing my library components from SketchUp, and because I use V-Ray to render my images, I put useful components names of the materials under the name of the component, to edit in V-Ray."
So, I wonder if it would be possible to create a script that renames the materials of these components according to some criteria. For example, suppose that I am editing a component called "table 045.skp" and it has the following materials: mapple wood, metal, white paint, etc.. After we run the script, the material would have the following names, such as:
wood mapple >> "wood table 045 01",
Metal >> "wood table 045 02",
white paint >> "wood table 045 03"
The reason for this is that it's confusing to locate in the scene the names of the materials of the componentes for editing in Vray.
Thanks...
bagatelo
Postby honoluludesktop » Wed Sep 30, 2009 11:47 pm
Amos, or anyone, can your code be easily modified to apply textures (by their name) to components (by their name) while ignoring all other entities (surfaces, components with names that do not match textures, groups, etc.)?
honoluludesktop
In Remembrance
Postby RunnerPack » Thu Oct 01, 2009 1:03 pm
Eric_Erb wrote:On Sketchup Load it's returning... undefined method `file_loaded' for main:Object. is there something here I'm supposed to change before I save it to plugins?
Oops! Put the following line at the top:
Code: Select all
require 'sketchup'
Well, it's always good coding practice to put in as much error handling as one can. Ideally (though not necessary in this simple script) one should use begin...rescue...end blocks to trap and handle errors in a clean manner. Besides, this script could be handy for others who may not want to make sure every layer has a material, and vice versa, just to keep it from wiping out their already-assigned materials. :D
RunnerPack
Postby RunnerPack » Thu Oct 01, 2009 1:15 pm
@bagatelo:
Ignoring the fact that you hijacked the thread... ;) I suggest you look at the code posted so far, at the code of some related plugins, and at the SketchUp Ruby API docs, and see if you can come up with something that does what you want. Your idea sounds like a simple extrapolation of the code above. If you start your own thread, I and other Rubyists can answer specific questions as you go.
You may find that you really enjoy programming in Ruby. I certainly do! :D
@honoluludesktop:
Yes, that would be quite simple. Just change the test for Sketchup::Drawingelement to Sketchup::ComponentInstance and e.layer.name to either e.name or e.definition.name. You might want to put in another test for Groups, too.
RunnerPack
Postby Eric_Erb » Thu Oct 01, 2009 5:26 pm
RunnerPack wrote:this script could be handy for others who may not want to make sure every layer has a material, and vice versa, just to keep it from wiping out their already-assigned materials. :D
Sorry, I didn't think about people not wanting to replace all the materials on every layer. Thank you so much RunnerPack. You have been a life saver... Now I just gotta read the little book of ruby a few more times (I just finished the second read) last night), and maybe this will finally click. You know I didn't have near the same difficulty learning AS3 or HTML.
Eric_Erb
Postby honoluludesktop » Thu Oct 01, 2009 9:33 pm
Amos, Thanks, I will give it a spin the next time I have a model that I import by component/texture into my model:-) Btw, I am more of a hacker then a Ruby programmer, any hints on "another test for groups" is welcomed.
honoluludesktop
In Remembrance
Postby RunnerPack » Fri Oct 02, 2009 8:26 am
Eric_Erb wrote:...Thank you so much RunnerPack. You have been a life saver... Now I just gotta read the little book of ruby a few more times (I just finished the second read) last night), and maybe this will finally click. You know I didn't have near the same difficulty learning AS3 or HTML.
You're quite welcome. (I didn't even do much, really...)
If you can make sense of ActionScript, I'm confident you'll learn Ruby in short order. Not to brag, but I haven't read any books on Ruby; I just keep the reference docs handy. And those are from Ruby 1.4.6. :P
I guess I just learn better by doing, and Ruby makes that process very fast.
RunnerPack
Postby RunnerPack » Fri Oct 02, 2009 8:45 am
honoluludesktop wrote:Amos, Thanks, I will give it a spin the next time I have a model that I import by component/texture into my model:-) Btw, I am more of a hacker then a Ruby programmer, any hints on "another test for groups" is welcomed.
I just meant to add another "if" statement to test for Group entities. It's necessary if you use e.definition.name, since Groups don't have definitions. But it would actually take a bit of code refactoring, like so:
Code: Select all
module Eric_Erb_and_AJB
    def self.paint_by_name
        begin
            begin
                mat = su_materials[e.definition.name]
            rescue
                mat = su_materials[e.name]
            unless mat.nil?
                if e.is_a? Sketchup::ComponentInstance or e.is_a? Sketchup::Group then
                    e.material = mat
    UI.menu('Plugins').add_item('Paint by Layer') { Eric_Erb_and_AJB.paint_by_name }
RunnerPack
Postby honoluludesktop » Fri Oct 02, 2009 10:46 am
Amos, Thanks. Am currently at home. Will work on it at the office tomorrow.
honoluludesktop
In Remembrance
Postby honoluludesktop » Sat Oct 03, 2009 3:11 am
Amos, Thanks, this is a big help for me. Any reason why (sometimes) I have to click on the display after the plugin has run in order for the textures to change? Hmm... Sometimes I change the component name from different menus, or change the texture name from diferent menus. Does it matter?
honoluludesktop
In Remembrance
Postby bagatelo » Sat Oct 03, 2009 7:12 pm
Inside the Vray Plugin have tool to apply materials to specific layers.
bagatelo
Postby Didier Bur » Mon Oct 05, 2009 12:01 pm
This one may help you too: layers_materials.rb to be found at the Ruby Library Depot, "layers Selection"page.
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby austinryan » Wed Aug 05, 2020 2:26 pm
Man I thought python and Dynamo were hard. I even had a go at lisp but for some reason I cant get my head a round ruby. I like the code above but want to use the clean code but also just add in the layer names and leave the other ones alone. It seams that when I run this it converts all the layers in the model to Default and then the layer color had to be the same as the material name. I like the hash option but cant seem to get it to run on transparent materials and it only paints 1 side. any suggestions
P.S. I am bringing in a dwg (exported from Revit) with 20 or so layers and want to put all the layers to 1 color but windows I want them to be on Translucent Glass Gray
F.E. all layers to color 123_White except 0_EX_Glazing it needs to be on Translucent Glass Gray
Some of the issues
1. the import comes in as 1 group (with layers in the group)
2. some of the groups come in the main group with groups within groups (doors and Door windows)
Objects come in with a material not defined (<auto1>)so a generic material must be placed on all the objects for the script to have a chance.
Thanks in advance
austinryan
Return to Developers' Forum
Users browsing this forum: No registered users and 7 guests
