Move groups with different measures?
• Page 2 of 2 • 1, 2
Re: Move groups with different measures?Funny thing
Re: Move groups with different measures?Some tests
Press "Eval" button and have fun Veyron model is from 3Dwarehouse!
Re: Move groups with different measures?Looking good Pilou!
Instant assembly drawings! Thomas Thomassen — SketchUp Monkey & Coding addict
Alas for the inverse, that must be more tricky! Better is use the Undo
Re: Move groups with different measures?hm... You could store the relative position you move the entities by in and attribute dictionary. Then perform the opposite when you want to reassemble.
though, that will fail if the user moves anything... Maybe, you could store the original absolute position before you move stuff. Then you can reassemble back to that original position. That would allow the user to move things around as they please. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: Move groups with different measures?In theory that must be more easy
Just select that you want and apply a "negative" translation : a deflation Maybe my next And the above is not yet perfect! The Pivot Point seems not have the wished result wanted be continued... Ps When Groups or Components are nested how to process automatically? A plug for make each components individual is maybe existing? Edit one exist for group by TIG Explode2groups miss now somethings transform Transform2goups or Explode2Components Last edited by Pilou on Thu Jul 16, 2009 10:24 pm, edited 1 time in total.
Re: Move groups with different measures?Store the original transformation in a dictionary attached to the group/component. Then to unexplode, just re-apply that transformation onto the group. It will go right back where it belongs.
I wrote that crazy scrambler script a while ago that does this and it worked very well. Chris
Re: Move groups with different measures?@Chris Any chance to see it somewhere?
PS A plug for make each components individual is maybe existing? Edit one exist for group by TIG Explode2groups miss now somethings for components Transform2goups or Explode2Components
Re: Move groups with different measures?take the componentInstance, add it to a group, then explode the component instance.
And I posted my scrambler script here. I'll see if I can find the thread. Chris
Re: Move groups with different measures?@Chris thx for the Info
Fredo6 has inside the FredoScale something who transform any selection of groups or Components in "Unique" groups or componants! (each become individual) (last icon)
