SketchUcation Plugin Store
Move groups with different measures?
Postby Pilou » Thu Jul 02, 2009 10:59 am
Say I have some groups
How move these different groups with a different move (here on the Z)
After reading tons of examples (and of course don't find the good :roll: and try tons of differents things :roll: (I am totally ruby maker beginner) :roll:
I have made that but don't know yet with what replace these damned ??? :mrgreen:
Ps Curious that the code text don't respect my original indentation (second loop groups.each ) :o :?:
EDIT you can find these 2 brilliant plugins inside the thread here ;)
Undrop Multiple
Explosion
Code: Select all
model = Sketchup.active_model
entities = model.entities
selection = model.selection
groups = []
z=0
entities.each do |e|
  groups.push e if e.is_a? Sketchup::Group
groups.each do |e|
 z= z + 100
 point = Geom::Point3d.new 0,0,z
 t = Geom::Transformation.new point
Speedy Galerie
Pilou
Top SketchUcator
Operating system: Windows
SketchUp version: 6
License type: Free
SketchUp use: hobby
Level of SketchUp: Advanced
Re: Move groups with different measures?
Postby TIG » Thu Jul 02, 2009 11:14 am
Try this...
Code: Select all
def movegallgroupsup100mm()
 model=Sketchup.active_model
 ents=model.active_entities
 groups=[];ents.each{|en|groups.push(en)if en.kind_of?(Sketchup::Group)}
 groups.each{|gp|
  tra=gp.transformation.to_a
  # Z value is at position 14 ###...
  tra[14]=tra[14]+100.mm ### or whatever increment desired
  ### they each move up by 100mm from where they are currently...
  gp.transformation=tra
end#def
To move them all to z=0 simply substitute
Code: Select all
tra[14]=0.0
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby thomthom » Thu Jul 02, 2009 11:19 am
.is_a? is much faster then .typename
I think that for your original code Pilou, you could write e.transform!(t) where you got the ???.
So we got a new scripter, eh? :)
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Thu Jul 02, 2009 11:23 am
You don't have to do one loop to filter out the groups and then one to process them. That isn't too efficient.
Code: Select all
groups = []
z=0
  # Skip all entities that aren't groups
  next unless e.is_a? Sketchup::Group
  # Now we process the groups
  z += 100 # self increments can be written shorter like this
  # Apply the transformation
  e.transform!(t)
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Thu Jul 02, 2009 11:32 am
thomthom wrote:e.is_a(Sketchup::Group) is much faster then e.typename=="Group"
I think that e.kind_of?(Sketchup::Group) has also just
beaten e.is_a(Sketchup::Group) in some intensive testing ???
We are only talking of perhaps a fraction of a second more for moving several groups... however, if you are applying this to a large model with hundreds/thousands then obviously the quicker methods will reduce the processing by quite appreciable times...
There's a typo in your code too groups.each do |e|...
should be entities.each do |e|... as you have and empty array 'groups'...
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Thu Jul 02, 2009 11:40 am
I did some further testing on that testcase: viewtopic.php?f=180&t=19576&start=15
.is_a some times came out faster than .kind_of? . But these two methods are aliases of the same method. So they should be identical. So I expect that the difference in values is due to other system operations while testing.
And I'm surprised that testing the class isn't faster than both of the other two as it's a stricter match.
If you look at the Ruby Source code for .class: http://www.ruby-doc.org/core/classes/Ob ... ml#M000376
Code: Select all
 *  call-seq:
 *     obj.class    => class
 *  Returns the class of <i>obj</i>, now preferred over
 *  <code>Object#type</code>, as an object's type in Ruby is only
 *  loosely tied to that object's class. This method must always be
 *  called with an explicit receiver, as <code>class</code> is also a
 *  reserved word in Ruby.
 *     1.class      #=> Fixnum
 *     self.class   #=> Object
VALUE
rb_obj_class(obj)
    VALUE obj;
    return rb_class_real(CLASS_OF(obj));
While .is_a? / .kind_of? do more processing:
Code: Select all
 *  call-seq:
 *     obj.is_a?(class)       => true or false
 *     obj.kind_of?(class)    => true or false
 *  Returns <code>true</code> if <i>class</i> is the class of
 *  <i>obj</i>, or if <i>class</i> is one of the superclasses of
 *  <i>obj</i> or modules included in <i>obj</i>.
 *     module M;    end
 *     class A
 *       include M
 *     end
 *     class B < A; end
 *     class C < B; end
 *     b = B.new
 *     b.instance_of? A   #=> false
 *     b.instance_of? B   #=> true
 *     b.instance_of? C   #=> false
 *     b.instance_of? M   #=> false
 *     b.kind_of? A       #=> true
 *     b.kind_of? B       #=> true
 *     b.kind_of? C       #=> false
 *     b.kind_of? M       #=> true
VALUE
rb_obj_is_kind_of(obj, c)
    VALUE obj, c;
    VALUE cl = CLASS_OF(obj);
    switch (TYPE(c)) {
      case T_MODULE:
      case T_CLASS:
      case T_ICLASS:
        break;
      default:
        rb_raise(rb_eTypeError, "class or module required");
    while (cl) {
        if (cl == c || RCLASS(cl)->m_tbl == RCLASS(c)->m_tbl)
            return Qtrue;
        cl = RCLASS(cl)->super;
    return Qfalse;
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Thu Jul 02, 2009 11:44 am
On average testing the .class come out similar, which I think might be due to the types of things we test. It'll usually short-circut returning true on the first iteration of the loop. So there probably has to be a much great number of iterations of the methods to see a real difference.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Thu Jul 02, 2009 11:47 am
@ Tig Some cryptic but I will see that ;)
Joint an image for no ambiguities
So here the increment is 300 cm
Edit sorry I have not seen all these speedy results! :oops:
@Thomthom! Yes that is that ! e.transform!(t) ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby thomthom » Thu Jul 02, 2009 12:01 pm
TIG wrote:There's a typo in your code too groups.each do |e|...
Ooops! Corrected. :thumb:
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Thu Jul 02, 2009 12:17 pm
Just to find now apply that just only for a selection! :)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby TIG » Thu Jul 02, 2009 12:19 pm
Pilou wrote:à Tig Some cryptic but I will see that ;)
My method adds '100mm' to each group's Z and moves then to suit: the other way with 'z+=100.mm' increments z by 100mm each step through the loop so then the groups get progressively further apart !
If you want to move all groups a certain amount use my way, if [for some unfathomable reason] you want to do a pseudo-grow then increment the offset each time...
My method finds each group's transformation [as an array], changes just its Z value and then resets it: the other way invents a new transformation and applies it to the group...
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Thu Jul 02, 2009 12:23 pm
Pilou wrote:Just to find now apply that just only for a selection! :)
Code: Select all
    entities = model.active_entities
    ###groups = [];entities.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup::Group)}###
    groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup::Group)}
    groups.each{|group|
      transformation_as_array = group.transformation.to_a
      transformation_as_array[14] = transformation_as_array[14] + 100.mm
      ### or whatever increment is desired
      group.transformation = transformation_as_array
end#def
Note that I've keep making the array of groups separate from the loop though the selection - changing them - since this way allows you to do other things to that array later if desired... e.g. groups[0].material="Red"###colours the first group red !
PS: The test definition 'movegallgroupsup100mm' is optional !!! ;)
To test your code I suggest you type this in the Ruby-Console [assuming the file is called "tester.rb"]
load"tester.rb";movegallgroupsup100mm
this will load and run the script... if it's not doing what you expect then change the script and copy+paste the line back into the console and it will load/run repeat... etc etc
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Thu Jul 02, 2009 1:10 pm
@Tig
I have the "Web console" so no problem for copy/ past and launch it
Seems your plug move all selection of groups, but not each by each :)
Result stay grouped without interval
What is precisely this "14" value?
( i have just 5 group and one component (Bryce) for the moment and just 3 selected for the test ;)
Why not take the first value of the array?
The ThomThom method works except that woks for the 5 groups and not only for the selection :)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby thomthom » Thu Jul 02, 2009 1:15 pm
Code: Select all
groups = []
z=0
selection.each do |e| # update!
  e.transform!(t)
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Thu Jul 02, 2009 1:31 pm
Code: Select all
groups = []
z=0
  e.transform!(t)
  z = z*2 + 100
Perfect :thumb: (I put the z=z*2+100 at the end for have the first group of selection with no move)
Last thing I obtain 254 cm ( I suppose that is a conversion between inch/cm ?)
My first volume is at level z = 0 and I work in cm
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby thomthom » Thu Jul 02, 2009 1:33 pm
SU always uses inches internally.
If you want 100mm type 100.mm . See http://code.google.com/intl/nb/apis/ske ... meric.html for more units.
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Thu Jul 02, 2009 1:55 pm
Pilou
Do you want to move each of the selected groups by the same amount (my code - e.g. 100.mm) or by an ever changing amount ?
If you want it to change then you need to define how, and add this into the loop - e.g. z=1..... then loop... z += 2*z
exponential type increase !
If you are applying different offsets, and you have made the groups in order, then the increments will apply in that way; but it would be possible to 'stack' groups made at different times and the loop would process then in their made order, but not the 'stacked' order you want ! Perhaps you need to add in another test... for each of the group.bounds.min.z. which sorts them by their relative heights, so at least the groups array would be in the height order you expect...
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Thu Jul 02, 2009 2:04 pm
Yes! Works like a charm! :enlight:
For my first one that was not like a true romance but with your help, ThomThom, Tig (yet a lot of cryptic for me :), and the Chris tutorial and a dash of milk of Tod Burch
Many thx for the helps :fro:
Next will maybe an "explode view" of several groups :)
Just need to know position of a group :)
PS @ Tig Sorry but I had no chance with yours! (see previous page) :shock:
And yes I want any sort of increments so now I can have any sort of it! Thx! :enlight:
Just play with parameters :)
I keep your group.bounds.min.z. trick in my mind!
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby TIG » Thu Jul 02, 2009 2:51 pm
for a completely random offset try
Code: Select all
    ###point = Geom::Point3d.new 0,0,(1000.mm * rand)
    ### offset in Z somewhere between 0m and 1m - 'rand' makes a random number 0><1
    point = Geom::Point3d.new (1000.mm * rand),(1000.mm * rand),(1000.mm * rand)
    ### offset in all XYZ axes by 0 to 1m
    e.transform!(t)
Swap the ### between the different points = to see the effect
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Thu Jul 02, 2009 2:58 pm
Before testing your new randomizer plug :)
I have a little problem :)
I have used "Grow" by Tig for make the "volume" on the left (50 groups), then my "Plug" Thomthomised :roll:
with a normal interval of course!
Seems there is something wrong somewhere :o
Groups are not recorded following the "grow" generation?
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby thomthom » Thu Jul 02, 2009 3:01 pm
The entities are not returned in their order in z height. You would need to sort the objects by their Z position before applying the transformations.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Thu Jul 02, 2009 3:18 pm
So i must use the Tig Advertissement more soon than I have expected :mrgreen:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby Pilou » Thu Jul 02, 2009 3:38 pm
This group.bounds.min.z. can be found somewhere or the sorting of Groups must be forged again?
(nothing about sort, sorting in the API helping) :o
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby thomthom » Thu Jul 02, 2009 3:48 pm
Build a hash with the entities as the key and their Z posiiton as value and then sort the hash by the values.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Thu Jul 02, 2009 4:05 pm
Each groups has not a "time creation" trace board? So no need to remake a sorting ?
Seems I have re-open a new nightmare door :mrgreen:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby Chris Fullmer » Thu Jul 02, 2009 5:23 pm
Awesome Pilou! Keep it up, its looking great. You've got lots of good help around here.
Chris
All my Plugins I've written
SketchUp Team
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Postby TIG » Thu Jul 02, 2009 5:39 pm
Try something like...
Code: Select all
zeds=[]
index=0
groups.each{|group|
   zeds.push(group.bounds.min.z, index)
   index+=1
zeds.sort!
sorted_groups=[]
zeds.each{|z|sorted_groups.push(groups[z[1]]) }
### sorted_groups is now groups sorted by Z
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Thu Jul 02, 2009 6:02 pm
Does the group.bounds.min.z only valuable in SU 7?
Edit seems not :)
little try but seems I miss something :) (any doubt selection but the sorted_groups gives nothing on the screen)
Code: Select all
groups = []
z=0
zeds=[]
index=0
groups.each{|group|
   index+=1
zeds.sort!
sorted_groups=[]
sorted_groups.each do |e|
  e.transform!(t)
  z =  z + 1000.mm
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby TIG » Thu Jul 02, 2009 6:58 pm
groups = [] then nothing set !!!
You emptied the groups array...
You need to fill it from the selection... :geek:
Code: Select all
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Thu Jul 02, 2009 7:40 pm
it's like a snowball on the top of the mountain :D
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Next
Return to Developers' Forum
Users browsing this forum: -jandalf- and 7 guests
