SketchUcation Plugin Store
[Catalog] Matt666
[Catalog] Matt666
Postby Matt666 » Wed May 20, 2009 9:18 am
Hi all!
I decided to create a topic containing all scripts I wrote. I don't know if it's a good idea, but I like it... Here we go!
For many, these scripts have been published on this site. Some were created as a result of requests. Many have evolved as a result of testing and suggestions, thank you to all who participated.
EDIT 20120202: Change topic title (thank you Dan Rathbun)
EDIT 20120201: Normalize tool added
  • Cartouche
    Description: Create a cartouche (title block) with informations contained in the drawing title.
    Toolbar: Yes.
    Localization:
    • Menu Plugins/Cartouche/Add
    • Menu Plugins/Cartouche/Settings
    • Menu Plugins/Record existing cartouche
    • Help
    Command: 'Matt_Tools::Cartouche::go' & 'Matt_Tools::Cartouche::settings'. Commands appear in the ruby console when tool is activated.
  • Component/Groups tools
    Description:
      A set of tools to play with components and groups.
    • Make a group of just one entity (right click or menu plugins/Make group)
    • Make a component instance of just one entity (right click or menu plugins/Make component)
    • Convert each entity in the selection in a single group (right click or menu plugins/Convert on single groups)
    • Convert each entity in the selection in a single component (right click or menu plugins/Convert on single components)
    • Convert the selected component into a group (right click or menu plugins/Make group)
    Toolbar: No.
    Localization:
    • Menu Plugins/Convert in single components
    • Menu Plugins/Convert in single groups
    • Menu Plugins/Make component
    • Menu Plugins/Make group
    • Context menu/Convert in single components
    • Context menu/Convert in single groups
    • Context menu/Make component
    • Context menu/Make group
    Command: 'Several'
  • Components to groups
    Description: Converts all components to groups.
    Toolbar: No.
    Localization: Menu Plugins/Components to groups
    Command: c2g
  • Extend tool
    Description: extend edge you pointed on. It tries to work like acad Extend tool...
    Toolbar: No.
    Localization:
    • Menu plugins/Extend edges
    • Context menu/Selection/Extend edges
    Command: Matt_Edges.extend
  • Face 2 face
    Description: Redefine current view to the normal of the selected face.
    Toolbar: No.
    Localization: Context menu/Face2Face
    Command: Sketchup.active_model.select_tool Face2Face.new
  • Last entity drawn
    Description: Select last entity drawn.
    Toolbar: No.
    Localization: Menu Plugins/Select last entity drawn
    Command: entlast
  • Normalize
    Description: Puts entities to layer 0. Possibility to filter entity type to normalize by entering a web dialog.
    Toolbar: No.
    Localization:
    • Menu Plugins/Matt_Normalize/All
    • Menu Plugins/Matt_Normalize/Selection
    • Menu Plugins/Matt_Normalize/Filter options
    Command: 'Several'
  • Point
    Description: Draw a points by left-clicking or giving a distance.
    Toolbar: Yes.
    Localization: Plugins/Draw points
    Command: pointtool
  • Polar line
    Description: Draw a line with polar method.
    Toolbar: Yes.
    Localization: Menu Plugins/Polar line
    Command: polarline
  • Purge
    Description: Purge model. One step less than TIG script.
    Toolbar: yes.
    Localization: Menu Plugins/Purge
    Command: purger
  • Recall last tool
    Description: Recall last tool used.
    Toolbar: No.
    Localization: Menu Plugins/Recall last tool
    Command: Matt_Observer.recall_last
  • Reinit scale
    Description: Reinit scale of selected components.
    Toolbar: No.
    Localization: Context menu/Reset scale
    Command: scale_reinit
  • Remove group materials
    Description: Remove group materials but leave geometry material. Possbility to put group material on 'unmaterialed' geometry
    Toolbar: No.
    Localization: Menu Plugins/Remove C-G materials
    Command: Matt_Tools.remove_CG_mat
  • Selection_Manager
    Description: Manage (add, remove, etc) current selection.
    Toolbar: No.
    Localization:
    • Menu Plugins/Selection/Selection manager
    • Menu Plugins/Selection/Selected edges by angle
    • Menu Plugins/Selection/Selected edges by user-defined angle
    • Context menu/Selection/Selection manager
    • Context menu/Selection/Connected edges by angle
    Command: Matt_Tools.selection_manager
  • Shadow_now
    Description: Puts shadows on actual time.
    Toolbar: No.
    Localization: Menu Plugins/Shadows=Now!
    Command: Matt_Shadows.now
  • Soften/Unsoften
    Description: Soft / Unsoft edges in one action.
    Toolbar: Yes.
    Localization:
    • Menu Plugins/Soften edges/Soften
    • Menu Plugins/Soften edges/Soften all
    • Menu Plugins/Soften edges/Unsoften
    • Menu Plugins/Soften edges/Change normal angle
    Command: Several
  • Statistics
    Description: Returns a report of all entities in the current selection
    Toolbar: No.
    Localization:
    • Menu plugins/Selection/Deep stats
    • Menu plugins/Selection/Simple stats
    • Context menu/Selection/Deep stats
    Command:
    • Matt_Selection.stats false (for a simple report)
    • Matt_Selection.stats true (for a deep report)
  • Toggle units
    Description: Change drawing units and precision quickly.
    Toolbar: Yes.
    Localization:
    • Menu Plugins/Toggle units/Decimal
    • Menu Plugins/Toggle units/Architectural
    • Menu Plugins/Toggle units/Fractionnal
    • Menu Plugins/Toggle units/Ingeniery
    • Menu Plugins/Toggle units/Feet
    • Menu Plugins/Toggle units/Inch
    • Menu Plugins/Toggle units/Millimeter
    • Menu Plugins/Toggle units/Centimeter
    • Menu Plugins/Toggle units/Meter
    • Menu Plugins/Toggle units/Decrease precision
    • Menu Plugins/Toggle units/Increase precision
    • Menu Plugins/Toggle units/Display format
    Command: 'Several'
  • Zoom selection
    Description: Zoom on selected. Works inside groups / Components.
    Toolbar: No.
    Localization: Context menu/Zoom on selected
    Command:zSel
Frenglish at its best !
My scripts
Matt666
Re: All my scripts
Postby Pilou » Wed May 20, 2009 10:00 am
My favorite : selection-manager :enlight:
Speedy Galerie
Pilou
Top SketchUcator
Operating system: Windows
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Level of SketchUp: Advanced
Re: All my scripts
Postby Chris Fullmer » Wed May 20, 2009 4:20 pm
Looks great Matt! Its nice to be able to see them all in one place with descriptions,
Chris
All my Plugins I've written
SketchUp Team
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Re: All my scripts
Postby modelhead » Wed May 20, 2009 4:29 pm
Now that has been a great effort!! Thanks for your kind contributions. This one needs a bookmark....and what a valuable deposit....cheers to you!!
modelhead
Re: All my scripts
Postby Chris Fullmer » Wed May 20, 2009 4:34 pm
I've noticed a bunch of the script-writers have links to all their plugins in their sigs - beneath each of their posts. So you can always check there too Bruce if you're looking!
Chris
SketchUp Team
SketchUp version: 8
License type: Pro
Re: All my scripts
Postby modelhead » Wed May 20, 2009 4:42 pm
Hey thanks Chris!
modelhead
Re: All my scripts
Postby CadFather » Wed May 20, 2009 5:14 pm
that was a bit of time travel - great scripts and quickly written too.. Thanks Matt : )
(just need to think of a new request now......)
Quarr-IT - SketchUp Training from the Master.. . ;) .
CadFather
Re: All my scripts
Postby Edson » Wed May 20, 2009 5:37 pm
great idea, matt. i assume you will update it everytime you create a new plugin. and thanks for all the ones already available.
edson mahfuz, architect
http://www.mahfuz.arq.br
Anyone can get you more for more, but it takes genius to get you more for less.
Edson
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Re: All my scripts
Postby Matt666 » Fri May 22, 2009 3:50 pm
Thank you all!
My scripts
Matt666
Re: All my scripts
Postby dtrarch » Fri May 22, 2009 5:39 pm
Thank you, thank you, thank you :berserk:
Really good work
dtr
dtrarch
Premium Member
Premium Member
Re: All my scripts
Postby urgen » Fri May 22, 2009 6:07 pm
...hi,Matt,good idea! :thumb: :D ...but "PURGE"page is absent... ;) ..."PURGE" only...
--------------------------------------------------I see also it ...
..Discussion about it------> viewtopic.php?f=180&t=13067&p=95518&hilit=+purge#p95518
--pupil forever...------
urgen
Re: All my scripts
Postby Matt666 » Sat May 23, 2009 1:22 am
Yes, I put this plugin on the french forum...
Perhaps I will create a new thread inside ruby forum...
Thank you urgen!
My scripts
Matt666
Re: All my scripts
Postby Matt666 » Mon Jun 22, 2009 11:01 am
Plugins "Statistics" and "Extend tool" added to the first post.
My scripts
Matt666
Re: All my scripts
Postby Matt666 » Tue Jan 31, 2012 11:05 am
Plugin "Nomalize" added in the first post.
My scripts
Matt666
Re: All my scripts
Postby Dan Rathbun » Thu Feb 02, 2012 7:25 am
The topic title could be more specific.
[Catalog] Matt666
I'm all for organization. Very well done.
Dan Rathbun
Top SketchUcator
SketchUp version: 2013
License type: Pro
SketchUp use: education
Re: All my scripts
Postby Matt666 » Thu Feb 02, 2012 9:00 am
Ah! That's a good idea!
My scripts
Matt666
Artisan Organic Toolset - a set of powerful organic modeling tools.
Return to Plugins
Users browsing this forum: azooznasser, josua7169194, k_yoshi, Scorpio0911, Spookydad, Tokador and 6 guests
