New API doc - typos and questions
Re: New API doc - typos and questions
Postby thomthom » Thu Mar 11, 2010 9:21 am
How about - when the issues from this thread has been addressed we lock and unstick it?
(I can move some posts around later on.)
PluginStore Author
PluginStore Author
Postby tobiaskordts » Thu Mar 11, 2010 10:14 am
TextureWriter.write_all
http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/texturewriter.html#write_all
Sketchup Ruby API wrote:Arguments:
entity: A face, image, component instance, group, or layer to write.
dirname: The directory to write to.
side: If the entity is a face, the side is used to indicate the side of the face being written (true if front, false if back.)
Returns:
The third parameter is wrong. True activates the 8.3 file naming convention, false for extended filenames.
tobiaskordts
Postby Dan Rathbun » Thu Mar 11, 2010 10:20 am
thomthom wrote:How about - when the issues from this thread has been addressed we lock and unstick it?
I can move my suggestions over to the 'API WishList' thread. It seemed easier to voice them at the time I noticed the errors (I always added them after stating the errors in a different color.)
But I can understand how all the extra 'noise' makes using the thread as a checklist difficult for the GSUPT (Google Sketchup Product Team.)
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby ScottLininger » Thu Mar 11, 2010 5:18 pm
    Dan Rathbun wrote:
    ScottLininger wrote:As soon as we close out the issues in this thread, I will remove it from the forums.
    Don't you dare!
    :D
    All great points, Dan. There is a valuable historical record here, and there are a lot of posts that aren't simple docs corrections. No reason to remove it. More what I'm getting at is to make it clear where different kind of posts are best shared, as you said. This is the community's site, not mine, so ultimately it's the community's decision! :)
    Cheers,
    - Scott Lininger
    SketchUp Software Engineer
    Have you visited the Ruby API Docs?
    ScottLininger
    Postby tomasz » Fri Mar 26, 2010 12:08 pm
    Model.select_tool
    Arguments:
    tool - The Tool object you want to select.
    Returns:
    tool - A Tool object. False! It returns Sketchup::Model
    tomasz
    SU2TH & SU2KT Developer
    Postby cjthompson » Fri Mar 26, 2010 1:10 pm
    http://code.google.com/apis/sketchup/do ... sify_point
    The classify_point method is used to determine if a given Point3d is on your face. The return value will be from this list:
    0: PointUnknown,
    1: PointInside,
    2: PointOnVertex,
    4: PointOnEdge,
    8: PointOnFace,
    16: PointOutside
    the list should be:
    0: PointUnknown,
    1: PointInside,
    2: PointOnEdge,
    4: PointOnVertex,
    8: PointOnPlane,
    16: PointOutside
    cjthompson
    Postby thomthom » Fri Mar 26, 2010 1:12 pm
    cjthompson wrote:http://code.google.com/apis/sketchup/docs/ourdoc/face.html#classify_point
    the list should be:
    0: PointUnknown,
    1: PointInside,
    2: PointOnEdge,
    4: PointOnVertex,
    8: PointOnPlane,
    16: PointOutside
    What?? ... I need to check some of my plugins...
    PluginStore Author
    PluginStore Author
    Model.get_product_family
    Postby Dan Rathbun » Tue Mar 30, 2010 11:46 am
    http://code.google.com/apis/sketchup/docs/ourdoc/model.html#get_product_family
    This thread gives a second-hand indication that Model.get_product_family is deprecated and "might be removed from the API at any time."
    So the question(s) I have is:
    Is it ( Model.get_product_family ) really to be considered as deprecated ??
    And if so, should not the API doc (link above,) mention this ( and perhaps direct coders to use Sketchup.is_pro? instead ) ??
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby tomasz » Tue Apr 13, 2010 9:23 am
      WebDialog.set_full_security=
      The set_full_security= method is used to place the WebDialog into a higher security mode where remote URLs and plugins (such as Flash) are not allowed inside the browser. This defaults to false when a new WebDialog is created.
      This method does not exist. There is set_full_security BUT It doesn't take arguments!! Also I am not sure if it defaults to false on MAC since it doesn't display Flash while under Windows it does.
      tomasz
      Postby Dan Rathbun » Wed Apr 14, 2010 11:33 am
      Also the API code example has nothing to do with this method.
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Postby Dan Rathbun » Fri Aug 13, 2010 12:46 am
        REPOST: from Mon MAR 08, 2010
        The web page has still not been fixed.
        API - Release Notes webpage error
        http://code.google.com/apis/sketchup/docs/releases.html
        The H2 Heading "What's new in SketchUp 7" is not displayed as a H2 heading.
        The error is caused by a missing '>' (greaterthan character) on the end of the preceeding <P> element closing tag, which is now: '</P'
        ie, snippit from current HTML source (line 378):
        <p class="post">&nbsp;</p
        <h2>What's new in SketchUp 7</h2>
        "What's new in SketchUp 7" should be rendered the same as:
        "What's new in SketchUp 7.0 M1"
        Adding a screenshot:
          Dan Rathbun
          PluginStore Author
          PluginStore Author
          Postby Dan Rathbun » Fri Sep 03, 2010 4:03 am
          The above error on the API Release Notes webpage no longer applies since the release of Sketchup v8.0 ...
          ... because all mention of Maintainance Releases have been scrubbed from the page, including the fixes, functionality and new methods that were introduced by the MR.
          Example (see above,) Sketchup 7.0MR1 added the get_glued_instances instance method to the Sketchup::Face class, but now readers (especially those new to using the SUAPI,) will not know this by looking at this page. They'd need to notice the version on the right, of the method defintion, on the Face class page. [ie: SketchUp 7.0.10247 (M1)+]
          Did anyone save an offline archive of the API Release Notes Page ?? ( Can you attach copy to this thread if so, please. )
            Dan Rathbun
            PluginStore Author
            PluginStore Author
            Postby thomthom » Fri Sep 03, 2010 7:16 am
            *sigh* ... I only hope this is because of some restructure of the API site. Better poke a Googler just in case to make sure that info will be available somewhere.
            PluginStore Author
            PluginStore Author
            Postby Dan Rathbun » Fri Sep 03, 2010 7:43 am
            thomthom wrote:... just in case to make sure that info will be available somewhere.
            Isn't there an web archive kept by Google somewhere.. built by bots ??
              Dan Rathbun
              PluginStore Author
              PluginStore Author
              Postby Dan Rathbun » Fri Sep 03, 2010 7:45 am
              thomthom wrote: I only hope this is because of some restructure of the API site.
              I also. I'd like to see the page remade like the SU Application Release Notes page, with expanding sections for each release.
                Dan Rathbun
                PluginStore Author
                PluginStore Author
                Postby Dan Rathbun » Sun Sep 05, 2010 5:34 am
                Yes, found it (Google caches their own pages): Release Notes - Google SketchUp Ruby API - v7
                Not knowing when this cached page will be replaced (possibly the 1st of next month,) here's an offline snapshot:
                Release Notes - Google SketchUp Ruby API - v7.zip
                  Dan Rathbun
                  PluginStore Author
                  PluginStore Author
                  Postby snicolo » Thu Sep 09, 2010 9:03 pm
                  Guys, thanks for the heads up, you can blame this one on ScottL :roflmao: but also he was the one that corrected it, so I guess he is even.
                  Should be fixed shortly.
                  Simone.
                  Simone Nicolo
                  QA Manager
                  www.sketchup.com
                  snicolo
                  Postby thomthom » Fri Sep 10, 2010 8:43 pm
                  Just saw the updates. :)
                  Scott even sneaked in a UTM class - which apparently has been there since SU6??
                  PluginStore Author
                  PluginStore Author
                  Postby tomot » Mon Aug 15, 2011 10:58 pm
                  WOW! no replies for almost a year! Things must really have improved on the SketchUp API side of things .......just kidding!
                  I noticed Google is buying Motorola or 12.5 Billion today http://www.telegraph.co.uk/technology/g ... -deal.html
                  Looks like they ran out of money once again, still can't afford to hire someone to get rid of the typos in the API. :( :( :(
                  tomot
                  PluginStore Author
                  PluginStore Author
                  Postby ScottLininger » Mon Aug 15, 2011 11:03 pm
                  tomot wrote:WOW! no replies for almost a year!
                  Hey Tomot,
                  I'm still listening. :)
                  We have been making incremental fixes now and then. I'll take this ping as a useful reminder to check the thread for things we still need to do...
                  - Scott Lininger
                  ScottLininger
                  Postby thomthom » Mon Aug 15, 2011 11:16 pm
                  What would your preferred channel for API documentation issues be? This thread or the comment pages on the API pages?
                  PluginStore Author
                  PluginStore Author
                  Postby ScottLininger » Mon Aug 15, 2011 11:26 pm
                  thomthom wrote:What would your preferred channel for API documentation issues be? This thread or the comment pages on the API pages?
                  Reporting issues via the code.google.com comments tool (which you can find at the bottom of every documentation page) is better, because it warns other users right on the page.
                  - Scott Lininger
                  ScottLininger
                  Postby Dan Rathbun » Mon Aug 15, 2011 11:28 pm
                  Yea.. but the formatting sucks!
                    Dan Rathbun
                    PluginStore Author
                    PluginStore Author
                    Postby ScottLininger » Mon Aug 15, 2011 11:42 pm
                    Dan Rathbun wrote:Yea.. but the formatting sucks!
                    ...of course if you prefer to post nicely formatted stuff to this thread, that's cool, too! :D
                    - Scott Lininger
                    ScottLininger
                    Postby thomthom » Tue Aug 16, 2011 7:37 am
                    And there is some other wee issues, it quickly wraps the comments into pages, after 10 pages. And it's not always obvious.
                    The biggest problem is if you have your browser set to prefer a language over English, then you'll be presented with an empty comment page. (I think the comments are all gone.) Every time I have to install a new system, or use another computer here in Norway, and the preferred language is set to Norwegian I cannot see any of the comments.
                    I have to rearrange the preferred languages to English before I get the comments because the API doc pages forcefully redirect me to a so-called localised version for my language, even though everything is still in English.
                    So I can imagine there's many people not aware of the comments at the bottom of the API pages.
                    PluginStore Author
                    PluginStore Author
                    Postby Dan Rathbun » Tue Aug 16, 2011 11:02 am
                    It would be better to have INLINE (expandable) comment block beneath each method. I know you guys can do this because you did it on the Release notes pages.
                    Also expandable sample code block under each method.
                    Basically it needs to be more like a wiki page. Jim experimented a bit with this on his code site page.
                      Dan Rathbun
                      PluginStore Author
                      PluginStore Author
                      Postby Dan Rathbun » Tue Aug 16, 2011 11:04 am
                      HOW! ??
                      I don't think it takes markup... or does it?
                      If so. What kind? git markup? bbCode? what?
                        Dan Rathbun
                        PluginStore Author
                        PluginStore Author
                        Postby Dan Rathbun » Tue Aug 16, 2011 11:09 am
                        @Scott.. on the subject of the API... see this thread:
                        http://groups.google.com/group/sketchup ... 2d2113a894
                        Wouldn't it be better to have a DC playsound() click function appended to the the DC class?
                          Dan Rathbun
                          PluginStore Author
                          PluginStore Author
                          Postby thomthom » Tue Aug 16, 2011 11:20 am
                          Dan Rathbun wrote:It would be better to have INLINE (expandable) comment block beneath each method. I know you guys can do this because you did it on the Release notes pages.
                          ? Inline comment on the release notes?
                          PluginStore Author
                          PluginStore Author
                          Postby Dan Rathbun » Tue Aug 16, 2011 12:23 pm
                          Yes, instead of random (newest first,) ordered comments at the page bottom...
                          ... a poster would click an add note button WITHIN each method section. The note would be wrapped in a collapsed DIV or SPAN that is INLINE with the method section.
                          At the bottom of each method would be a "plus" button that has a title "Read Notes (current_num)"
                          If the user wished to get more info on that SPECIFIC method, they can click the "+" button, and the collapsed DIV would expand.
                          The same could be true for Community Contributed Sample Code Snippets. Each method could have a collapsed "snippets" section, that works in the same manner.
                          For an example of what I'm talking about.. see the Sketchup Release Notes page.
                            Dan Rathbun
                            PluginStore Author
                            PluginStore Author
                            PreviousNext
                            Return to Developers' Forum
                            Users browsing this forum: joss1995, naparat and 7 guests
