SketchUcation Premium Membership
[HowTo?] Edit Components (or change "active level")
Postby MarcioAB » Tue Dec 02, 2008 3:52 pm
Now, on SU7, that one can get the full "genealogical instances path" from your current "active level" up to the model level ( with model.active_path ).
How can I re-position my "active level" in one particular instance of this path (kind of "edit level") ? Example:
print model.active_path
#<Sketchup::ComponentInstance:0x01><Sketchup::ComponentInstance:0x02><Sketchup::ComponentInstance:0x03>
That means my current "active level" is instance 0x03.
How can I move up one level using Ruby API to make my "active level" at instance 0x02 ?
Thank you
PS1: It could be a pair of APIs like this:
model.get_active_path ( exactly the same as model.active_path)
model.set_active_path(n) where n is the number of "levels" to go up.
In the example above, model.set_active_path(1) will move the "active level" to
PS2: Today I'm using the OUTLINER to get positioned in a particular "active level". How can I do the same using Ruby API ?
Thank you
Marcio
MarcioAB
Re: [HowTo?] Edit Components (or change "active level")
Postby Matt666 » Tue May 19, 2009 11:44 am
Hi!
I am also intersted by this request... How can you set active path to a defined componant instance?
Frenglish at its best !
My scripts
Matt666
Postby thomthom » Tue May 19, 2009 11:46 am
Don't think there is one... :(
Global Moderator
Name: Thomas Thomassen
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby Jim » Tue May 19, 2009 11:48 am
Sounds like model.close_active is what you're looking for. You can "move up", but not dig deeper.
http://code.google.com/apis/sketchup/do ... ose_active
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Matt666 » Tue May 19, 2009 12:21 pm
Yes I know this method... But not its opposite! :(
My scripts
Matt666
Postby TIG » Tue May 19, 2009 12:31 pm
model.close_active ### will jump you up one 'level' out of the current edit session.
### You can only go in the direction of the base model...
### You can repeat x(model.active_path.length) to close the edit back to the base model 'level'.
### Alternatively...
model.active_path[model.active_path.length-2] ### to get up 1 level, or use -3 for 2 levels etc...
### All of these physically close any current edit sessions...
### If you just want to do something with the entities found at a particular 'level' then just use...
parent=model.active_path[model.active_path.length-2]
### i.e. the container of the current edit session's instance/group
parent_entities=parent.definition.entities if parent.typename=="ComponentInstance"
parent_entities=parent.entities if parent.typename=="Group"
### etc... there's no need to close edits etc, just specify the actual entities-set to work on...
Global Moderator
License type: Pro
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Return to Developers' Forum
