SketchUcation Plugin Store
SketchUp RUBY API Wishlist [way of coding wishes, please]
Re: Sketchup::load
Postby Dan Rathbun » Sat Jul 31, 2010 11:10 pm
Dan Rathbun wrote:Sketchup::load
The Sketchup::load method does NOT expose the wrap argument, so we can specify wrap=true for rbs scripts.
For some unknown reason, the Google team defeated, or just didn't pass the 2nd argument (wrap) on to the aliased standard load, when they overrode it to handle rbs decrypting.
Please fix this!_
Taking this a step further.
Since the rbs code blocks are eval'd, and Sketchup.load is an override (redefinition,) just pass the 2nd argument to Sketchup.load (if given,) on as the 2nd argument to the eval method.
That way developers can instantiate a binding() to their custom namespace(s), and have the code evaluated within that scope.
This can also give the GSUT the opportunity to protect some Google namespaces, within the argument validation block of the Sketchup.load method (ie: raise a custom "NotAllowedError" exception.)
Dan Rathbun
Top SketchUcator
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: education
Level of SketchUp: Advanced
Re: SketchUp RUBY API Wishlist [way of coding wishes, please
Postby Dan Rathbun » Thu Aug 05, 2010 11:04 am
EDITED: Get||Set Layer Material & Color
Added missing "wish" statement to set Layer color in the example I gave (the last statement.)
Dan Rathbun
Top SketchUcator
License type: Pro
Postby kwalkerman » Tue Aug 10, 2010 2:44 pm
Seconded on the Layers usability, also, it would be great to be able to do:
Layers.active_layer
Layers[layer] = active
A consistent entityID would be awesome. The entity should maintain the ID if it is deleted, and then undeleted as well.
Pages:
In addition to retaining information on which layers are on and off, should also be able to retain the active layer for each page.
Karen
kwalkerman
Re: active Layer via the Sketchup::Layers class
Postby Dan Rathbun » Tue Aug 10, 2010 4:46 pm
kwalkerman wrote:Seconded on the Layers usability, also, it would be great to be able to do:
Layers.active_layer
That can already be done:
Sketchup.active_model.active_layer
.. as it's a property of the model (Sketchup::Model class.)
see API: Model.active_layer
kwalkerman wrote:Layers[layer] = active
Will not work because there is no .= method defined for the Sketchup::Layer class. (You'd just be calling Ruby's internal hardcoded refererence assignment operator, which could set the layer reference on the left of the operator, to any kind of Ruby object. A bad idea, if it doesn't immediately cause an exception.)
This why the .new constructor is "hidden" (or made private,) and we create layers thru the collection class' .add method.
Sketchup.active_model.active_layer=layers['mylayername']
.. again, a property of the model (Sketchup::Model class.)
see API: Model.active_layer=
You CAN get a SKP DOM object's parent by using the .parent method. The model is the layer collection's parent, in the SKP doucment heirarchy. Where layers is the model's Sketchup::Layers class instance:
this_layer = layers.parent.active_layer
But, since each model instance, has an instance of a Sketchup::Layers class object, you'd think it (the Layers collection,) should also know which one of it's elements was active.
A simple Ruby patch for the Layers class:
Code: Select all
class Sketchup::Layers
  unless method_defined?('active')
    def active
      self.parent.active_layer
    end # def active
  unless method_defined?('current')
    alias_method('current','active')
  unless method_defined?('active=')
    def active=(arg)
      if arg.class==String || arg.kind_of?Integer
        self.parent.active_layer=self[arg]
      elsif arg.class==Sketchup::Layer
        self.parent.active_layer=arg
      else
        raise(TypeError,'Sketchup::Layer, String, or Integer expected.')
    end # def active=
  unless method_defined?('current=')
    alias_method('current=','active=')
end # class extension
EDIT:
  • added aliases
  • fixed method defintion tests
Note: The reason I do not call
Sketchup.active_model.active_layer (in the patch,) is to accomodate multi-model environment on the Mac, where the active model may not be the one a script is working on.
ADD: This can be extended to the Sketchup::Layer class, so that a layer can return (boolean) whether it is the active layer or not.
Code: Select all
  unless method_defined?('active?')
    def active?
      # .equal? returns true ONLY if receiver and arg have same object_id
      self.equal?( self.parent.parent.active_layer )
    end # def active?
  unless method_defined?('current?')
    alias_method('current?','active?')
  unless public_methods(false).include?('eql?')
    # only override if it hasn't yet been redefined
    def eql?(arg)
        # we shall ignore the name attribute
        # use the == override to include name in test
        # use <=> to test only the names (match returns 0)
        same = true
        return (same = (self.page_behavior==arg.page_behavior)) if (not same)
        return (same = (self.visible?==arg.visible?)) if (not same)
        return same
      else
        raise(TypeError,'Sketchup::Layer expected.')
    end # override eql?
Dan Rathbun
Top SketchUcator
License type: Pro
Postby thomthom » Tue Aug 10, 2010 4:52 pm
hm... never thought of that inconsistency before...
model.materials.current vs model.active_layer
Global Moderator
Name: Thomas Thomassen
License type: Pro
SketchUp use: architecture
Postby Dan Rathbun » Tue Aug 10, 2010 5:02 pm
thomthom wrote:hm... never thought of that inconsistency before...
"current and "active" should aliases for each other.
Dan Rathbun
Top SketchUcator
License type: Pro
Postby kwalkerman » Tue Aug 10, 2010 5:16 pm
Cool. Thanks again.
kwalkerman
Postby Dan Rathbun » Tue Aug 10, 2010 6:53 pm
kwalkerman wrote:Cool. Thanks again.
No problem.
(bumping the topic..)
  • Made edits to the Layers code example
  • Added a second code example for Layer class.
See previous post...
Dan Rathbun
Top SketchUcator
License type: Pro
Postby Jim » Tue Aug 10, 2010 7:17 pm
kwalkerman wrote:In addition to retaining information on which layers are on and off, should also be able to retain the active layer for each page.
I like this idea, particularly useful when adding text to Scenes. It seems quite possible using an Observer.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Jim » Tue Aug 10, 2010 8:53 pm
Well, don't leave out Pages.selected_page!
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Dan Rathbun » Tue Aug 10, 2010 11:22 pm
I don't know about that one... Pages are special. Even though you "select" a Page, depending on transition time, Sketchup can be animating somewhere between the previous page and the selected one.
A FrameChangeObserver is needed to know when the animation is complete. Only at that point would I 'technically' say that a Page was the "active_page" or "current_page."
@Karen. You can get an array of the hidden layers for a Page:
mypage.layers
so the visible layers would be:
my_vis_layers = model.layers.to_a - mypage.layers
* why they didn't name the method Page.hidden_layers, I don't know.
Dan Rathbun
Top SketchUcator
License type: Pro
Postby Dan Rathbun » Wed Aug 11, 2010 12:24 am
Jim wrote:
kwalkerman wrote:..., should also be able to retain the active layer for each page.
But when you add text to Scenes (Pages,) are you drawing to the model, or drawing to the View ??
If it's the View, then the active layer does not matter.
The active layer is a property of the model. A Scene (Page,) is a View mechanism, which does not "have" layers; it only 'remembers' which of the model's layers to hide or show. A layer also has "new page behaviour" which it can tell new Scenes (Pages,) how to 'remember' their visibilty.
I can see some problems for other scripts, if the active layer was automatically changed when a Scene changed. There would need to be some kind of toggle to turn the "auto" feature on and off.
In addition, their would need to be scoping. What if an Observer was to be triggered while this "auto layer" feature was on? Outside the current script (or scope,) the Observer may want to "see" or "use" another layer as the active one.
It also occurs to me, that we are supposed to always be drawing primitives on "Layer 0", but still some modelers want to draw on other layers (construction lines especially.)
Anyway.. we'd need to consider this carefully. It could be a disaster.
Dan Rathbun
Top SketchUcator
License type: Pro
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Previous
Return to Developers' Forum
Users browsing this forum: No registered users and 6 guests
