SketchUp-Ruby Resources
Postby Jim » Sat May 31, 2008 6:02 pm
Official Google Sketchup API Documentation
Ruby Operator Precedence
The reserved words and, or and not have a lower precedence than &&, || and !. The tricky part is that their precedence is lower than the assignment operator = .
a = false or true evalualtes to (a = false) or true.
You probably meant one of:
a = (false or true)
a = false || true
Avoid using the typename method
In this discussion, user AlexMozg presents evidence that avoiding the object.typename can give your script a considerable performance increase.
Instead, use object.is_a? Class::Type.
He also says in a model that is less than 10 MB, there may not be a substantial increase, but for very large models the speed increase is considerable.
Installing Extensions
Here's a method that tells you right where your version of SketchUp is looking for extensions. Copy and paste the code into the Window > Ruby Console dialog, and press ENTER. It works for all versions of SketchUp, and on all operating systems, too.
Code: Select all
Sketchup.find_support_file("Plugins")
And in my case the location to install plugins is C:/Program Files/Google/Google SketchUp 7/Plugins
Links to important and notable Dev Forum posts past and present. Let me know if there is a topic that should be included here.
SketchUp & Ruby Development Discussions
Ruby Editor Suggestions
Ruby Challenges
  1. UI.play_sound jukebox (RickW)
  2. best fitting bounding box (Matt)
Ruby Docs
Ruby Books
Extension Collections
Resources
Reason: Added link to SketchUp Ruby C Extension tutorial
Jim
Global Moderator
Re: SketchUp-Ruby Resources
Postby Heven7_floor » Tue Jan 20, 2009 10:14 am
Great Jim
Your suggestion is usefully to every newer like me .
Thanks :bounce:
Heven7_floor
Postby watkins » Tue Jan 20, 2009 1:23 pm
Dear Jim,
Many thanks for all your hard work. It is greatly appreciated.
Kind regards,
Bob
watkins
Postby sepo » Fri Jan 23, 2009 8:10 pm
Just found this depository of Plugins for SU. There a lot of known ones but nevertheless mayby useful.
http://www.accustudio.com/index.php?opt ... lect&id=23
sepo
Postby Oaht » Tue Feb 10, 2009 11:10 am
Thanks for your effort. Cheers :thumb:
Oaht
Postby vashstamp3de » Sun May 17, 2009 1:30 pm
I hope this helps...(and not violating someone :( )
http://xoomer.virgilio.it/kites/program ... ugins.html
Good Luck!
vashstamp3de
Postby remus » Sun May 17, 2009 5:59 pm
I imagine a link to contact each plugins developer would be appreciated by the authors :thumb:
remus
Postby Pauline01 » Mon Oct 12, 2009 2:01 pm
thx again it's very very nice!
Pauline01
Postby Align » Sun Nov 08, 2009 4:15 am
thanx for this awesome thread! i give it a 10 :sketchstatic:
Align
Postby thomthom » Sun Nov 08, 2009 11:44 am
Jim, maybe include the path to install plugins on Mac as well. That one seem to be the most confusing amongst users it seems.
User avatar
PluginStore Author
PluginStore Author
Postby RickW » Mon Jan 11, 2010 10:27 pm
vashstamp3de wrote:I hope this helps...(and not violating someone :( )
Good Luck!
Just point the Windowizer link to Smustard, please. It currently points to a broken link on RLD.
RickW
Postby thomthom » Sun May 09, 2010 4:29 pm
Might be worth noting that definition names can't be trusted to be unique: viewtopic.php?f=11&t=28094
User avatar
PluginStore Author
PluginStore Author
RUBY PROGRAMMING REFERENCES
Postby Dan Rathbun » Thu Aug 26, 2010 10:53 pm
RUBY PROGRAMMING REFERENCES - CHM format*
Method References for Ruby Core and Extended Modules & Classes
~ Arranged by Ruby version and PatchLevel ~
1.8.6
END OF LIFE
announced 2011-09-11
Ruby ver 1.8.6 p398
ruby-1.8.6-p398-doc-chm-2.zip
dl.txt
DL library documentation (from v1.8.6-p287)
Online version at ruby-doc.org
Latest ver 1.8.6
Online at Ruby-Doc.org
Core <> Libraries [framed webpage]
1.8.7
END OF LIFE
2014-06-30
Ruby ver 1.8.7 p330
ruby-1.8.7-p330-doc-chm.zip
Latest ver 1.8.7
1.9.1
END OF LIFE
2012-01-31
Latest ver 1.9.1
Keywords <> Core <> Libraries [framed webpage]
1.9.2
END OF LIFE
2014-07-31
Latest ver 1.9.2
1.9.3
END OF LIFE
2015-02-23
Latest ver 1.9.3
2.0.0
SECURITY MAINTENANCE ONLY
ends 2016-02-24
Ruby ver 2.0.0-p247
ruby-2.0.0-p247-core-doc-chm.zip
ruby-2.0.0-p247-stdlib-doc-chm.zip
Latest ver 2.0.0
2.1.6
STABLE - MAINTENANCE
Ruby ver 2.1.6
ruby-2.1.6-core-doc-chm.zip
ruby-2.1.6-stdlib-doc-chm.zip
Latest ver 2.1.6
2.2.2
STABLE - CURRENT
Ruby ver 2.2.2
ruby-2.2.2-core-doc-chm.zip
ruby-2.2.2-stdlib-doc-chm.zip
Latest ver 2.2.2
* Compiled HTML Help Markup
NOTICE: CHMs for older patchlevels under each version may be deleted to save server space.
( Get 'em while they're hot! )
    I'm not here much anymore. But a PM will fire email notifications.
    User avatar
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby Dan Rathbun » Wed Sep 08, 2010 10:51 am
    |--<<< RUBY RESOURCES >>>--|
    Ruby Newbie's Guide to Getting Started
    viewtopic.php?f=180&t=10142&start=15#p298780
    TUTORIALS & PRIMERS
    ~ Ruby (Generic) ~
    Introduction to Ruby
    http://www.ruby-doc.org/docs/Tutorial/
    Ruby User's Guide
    by Mark Slagell, Iowa State University
    http://www.rubyist.net/~slagell/ruby/
    Ruby Study Notes
    by Satish Talim
    http://rubylearning.com/satishtalim/tutorial.html
    Learn to Program
    by Chris Pine
    http://pine.fm/LearnToProgram/
    ~ Sketchup Specific ~
    Edges to Rubies - The Complete SketchUp Tutorial
    by Martin Rinehart
    http://www.martinrinehart.com/models/tutorial/
    Ruby Tutorials
    SketchUcation Forums
    http://forums.sketchucation.com/viewtopic.php?p=52665#p52665
    Tutorial Index
    http://forums.sketchucation.com/viewtopic.php?f=18%26amp;t=8767
    BOOKS
    ~ Offline (PDF, CHM, TAR, etc.) ~
    The Book of Ruby
    by Huw Collingbourne
    ** PDF
    http://www.sapphiresteel.com/IMG/zip/book-of-ruby.zip
    The Little Book of Ruby
    ** PDF
    http://www.sapphiresteel.com/IMG/pdf/LittleBookOfRuby.pdf
    Mr. Neighborly's Humble Little Ruby Book
    by Jeremy McAnally
    ** PDF
    http://www.humblelittlerubybook.com/book/hlrb.pdf
    Programming Ruby - The Pragmatic Programmer's Guide, 1st Ed.
    (aka "The Old Pick-Axe Book" circa Ruby ver 1.6.x)
    by David Thomas and Andrew Hunt
    ** TAR archive of website
    http://phrogz.net/ProgrammingRuby/ProgrammingRuby_20061016.tar.gz
    ** CHM edition file is included w/ Win 1.8.6 One-click install
    see your /ruby/doc directory OR
    download from SketchUcation
    Extending Ruby 1.9 - The Pragmatic Programmer's Guide
    by David Thomas
    http://media.pragprog.com/titles/ruby3/ext_ruby.pdf
    Ruby Best Practices
    by Gregory T. Brown
    ** PDF
    http://sandal.github.com/rbp-book/pdfs/rbp_1-0.pdf
    Automatic SketchUp
    by Matthew Scarpino, Eclipse Engineering LLC
    http://www.autosketchup.com/downloads/Automatic_SketchUp.pdf
    ~ Online ~
    Ruby Essentials
    Techotopia
    http://www.techotopia.com/index.php/Ruby_Essentials
    http://phrogz.net/ProgrammingRuby/frameset.html OR
    ~ Previews of Ruby Books for Sale ~
    Learn to Program, 2nd Ed.
    by Chris Pine
    (expanded from the original tutorial)
    http://www.pragprog.com/titles/ltp2/learn-to-program-2nd-edition
    Programming Ruby - The Pragmatic Programmer's Guide, 2nd Ed.
    (aka "The New Pick-Axe Book" circa Ruby ver 1.8.x)
    by David Thomas, with Chad Fowler and Andrew Hunt
    http://pragprog.com/titles/ruby/programming-ruby
    Programming Ruby 1.9: The Pragmatic Programmers' Guide
    http://pragprog.com/titles/ruby3/programming-ruby-1-9
    The Ruby Programming Language
    by David Flanagan and Yukihiro Matsumoto
    http://books.google.com/books?id=jcUbTc ... GordbwjC...
    TECHNICAL REFERENCES
    Ruby Cheatsheet
    http://www.zenspider.com/Languages/Ruby/QuickRef.html
    Ruby Base Classes - circa ver 1.6.x
    (but most still OK for 1.8.x which has more methods)
    http://phrogz.net/ProgrammingRuby/builtins.html
    Ruby Core Documentation
    (may be ver 1.9.x)
    http://www.ruby-doc.org/core/
    RDoc Documentation
    http://rdoc.rubyforge.org/
    RubyGems User Guide
    http://rubygems.org/read/chapter/1
    RubyGems Manuals
    http://docs.rubygems.org/
    INDEXES
    Resources
    (SketchUp Sage)
    http://sites.google.com/site/sketchupsage/resources
    SKETCHUP SPECIFIC
    ~ API ~
    SketchUp Ruby API Cheatsheet
    by Alex Schreyer
    http://www.alexschreyer.net/cad/sketchup-ruby-api-cheatsheet/
    SketchUp Ruby API
    http://code.google.com/apis/sketchup/
    SketchUp Ruby API - Class Index
    http://code.google.com/apis/sketchup/docs/classes.html
    SketchUp Ruby API - Method Index
    http://code.google.com/apis/sketchup/docs/methods.html
    SketchUp Ruby API - Class Diagram
    http://code.google.com/apis/sketchup/docs/diagram.html
    Sketchup Ruby API Class Diagrams
    by Jim Foltz
    http://sketchuptips.blogspot.com/2008/08/sketchup-ruby-api-class-diagrams.html
    Google SketchUp API Blog
    http://sketchupapi.blogspot.com/
    PickHelper - Visual Guide
    by Thomas Thomassen
    http://forums.sketchucation.com/viewtopic.php?f=180&t=30232&p=266685
    WebDialogs - The Lost Manual
    by Thomas Thomassen
    http://forums.sketchucation.com/download/file.php?id=36664
    ~ Indexes ~
    http://forums.sketchucation.com/viewtopic.php?f=180%26amp;t=10142
    ~ BBs / Forums ~
    Developers Forum - Google Groups
    http://groups.google.com/group/google-sketchup-developers
    Developers Forum - SketchUcation Community Forums
    http://forums.sketchucation.com/viewforum.php?f=180
    ~ Code Snippets ~
    Code Snippets Index - SketchUcation Developers Forum
    http://forums.sketchucation.com/viewtopic.php?f=180%26amp;t=28846
    ~ Plugins ~
    Plugins Index (by author) - SketchUcation Plugins Forum
    http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28782
    Plugins Visual Index - SketchUcation Plugins Forum
    http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=16909
    Trimble SketchUp - Plugins (Download Page)
    http://www.sketchup.com/intl/en/download/plugins.html
    Trimble SketchUp - Ruby Scripts (Download Page)
    http://www.sketchup.com/intl/en/download/rubyscripts.html
    Jim Foltz SketchUp Plugins
    http://sketchuptips.blogspot.com/2007/09/plugin-index-page.html
    Ruby Libray Depot
    ! URL Removed due to too many outdated plugins !
    Smustard(TM) - Plugins and Scripts
    http://www.smustard.com/scripts/
    JohnJ - Plugins for Sketchup
    http://www.johnj.com/drawing/sketchup/ruby-plugins-for-sketchup/
      User avatar
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby thomthom » Wed Sep 08, 2010 11:07 am
      Very nice list Dan!
      Dan Rathbun wrote:Ruby Best Practices, by Gregory T. Brown
      ** PDF
      This one looks very interesting.
      User avatar
      PluginStore Author
      PluginStore Author
      Postby Dan Rathbun » Wed Sep 08, 2010 11:35 am
      thomthom wrote:Very nice list Dan!
      Thanks.. (but I didn't find all these myself.) I had it posted over at GG, but it kept getting farther down the topic stack. Over here I know right where it is, and can format it.
      thomthom wrote:This one looks very interesting.
      Jim found that one.
      P.S. - @Jim your free to cut and paste anything from here to the top of the thread.
        User avatar
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Ruby Interpreter DLLs (Win32)
        Postby Dan Rathbun » Fri Oct 01, 2010 7:06 am
        Instructions: (Win32 ONLY)
        These Instructions Were Aimed at SketchUp Releases 6.x & 7.x ONLY
        Navigate (Explore) on your computer, to the Google Sketchup application folder, and ...
        1. Backup the current "Deceased" 1.8.0 dll, msvcrt-ruby18.dll by renaming it:
          • msvcrt-ruby180_p0.dll
          • or similar if it's a newer version. For example, if the old dll is v1.8.6-p287, then rename it msvcrt-ruby186_p287.dll
        2. Download your choice of a newer version Ruby Interpreter Win32 DLL (below)
        3. Make a copy of the new file and name it: msvcrt-ruby18.dll
            (Sketchup is hardcoded to load this DLL filename.)
        ALL Ruby 1.8 Trunk Releases Are Now Obsolete
        1.8.0
        OBSOLETE
        ruby-1.8.0-p0-i386-mswin32-dll.zip
        1.8.1 .. 1.8.4
        OBSOLETE
        1.8.1 thru 1.8.4 are obsolete (no sense posting them.)
        1.8.5
        OBSOLETE
        ruby-1.8.5-p0-i386-mswin32-dll.zip
        ruby-1.8.5-p231-i386-mswin32-dll.zip
        1.8.6
        OBSOLETE
        ruby-1.8.6-p287-i386-mswin32-dll.zip
        ruby-1.8.6-p369-i386-mswin32-dll.zip
        1.8.7
        OBSOLETE
        ruby-1.8.7-p330-i386-mswin32-dll.zip
          User avatar
          Dan Rathbun
          PluginStore Author
          PluginStore Author
          Postby Dan Rathbun » Wed Dec 29, 2010 6:48 am
          UPDATES / ADDITIONS (in this topic.)
          Edited Instructions to be more clear and precise.
          Added DLL for:
          • latest Ruby v 1.8.7 p330
          Added CHMs for:
          • latest Ruby v 1.9.2 p136
            User avatar
            Dan Rathbun
            PluginStore Author
            PluginStore Author
            Postby Dan Rathbun » Wed Jan 05, 2011 10:28 pm
            Go to this post... Ruby Resources
            (1) make a checklist of all the Tutorials, and go thru them 1 by 1, and check them off the list as you do.
            (2) make a checklist of all the free downloadable books, and down load them one by one. Put them in a folder on your Desktop (or wherever you can find them easily.) And read them.
            (3) For Standard ruby Reference, get the CHM for Ruby here, put it in this same folder.
            Get comfortable with Standard Ruby. When your ready to script for Sketchup:
            (4) On the Reference list (link above,) go to the Sketchup Specific section, and download Alex's Cheatsheet, and bookmark the Sketchup API Documentation website. (You'll be referencing it a lot.) It has the methods for the modules and classes for 'talking' to Sketchup, and manipulating it's models.
            (5) Go through all the available Sketchup Ruby tutorials (on the list.)
            (6) Read the code examples in your plugins/Examples folder.
            (7) Have fun. Start fooling around with Ruby under Sketchup. Usually the best thing is to start by customizing the examples.
            (8) Whenever you have questions, come back to this forum, and first do a search (it's likely your question has already been asked.) If not.. start a new topic (make the the topic title simple but informative... a shortened version of your question. Don't make it "Help Me!", that does not work well.)
            (9) Before going into advanced Sketchup scripting, download more advanced plugins from the plugins forum (or other websites.. see the Resource list,) and examine them. See how they did things. This the best way to learn how to do things right. If you have a question about why an author did something a certain way... you can either Private Message them, or see if there is a discussion topic specific to their plugin, here in the Developer's forum, and post a question at the end of that topic. If no topic exists, create one by putting the plugin name in square brackets following by 'coding questions.' Please don't ask coding questions in the Plugin distribution topic of the Plugins forum. Ask them here in the Developers forum.
            And ... welcome to the world of Ruby !
              User avatar
              Dan Rathbun
              PluginStore Author
              PluginStore Author
              Postby Jim » Sun Oct 30, 2011 12:30 pm
              This site has many videos of Ruby talks recorded at various Ruby Conferences - http://confreaks.net
              Some good stuff there - if you can find them...
              Jim
              Global Moderator
              Postby rricon » Sun Dec 18, 2011 5:23 am
              Hello,
              Where to find the .h file of msvcrt-ruby18.dll file ?
              Regards,
              rricon
              Postby Dan Rathbun » Sun Dec 18, 2011 8:54 am
              rricon wrote:Where to find the .h file of msvcrt-ruby18.dll file ?
              In the source:
              ftp://ftp.ruby-lang.org/pub/ruby/1.8/ruby-1.8.6-p287.zip
                User avatar
                Dan Rathbun
                PluginStore Author
                PluginStore Author
                [doc] Programming Ruby (The "Pick-Axe" Book)
                Postby Dan Rathbun » Sat Sep 29, 2012 3:29 am
                  book: "Programming Ruby - The Pragmatic Programmer's Guide"
                  Copyright © 2000 Addison Wesley Longman, Inc.
                  ProgrammingRuby.zip
                  Released under the terms of the Open Publication License V1.0.
                  :ugeek:
                    User avatar
                    Dan Rathbun
                    PluginStore Author
                    PluginStore Author
                    Postby todd burch » Wed Oct 24, 2012 5:48 pm
                    Chunky Bacon. I didn't see a link for Why's Poignant Guide to Ruby. A true classic.
                    http://mislav.uniqpath.com/poignant-gui ... ter-1.html
                    todd burch
                    Postby Dan Rathbun » Fri Nov 09, 2012 7:53 pm
                      User avatar
                      Dan Rathbun
                      PluginStore Author
                      PluginStore Author
                      Postby mptak » Mon Dec 03, 2012 3:07 am
                      http://rubyjs.org/
                      Javascript implementation of Ruby. For what its worth.
                      mptak
                      Postby Jim » Wed Apr 23, 2014 12:37 am
                      http://opalrb.org/
                      Ruby to JavaScript compiler, for what it's worth.
                      Jim
                      Global Moderator
                      Postby August » Fri Jul 31, 2015 1:15 am
                      In his main post above, Dan basically suggests becoming very familiar with Ruby before beginning to use it with Sketchup. And he has a very good point, especially when it comes to the powerful and rather esoteric ways that Dan himself can use Ruby.
                      However, in the other direction, the Bastard's Book above, http://ruby.bastardsbook.com/, makes the point that "Programming and knitting are both skills that require continual practice but aren't easily improved by doing things other than, well, actually programming or knitting." So he presents lots of simple ways to get in your practice. "The good thing about programming compared to knitting a scarf is that you can experiment and mess up all you want without having to go out and buy more yarn."
                      Even further in that direction, Matthew Scarpino's book, "Automatic Sketchup", gives you ways to get that fundamental practice by working in Sketchup. And that's your goal, isn't it? I would even recommend Matt's book and SketchUp Ruby for initial programming instruction -- the instant gratification of creating SU objects is hard to beat.
                      And don't let the Amazon price for this out-of-print book scare you off. It's available free at the author's site. See also this thread, Automatic Sketchup book can now be freely downloaded.
                      “An idea, like a ghost, must be spoken to a little before it will explain itself.”
                      -- Charles Dickens
                      August
                      WIN32OLE Sample Scripts
                      Postby Dan Rathbun » Sun Aug 16, 2015 5:21 pm
                      WIN32OLE Sample scripts from the Ruby 1.8.6-p287 distribution:
                      win32ole_samples.zip
                      :idea:
                        User avatar
                        Dan Rathbun
                        PluginStore Author
                        PluginStore Author
                        by Ad Machine » 5 minutes ago
                        Ad Machine
                        Robot
                        Return to Developers' Forum
                        Who is online
                        Users browsing this forum: alexpap1992, stark4410 and 10 guests
                        Visit our sponsors:
