Towards a complete extension: Good Practices
I have with the aid of snippets and Alexander C. Schreyer's Ruby Code Editor stumbled my way to a example that does what I wish. Its of the form:
# # bbtools.rb script to add tools for bounding box manipulation # module HSM module BBTools class BBTool . . . vital essence . . . end # class BBTool end # module BBTools end # module HSM
and while in the editor I invoke it with:
tool = HSM::BBTools::BBTool.new() tool.runTool()
At this point I'd like to make it a 'real' extension. By that I mean add it to one of the pull down menus in SU. I believe I need to do this in a separate file where I essentially tell SU about my tool and where I will place it.
there is also the matter of:
Extension Wrappers: All extensions in the Extension Warehouse must be wrapped with a SketchupExtension class so that the user can enable and disable the extension from the Preferences dialog and/or the Extension Warehouse UI.
At this point I admit to being clueless about how to accomplish this last step. My goal is to at some point publish and I believe that adds a layer of complexity as well.
Advice? Suggestions. Brickbats? Catcalls? Bring it on---Please !!
Get some others recent Extensions to see how it's done by them...
e.g. some of my recent ones like "LayerWatcher"... -
e.g. some of my recent ones like "LayerWatcher"...Cool!! I will
Then you'll need to follow:
http://extensions.sketchup.com/en/developer_center/ew_developer#rbz -
http://extensions.sketchup.com/en/developer_center/ew_developer#rbzI've read through same and I plan to do so again more thoroughly again after I get this next layer of magic nailed down. I think I now understand the two file format well enough to give it a spin in a bit but am momentarily busy prepping prototype parts for shapeways. Its been tool, prototype, tool, proto in a kind of recursive spiral! Need one for the other and round about we go...
