SketchUcation Premium Membership
Optimization Tips
Re: Optimization Tips
Postby glro » Sun Aug 19, 2012 2:09 pm
Dan Rathbun wrote:
Dan Rathbun wrote:its nice but...
The code needs updating. It needs to search by ID instead.
(Or have arrays of the Inspector captions in all the local versions.)
Ooops.. just checked. The Outliner does not have an ID.
But Jim's system call 'may' work. The window object can have a different "name" than the text displayed on the caption bar.
Someone running a non-English version could test it and let us know.
I run a spanish computer using french as default language, and it doesn't work...
But there is a simple way to do it, using the standard line of code you mentioned, plus a messagebox
Code: Select all
result = UI.messagebox "if the outliner window is opened, close it?'", MB_YESNO
  if result == 6 #yes
     #close or open the outliner window
      status=UI.show_inspector "Outliner"
      if status==false then
This way, you don't toggle on the outliner window if it is not opened already, and if it is, you close it
glro
Name: Georges LE ROUX
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Level of SketchUp: Intermediate
Postby Dan Rathbun » Sun Aug 19, 2012 3:30 pm
Actually we cannot close inspectors singly. Once they are open, we can only collapse or expand them.
User avatar
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: education
Level of SketchUp: Advanced
Postby TIG » Sun Aug 19, 2012 3:44 pm
For Windows windows only - using Win32API.so - which you'll need to 'require'...
You can 'close' just one window thus:
closeWindow("Outliner")
where:
Code: Select all
def closeWindow(name)
    findWindow = Win32API.new("user32.dll","FindWindow",['P','P'],'N')
    pw=findWindow.call(0,name)
    sendMessage = Win32API.new("user32.dll","SendMessage",['N','N','N','P'],'N')
    sendMessage.call(pw,0x0112,0xF060,0)#CLOSES
You can check if a window is 'visible' with:
Code: Select all
def windowIsVisible?(name)
    isWindowVisible= Win32API.new("user32.dll","IsWindowVisible",['P'],'N')
    return isWindowVisible.call(pw)==1
Incidentally, the roll 'up'/'down' methods I often use are:
Code: Select all
def toggleRollUp(name)
    sendMessage.call(pw,0x00a1,2,"")#WM_NCLBUTTONDOWN
    sendMessage.call(pw,0x0202,0,"")#WM_LBUTTONUP
def isRolledUp?(name)
    getWindowRect= Win32API.new("user32.dll","GetWindowRect",['P','PP'],'N')
    data=Array.new.fill(0.chr,0..4*4).join
    getWindowRect.call(pw,data)
    rect=data.unpack("i*")
    #if window height is less than 90 then the window is rolledup
    return (rect[3]-rect[1]) < 90
... using isRolledUp?("Outliner") to then toggleRollUp("Outliner") to roll it up if it's down etc...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby glro » Mon Aug 20, 2012 8:50 am
Dan Rathbun wrote:Actually we cannot close inspectors singly. Once they are open, we can only collapse or expand them.
i am surely missing something
you are right; the window is not closed, only collapsed
but it is sufficient; my experience is that sketchup doesn't crash anymore
glro
SketchUp version: 8
License type: Pro
Postby TIG » Mon Aug 20, 2012 9:20 am
Collapsing [rolling-up] the Outliner is sufficient to stop it updating and causing bugsplats.
However, my methods just posted do also 'close' the window if desired - but this might be annoying for users [?]... remember to use the 'locale' name for the window...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Fri Oct 12, 2012 12:11 pm
Page 152
http://www.slideshare.net/tenderlove/zo ... de-so-slow
attr_accessor :property vs def property; @property; end
attr_accessor wins.
Video of the presentation where the linked slideshow was used: http://confreaks.com/videos/427-rubycon ... de-so-slow
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Dan Rathbun » Fri Oct 12, 2012 7:18 pm
That would be in the sub-catagory of load optimization.
However, later is there any difference when instances are instantiated ??
User avatar
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby thomthom » Fri Oct 12, 2012 10:05 pm
What do you mean?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Dan Rathbun » Sat Oct 13, 2012 2:12 am
The attr_* creation call is run on the C side so is bound to be faster. There is no parsing of text characters that make up the method definition, and translating to C-calls.
Also the built-in creates the @var and sets it to nil, so the pure Ruby version would also need to do that (within the initialize method, just to be fair.)
This work is all defintion work, done when the class is parsed and defined. It is only done once.
Who's classes have a million accessor methods that need to be defined ?
What I mean?
.. is that later, at Runtime, when actually calling the accessor method, to get the value of the instance variable, is there a speed difference between the method created by the C-call, and the method created by the Pure Ruby definition ?
I read the example as measuring the difference in method instance creation times. (Even methods are instances of a class object.)
User avatar
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby thomthom » Sat Oct 13, 2012 9:48 am
Have a look at the slideshow linked - from page 152 - it displays what does on on the C side and explains the difference. It also shows graphs for the speed difference.
The whole presentation is also interesting.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Dan Rathbun » Sat Oct 13, 2012 4:07 pm
I did.. It is not clear.
User avatar
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby thomthom » Tue Oct 23, 2012 11:30 am
Dan Rathbun wrote:I did.. It is not clear.
Page 154 vs 155 - you can see it does quite a lot of different things. On 154 which is the code for attr_reader it just directly fetches the value. In page 155 you can see it invokes a whole lot more (explained partly on page 156).
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby jolran » Tue Mar 12, 2013 1:24 pm
if vector1.samedirection?(vector2) => do something.... end
seams a little faster than:
next unless vector1.samedirection?(vector2) => do something...
Havent done any vigourious testing, could be specific case for me or maybe just a difference between if and unless.
Just wanted to mention I noticed some difference in speed for the 2 cases.
User avatar
jolran
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby thomthom » Tue Mar 12, 2013 2:32 pm
Got some numbers? I'd be surprised if there was a change due to if vs unless.
Isn't it the "do something" that makes the difference here? Because you're comparing inverted logic that control whether "do something" is executed or not...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby jolran » Tue Mar 12, 2013 4:30 pm
We are talking ms here, but still a consistent difference for me.
I was doing the condition inside a for loop.
Maybe, I don't quite know the difference :oops:
This was at the end of the loop, so the loop would restart again anyway if the "if" statement was false and there where more items to process.
My theory was to shortcut whats inside the if statement and just go ahead to the next one. But that was slower..
I have also noticed the same kind of ms speedgain when using if @edge VS if @edge == true while setting
true or false elsewhere in the script.
But that is probably more logic, although one could possibly expect that only if @edge needs to do more lookups.
Again I could be overlooking something fundamental gotcha in Ruby, needs testing by others.
Maybe next time I'll test I 'll get opposite results :)
Edit: It could have something to do with that the if statement has an end in this case?
So the code get's encapsulated or something.
next unless vector1.samedirection?(vector2) => do something... end. Doesent work.
Anyway it shaved 2 seconds of a process that took 30 seconds.
User avatar
jolran
SketchUp version: 8
License type: Pro
SketchUp use: other
by Ad Machine » 5 minutes ago
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Premium Members get 20% discount!
Ad Machine
Robot
Previous
Return to Developers' Forum
Who is online
Users browsing this forum: DanielBowring and 7 guests
