Quick select edges using the eraser tool!
Share or learn with the Pros
Postby justry » Thu Mar 13, 2008 11:32 pm
I posted this before, but looks like it got lost because of that server backup restore problem thing, so here it is again:
You know when you want to select some edges, and the shift-clicking is just taking too long? Don't you wish there was a selection tool that works like the eraser tool, so you can select the edges you want just by dragging along them? Well you can! And using the eraser tool too! Choose the eraser tool, and start dragging along the edges you want to select. Done? WAIT!! Don't release that mouse button yet! Right click any of the edges you selected (while still holding down the left mouse button [and make sure you're right clicking an edge, not a face]). The context menu will pop up. Move the mouse away from the menu, and you can now saftely release the left mouse button. Press Esc to close the context menu and...Volia! Your edges are still selected!
I know it seems complicated, but once you get the hang of it it becomes very easy, and it's much better than all the shift-clicking!
Note: You can then right-click > select > connected faces, to select faces as well.
justry
Re: Quick select edges using the eraser tool!
Postby tomsdesk » Fri Mar 14, 2008 4:52 am
And a big WELCOME! aboard to you Justry: with such a slick trick, thank you very much...yahoo! I will use this all the time.
tomsdesk
Postby Gaieus » Fri Mar 14, 2008 9:02 am
justry wrote:I posted this before, but looks like it got lost because of that server backup restore problem thing...
Yes, sorry about that.
And yes; a big welcome with such a nifty tip! :thumb:
Postby justry » Fri Mar 14, 2008 11:48 am
Thanks a lot guys, and the forum is really great, I love it!
justry
Postby justry » Fri Mar 21, 2008 11:09 pm
Go ahead man, it's all yours!
justry
Postby StarWarsKnower » Sun Mar 23, 2008 10:03 am
Hey, great trick!
Nobody made a big welcome like this when I started. :cry: :( :cry: :cry: :x :cry: :cry:
Just Kiddin.
Mike
StarWarsKnower
Postby justry » Wed Apr 02, 2008 9:46 pm
Update: instead of all the right click thingy, you can just press any shortcut key (e.g. space for the select tool) before releasing the LMB. That'll still keep your edges selected.
I saw this in a thread somewhere in the forums, but by the time I thought I'd add it here, I'd forgotten where I saw it, so if you know who it was please post his name here :enlight: .
justry
Postby simon le bon » Wed Apr 02, 2008 10:46 pm
Very useful. Thanks Justry
simon le bon
Postby shopdude » Thu Apr 03, 2008 5:38 pm
That IS a great trick, learning learning...
There is so much in this forum, now I'll spend all my time w/ SU and never actually build anything!
Thank you, Shopdude
shopdude
Postby simon le bon » Wed Mar 25, 2009 9:56 pm
As I was trying to explain this so usefull tip to a friend, I decided to produce out a small screencast of it. Here is the result:(Remind: press spacebar before release EraserTool and that's it!)
;) simon
simon le bon
Postby August » Sun May 03, 2009 8:20 pm
Thanks to all contributors for this.
Using the Spacebar makes it even easier and a bit intuitive. The Eraser first selects but does not actually erase until you release the mouse button. Think of pressing the Spacebar as changing the Erase selection to a Selection selection. "Opps, I didn't mean to erase, I meant to select; I'll just change tools in mid-action."
You can, of course, make the reverse change, in a way. "Opps, I didn't mean to select, I meant to erase." Just hit Delete.
But to collect the selection in the first place, dragging the Eraser tool is a LOT faster than Shift-Click, Shift-Click, Shift-Click, Shift-Click.
The Eraser is the only tool that I can think of that collects a selection before it actually operates. Anybody got any others?
I hope this adds something to the discussion,
August
“An idea, like a ghost, must be spoken to a little before it will explain itself.”
-- Charles Dickens
August
Postby Gaieus » Sun May 03, 2009 8:57 pm
August wrote:The Eraser is the only tool that I can think of that collects a selection before it actually operates. Anybody got any others?
No,although there are other tools that autoselect (like the PushPull or Move or Rotate), they can only select one entity at a time.
On another note, the Eraser can only select edges (not faces) so the autoselect function of say the PP tool can be used for other tricks like reversing faces quickly - you only need to set up a shortcut key for the function itself and "browse through" the faces with the PP tool while hitting the shortcut like a madman.
Every tool has its own, little "side effect" :D
Postby simon le bon » Sun May 10, 2009 6:37 pm
excellent :thumb: :thumb: . Works also of course with "del"
;-)s
simon le bon
Postby simon le bon » Tue Jun 09, 2009 11:37 am
Dear all,
It seems fredo has developed the perfect tool which makes the tip of the Eraser Tool unnecessary:
[Plugin] HoverSelect 1.1d - Multi-selection of Edges
SketchUp is in the way to become a Fredoogle product :lol:
*s
simon le bon
Return to SketchUp Tutorials
Users browsing this forum: 60marlan and 4 guests
