SketchUcation Premium Membership
[Tutorial > Modeling] How a Pro Builds a House in SU pt 1
Re: How a Pro Builds a House in Sketchup Part 1
Postby syburn » Sat Nov 17, 2007 2:22 pm
oh i have placed the rectangle to one side this time. I have managed to get the jgp in the matrial library by the right click methof - but when i paint bucket the material to the recangle nothing happens - i cant see the image. can see other materials if i try those though.....
hmm i have now done it but not sure how - restarted it. maybe it was groups problem.
had to flip the image as it was mirrored but looks ok now.
thanks for you help!
(syburn)
syburn
Postby Krisidious » Sat Nov 17, 2007 2:23 pm
you may have problems like this, after applying the texture to the rectangle, then right click on the rectangle and select "texture>Position> then flip, rotate, move until it fits correctly.
this help?
Kristoff Rand
Home Designer
Custom House Plans with a Point of View
Krisidious
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby titmas » Sat Nov 17, 2007 2:23 pm
Krisidious wrote:step 11
repeat this process for your foundation, your first level and your second level and third...
by 'repeat' are you referring to steps 1-10 for each page of the plans by importing an image of each page than scale, trace, copy, layer?
titmas
Postby Krisidious » Sat Nov 17, 2007 2:24 pm
yes that's what I meant...
Kristoff Rand
Home Designer
Krisidious
SketchUp version: 8
License type: Pro
Postby not registered yet » Sat Nov 17, 2007 2:25 pm
Hi Kristoff,
I only just found this thread and I'm finding it very useful indeed as I'm modelling my house in order to plan various improvements and alterations to services etc. I've got about six versions so far in various stages of completion which I realise is going to cause me major problem. Your tip about layers will be invaluable. Going right back to the beginning, would I be right in assuming that you could treat an imported 2D .DWG file in exactly the same way as you've used a .jpg image ?
Thanks again for all your great input.
Bigyin
not registered yet
Postby Krisidious » Sat Nov 17, 2007 2:25 pm
yes you could use the dwg file, although you would explode it and make the actual lines of the dwg into SU lines.
Kristoff Rand
Home Designer
Krisidious
SketchUp version: 8
License type: Pro
Postby not registered yet » Sat Nov 17, 2007 2:26 pm
Thanks for that Kristoff. I think I'm gonna restart my model as I have a .DWG that friend produced and following your approach will help me keep the versions much better organised.
Cheers,
Bigyin
not registered yet
Postby Krisidious » Sat Nov 17, 2007 2:26 pm
Bigyin...
start a thread in the gallery and post your work as you go, people will stop by and drop encouraging notes and advice that you can't find by asking, the kind that pops into their head while they see your progress.
good luck.
Kristoff Rand
Home Designer
Krisidious
SketchUp version: 8
License type: Pro
Postby not registered yet » Sat Nov 17, 2007 2:27 pm
I am having problems with step 4.
What do you mean when you say open the group?
If you mean edit, I am editing the group and measuring with the tape measure, but it is not asking me to resize the group?
BTW- I am using the free version of SketchUp.
Thanks from an aspiring SU user!
(Online)
not registered yet
Postby Krisidious » Sat Nov 17, 2007 2:28 pm
online...
after measuring a lined that you have drawn, you type in the box on the lower right hand of your screen, the measurment that you wish the line to become.
does that help?
Kristoff Rand
Home Designer
Krisidious
SketchUp version: 8
License type: Pro
Postby not registered yet » Sat Nov 17, 2007 2:28 pm
I am doing that and it is only making a construction point where the measurement would be?
(Online)
not registered yet
Postby Gaieus » Sat Nov 17, 2007 2:29 pm
Online,
Don't bother with the construction point!
Do as Kris told:
Do the measurement, click second time and before doing anything else, just start typing the desired measure (don't put your mouse into the VCB and click - just type) When finished, hit Enter and answer the question that pops up.
Administrator
SketchUp version: 2013
License type: Pro
SketchUp use: historical reconstruction
Postby not registered yet » Sat Nov 17, 2007 2:30 pm
Wow, that was easy!
I feel dumb now. :oops:
One more question, how come I am getting this black junk on my screen with zooming in?
(Online)
not registered yet
Postby Krisidious » Sat Nov 17, 2007 2:31 pm
if you are at scale already... then that's a videocard issue... if it's not to scale it may be clipping, to fix that a known GSU issue, you'll have to turn off the perspective view and use parallel view.
Kristoff Rand
Home Designer
Krisidious
SketchUp version: 8
License type: Pro
Postby not registered yet » Sat Nov 17, 2007 2:31 pm
Krisidious wrote:if you are at scale already... then that's a videocard issue... if it's not to scale it may be clipping, to fix that a known GSU issue, you'll have to turn off the perspective view and use parallel view.
Well I am at scale already.
On the existing plan that I made a material out of, I can zoom all the way in and it is at scale already?
(Online)
not registered yet
Postby Krisidious » Sat Nov 17, 2007 2:32 pm
if you are in the top view... square
and you have parallel view enabled...
and you still have this issue, I would say you need a better videocard or at very least to update your video card drivers...
Kristoff Rand
Home Designer
Krisidious
SketchUp version: 8
License type: Pro
Postby not registered yet » Sat Nov 17, 2007 2:33 pm
Thank you so much!
(Online)
not registered yet
Postby jaggie4life » Tue Dec 11, 2007 10:46 pm
Hi there,
i amnt very good at this but im just wondering where to get a picture at the start of the guide if anyone can post one up that would help very much
thanks
jaggie4life
Postby jvh » Wed Jan 09, 2008 9:48 pm
i've got problems with step 6. after right clicking and choosing "use as a material" i don't know how to apply it to the square.
jvh
Postby jvh » Thu Jan 10, 2008 4:11 pm
Thanks James,
That's what I tried. Then I get the materials window, but my plan is not in it, so I can't select and drop it in my square.
jvh
Postby J4Media » Wed Jan 16, 2008 6:09 pm
First off, thanks for this tutorial, its very helpful.
I have followed along through all steps and am at the part where I trace the plan. The problem I'm having trouble with is when i trace the entire perimeter of the plan and connect it to where I started, the lines get thin from their original thick. This then results in a hollow center when i use the offset tool to set the wall thickness of 6".
I am baffled by what I am doing wrong, can someone please help me out?
Thanks in advance for your help.
John
J4Media
Postby Gaieus » Thu Jan 17, 2008 10:15 am
John,
Thick lines are called "profiles" and are merely used to either indicate that they do not close a coplanar face or to give some "perspective look" to your model (meaning that the outlines and front edges of a 3D model are usually displayed with them).
I personally don't like profiles and even turn them off (Style window > in mode > edit > edge settings).
Now when you just simply close a face (tracing over the image) they should not turn into thin lines (that are called edges when surrounding a face) since they are still the "outlines" of your face.
Is there a face created at all? If not, you have done something wrong, i.e. I assume that your lines are not on the same (red/green, horizontal) plane. This is essential for SU to be able to create a face.
Try (at the same style setting as above) to set the line display to "color by axis" to see if your lines are coplanar (all lines on the red or green axis should be coloured red/green now). Of course if you modeled completely out of axis, this won't help.
Also try to put a text label onto every endpoint you drew. By default it will give you the coordinates. If you hit enter twice, that will be the text label. Wherever you se a different value of the last number (the z - blue - axis) it means that you are not coplanar.
Or just post your model here for us to see.
Administrator
License type: Pro
Postby J4Media » Thu Jan 17, 2008 4:21 pm
Gaieus wrote:John,
Thanks for the response Gaieus. I am getting a face, it was just picking up the image below it a dragging it up. I guess I just assumed that when I dragged the face up it would be solid white in color, so that threw me off.
The problem I'm having now is when i try to place a window on one of the walls i have drawn, it doesnt cut through the wall and its very hard to actually put on the face. sometimes i get to the point where it looks like its in place, but the top half of the window is still white (the color of the wall) and most (but not all) of the otherside of the window cut through.
I imagine there's an easy way to place the window on a face that I'm missing. Thanks again for your help!
John
J4Media
Postby Gaieus » Fri Jan 18, 2008 9:28 am
Note that in SU components can only cut an opening on a single face. This means they neither cut through a thick wall nor can cut two adjacent - though coplanar - faces (i.e. if you divide a face with a line and insert a component that should cut both faces, it will only cut one of them).
To get some ideas about the workarounds to cut thick walls, look at this tutorial (do NOT miss the link to Susan's further enhancement of the tut at the bottom of the first post).
Also, Didier has come up with a brilliant, new script, see the discussion here.
Administrator
License type: Pro
Postby Gaieus » Fri Jan 18, 2008 12:39 pm
Ah yes, I also believe that scripts are only to speed up the workflow and you should be able to do everything by hand also (OK, I know that there are some really tricky scripts like SSB and of course I'm really grateful for the rubiers).
Nothing beats practice!
Administrator
License type: Pro
Postby PassUby » Wed Feb 06, 2008 12:28 am
First off, thanks for all the great tutorials and help on here.
My question to anyone is why am I getting just this screen when I Import this file? I went through every setting i could think of, but to no avail I'm still stuck.
My video card is a Radeon X1600 with the newest drivers.
Thank you in advance!
PassUby
Re: [Tutorial > Modeling] How a Pro Builds a House in SU pt 1
Postby Aeir » Sun Jul 13, 2008 2:36 pm
The APV_Template.skp is just a template which gives you the various tabs and settings. To actually get the picture you need to import either an image of a house plan (which you can find by doing a google search for house plan images) or an actual cad type file (.dwg, .dxf, etc). Once you do that, you will have your plan in the template and be ready to work with it.
Hope that helps.
Aeir
Postby keithwins » Sat Aug 09, 2008 4:38 am
In the tutorial, Chris mentions "be sure to use the right thickness for walls". I can't figure out how to change that, or exactly what he means. Do I draw a rectangle that is 6" "thick" over every wall, or is there a way to set lines to 6" thick? Or would people typically do the outside outline, and then offset the 6"?
I also don't understand what is meant by "trace the door and window openings". Is that just drawing some short perpendicular lines to break the walls at the door and window locations, or is there something more tricky going on?
Sorry, I'm not real experienced with Sketchup, AND this is the first tutorial I've looked at. Thanks for any clarifications!
Warmly, keith
keithwins
Postby Gaieus » Sat Aug 09, 2008 7:55 am
keithwins wrote:Or would people typically do the outside outline, and then offset the 6"?
Yes, exactly. SU is not a "solid" but a "surface" modeler i.e. faces ("lines") don't have thickness at all. We only give "thickness" to bejcts bay drawing two faces of them.
Notice however that a face has two different sides; a white/beige one that is the front or outside of it and a bluish one that is the back face. Always make sure that the back face "faces" inside the "thickness" of the geometry and you can only see white faces everywhere in your model.
As for openings (windows, doors) you can either cut their places as Kriss suggests here or use components later. Components with gluing/cutting features can only cut through a single face however so in order to cut the inside face of a fat wall, you need to use some workarounds outlined in this tutorial:
viewtopic.php?f=20&t=744
Make sure to follow the link at the bottom of the first post.
Administrator
License type: Pro
Postby kikle_123 » Mon Sep 01, 2008 4:28 pm
I am currently learning sketchup but I ran across your tutorial and I think it will be a great learning tool to incorporate into my work. -Krystal
kikle_123
Not a Premium Member yet? Check out the great time-limited deal we are offering.
PreviousNext
Return to SketchUp Tutorials
