Worm Gear In SketchUp (3D Printable)
There is some things that could be done better and more exact, but the gears were tested to roll quite well. Except if you are making a swiss clock. Where is the "face width fixed" SPgears plug-in download location (I fixed it as shown on Sketchucation Forum)? It's very late... more tomorrow.
So, again. These are non-enveloping gears. Perhaps it's not hard to make double throat/double globoid? The worm wheel I had to fix in NetFabb basic (free version), but it's very easy, shown at the end of the video. The worm itself is done quite fast and solid.
Make a better shaft for your needs if you want. I used just M5 bolt as an axle.I started calculations from: http://www.mechguru.com/worm_gear_basic.htm
