Perfect Isometric View in Sketchup
Share or learn with the Pros
Postby broomstick » Thu Oct 11, 2012 10:08 am
Hello everyone, I want to share a quick tip I concocted while doing one of my latest jobs. I had a request for a perfect isometric view and came up with a quick solution.
What is an isometric view? It's a particular Parallel Line view where all 90° angles between lines are deformed to 120° like so:
In this particular mode you get model views like this one:
source: http://www.brynmawr.edu/
To setup this kind of view, you simply have to draw a cube starting from the Axis Origin, and then immediately view it in wireframe mode:
Now draw a line connecting the diagonal that starts from the axis origin to the opposite vertex going up (from vertex 1 to vertex 2 in the image:
And now, make sure you're using Parallel Projection and click on the "Position Camera" command
(You may find it in Camera Menu > Position camera, too)
Now the only tricky part: click on vertex number 2, keep the mouse button pressed, and drag to point number 1. Then release.
If all is well, you will find yourself with this:
(you may need to click on zoom extents to reset the viewing clipping plane)
Note that now vertexes 1 and 2 are overlapped!
Try activating "Back edges" view and you get this:
Pro tip: you can save this scene to get back to it whenever you want. Also, if you save this view as 2D Autocad format, you get a perfect isometric view of your model transformed in 2D lines ;)
Happy isometric views, everyone :)
broomstick
Re: Perfect Isometric View in Sketchup
Postby Paul Russam » Thu Oct 11, 2012 10:45 am
That's so perfectly simple its almost painful that it never dawned on me before!!
Well done on seeing the obvious and explaining it. :thumb: :thumb: :thumb:
Paul Russam
English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
Paul Russam
Premium Member
Premium Member
Postby gilles » Thu Oct 11, 2012 11:18 am
Brillant.
gilles
Top SketchUcator
Postby cotty » Thu Oct 11, 2012 11:22 am
Thanks for sharing!
cotty
Top SketchUcator
Postby broomstick » Thu Oct 11, 2012 11:27 am
Paul Russam wrote:That's so perfectly simple its almost painful that it never dawned on me before!!
The obvious is only seen when you need it. That's what I always think ;)
broomstick
Postby Snowy » Thu Oct 11, 2012 1:28 pm
Very nice tutorial Broomstick!
Can i add one thing to this? :)
I have a slightly different workflow.
here's the file that u can use/import as component for different projects.
isometric cube placed.skp
step 1: place the cube on the red and green axes.
step 2: set view to parallel
step 3: select the blue face
step 4: right click and press align view
and this should do the job.
Hope this will add something and thanks for bringing the subject up.
Greetings Erwin
Snowy
Postby pbacot » Thu Oct 11, 2012 4:11 pm
Thanks all. That's brilliant! If only I had any understanding why it works, I would know HOW brilliant. :roll:
MacOSX (El Capitan) ShetchUp Pro v16 Layout Twilight Pro v2 M2 Kerkythea PowerCADD
Top SketchUcator
Postby HPW » Thu Oct 11, 2012 5:33 pm
Is it not the same as menu:
Camera\Standardviews\Iso
HPW
Postby broomstick » Thu Oct 11, 2012 9:03 pm
HPW wrote:Is it not the same as menu:
wow, now I feel like an idiot.
But yes, you're right. Lets just say that the metod I showed allows you to do an ISO view in the direction you prefer...
broomstick
Postby HPW » Thu Oct 11, 2012 10:17 pm
Hm, the Sketchup function let you do this also.
Rotate fairly into the wanted view and choose ISO and it will be aligned exactly into the prefered view.
HPW
Postby pilou » Fri Oct 12, 2012 12:33 am
For diametric and other view Stuff :enlight:
From the Eboy site! :fro:
Speedy Galerie
Top SketchUcator
Postby broomstick » Fri Oct 12, 2012 8:06 am
HPW wrote:>Lets just say that the metod I showed allows you to do an ISO view in the direction you prefer...
I did not know that, that's why I came up with my solution
thanks for pointing it out for me..
broomstick
Postby Snowy » Fri Oct 12, 2012 11:02 am
by HPW » Thu Oct 11, 2012 11:17 pm
Haha that's something i completely overlooked. Thanks for the tip.
Got one more question about this:
The Architecture projects i work on are mostly world orientated so they don't follow the sketchup basic axes.
When i change the axes to follow the direction of the building and i want that view in isometric view. sketchup still shows the isometric view based on the basic axes.
Do i something wrong here? or is that the only restriction that your model has to follow the basic axes.
Snowy
Postby broomstick » Fri Oct 12, 2012 3:23 pm
In this case I imagine that my solution should work, but you would have to try it out ;)
broomstick
Postby alcohorse » Sun Aug 25, 2013 3:40 pm
Thanks for the awesome tip - just what i need for some iso architectural diagrams! :D
alcohorse
Postby NZ Fire Service Training » Thu Dec 12, 2013 2:27 am
TIG also has created a great plugin for both Axometric and Isometric views which can be found in the link below:
http://sketchucation.com/forums/viewtopic.php?t=29018
I've found this invaluable in my workflow
Premium Member
Premium Member
Postby wallride » Tue Feb 07, 2017 8:22 am
Perfect!! Very thank much you!!
wallride
Postby puchengtian » Sat Apr 15, 2017 10:33 pm
Perfect
puchengtian
Postby j03150315 » Wed May 03, 2017 11:46 pm
Thank you SOOOOO MUCH!!!!! :bounce:
j03150315
Return to SketchUp Tutorials
Users browsing this forum: Google Bot and 3 guests
