If you need to rotate a ring in the shape, it is sometimes easier to have a rectangle to set the rotational axis. As that was set up one can move the tool cursor to the horizon to get the green alignment. However sometimes this is not fast or I find at least, won't work in the context.
As I said most of the work can be done with the scale tool, since scaling causes the rotation of the rings, in the directions you'd want.
