SketchUcation Plugin Store
I need bending help...
Postby ninopiamonte » Fri Mar 16, 2012 1:19 pm
Hi guys. I need a help with this simple prob.
I'm making a background grid, and here is the first step I'm doing...
Second, I'm going to bend the half of it..
And here, you can see it not rightly mapped with the texture..?
Though, I used Fredo Scale for the bending.
I also used Round Corner tool.
Thanks....
ninopiamonte
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Intermediate
Re: I need bending help...
Postby tridem » Fri Mar 16, 2012 1:43 pm
when you rotate a geometry the texture mapping is rebuilded, you should unfold/refold the surface :? that is not a simple work in SU... I would follow this way suggested by Gaieus viewtopic.php?p=281409#p281409
User avatar
tridem
Postby dukejazz » Fri Mar 23, 2012 12:09 pm
UV_Toolkit
by thomthom
UV mapping automation:
- tries to fit the texture of the current material onto all quad-faces in the selection. The texture should fit once across the face, no tiling.
- Rotates the orientation of the textures on the quad-face,
- Transfers the material from one side of the face to the other. UV mapping will be mirrored.
UVtools
by D. Martens
Sections: Edit ; Materials - Rendering
Cylindrical and spherical mapping on surfaces.
UV Projection
by J. Sandstrom
Can easily fix messed up UV's by projecting planar UVs on a selection in either X, Y or Z axis.
Cylindrical UVtools may work best
User avatar
dukejazz
SketchUp version: 7
License type: Free
SketchUp use: hobby
by Ad Machine » 5 minutes ago
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Premium Members get 20% discount!
Ad Machine
Robot
Return to SketchUp Tutorials
Who is online
Users browsing this forum: moonsoo and 1 guest
