bottle label
• Page 1 of 1
bottle labelhi sorry my bad english, i search a tutorial for draw a bottle label (cilinder) in sketchup (sample. http://www.candybarwrap.com/images/lill ... sample.jpg) please help me, thank you, regards
Re: bottle labelHere's one for a label onto a curved surface - you can apply the ideas to a single curved bottle.
To make the bottle itself draw a circle for its plan and a half section face - followme the section around the circle, add transparent material etc... TIG
Re: bottle labelHi, frizio
Assuming that you have already made a bottle, you can wrap your texture around it - check out this thread for some additional info viewtopic.php?f=79&t=21762&start=15 viewtopic.php?f=15&t=13564&p=100523&hilit=wrap+label#p100523 Last edited by numbthumb on Tue Oct 05, 2010 6:26 pm, edited 1 time in total.
Comfortably numb...
Re: bottle labelHere's an alternative to using a 'projected-texture' - it's a 'wrapping' method viewtopic.php?p=100569#p100569
Re: bottle labelAs long as the projection does not go too much around the object you are projecting it onto, it is fine as the distortion on the sides is not that visible.
Once it goes too much onto the sides however,the wrapping method is much more preferred (though bit more laborious) and in any case, it gives a much more precise result. Gai...
Re: bottle labelok, I look, thank you..
Re: bottle labelNo problem, Fabricio. We all started somewhere! I still remember when I discovered SketchUp some 4+ years ago...
Re: bottle labelHI,
Is there anyone able to help me in applying graphics on the can, but the rest of the can, it should be in aluminum. (Like REDBULL cans) I have something like this (left): but it has to be something like this but white should be cans color (right). It`s any video tut or someone can help me step by step?
SketchUcation One-Liner AdvertsArtisan Organic Toolset - a set of powerful organic modeling tools.
• Page 1 of 1
